Old 05-27-2010, 05:08 PM   #1
MTI Racing Kevin
MTI Racing Kevin's Avatar
Drives: 2010 Camaro
MTI Racing DMH Exhaust Cutouts
These electric exhaust cutouts from DMH Performance are to cool, with the flip of a switch your Camaro takes on a whole new aggressive attitude. These cutouts are great when you pull into the show or at a cruise night, hit the button and watch everybodies head turn your way, SWEET. They also work perfectly when you hit the drag strip, nothing like the full growl of straight pipes down the 1320.
These are not cheap cutouts of days past, these are extremly well built with a 4 year warranty. Let me know if anyone has any questions.
MTI Racing Kevin is offline   Reply With Quote
Old 05-27-2010, 05:36 PM   #2
Rage
TRI-COUNTY CAMARO... FTW!
Rage's Avatar
Drives: 2010 Camaro 2SS M6 Cyber Grey
Pretty cool. Any dyno specs on the LS3? And of course....$$$$? Thanks!
CAI inc. cold air intake, LG G6x3 cam, Patriot Gold Extreme Dual springs, Titanium retainers and locks, LG SuperPro 1 7/8 Long Tube headers with full 3" exhaust, DynoMax VT mufflers, SLP 4" tips, Moroso catch can, Race Ready electronic exhaust cut outs, Full painted Razzi body kit, Headlight Armor Smoke taillight and marker blackouts, T-Rex aluminum upper and lower grille, Polished aluminum front and rear bowties. Professionally installed and Dyno Tuned by HorsePower Sales, Pompano Beach FL.
Rage is offline   Reply With Quote
Old 06-03-2010, 01:17 PM   #3
how hard are these to install or do they have to be installed by a shop.
Old 06-04-2010, 11:17 AM   #4
MTI Racing Kevin
Drives: 2010 Camaro
You can install them yourself as long as you are ok with cutting and welding your exhaust pipe. The low profile cutouts require an oval hole cut into the pipe and then welding the flange to the pipe. Then you bolt and wire the electric cutout to the welded flange.
The round cutouts are available with the flowtech Y pipe for easier installation. Just cut out a section of pipe, replace the section with the Flowtech Y pipe, attach the electric motor and cutout, run your wiring and you are all set.
Here are the DMH Cutouts with the Flowtech Y pipes
The low profile cutouts have a flange on the back that welds to the pipe.
Old 12-02-2010, 08:41 AM   #5
jhyland87
Drives: 2011 2ss rs, black
I know this is an old thread, thought id bump it rather than create a new one..
has anyone tried these and actually got the car thrown on a dyno?.. I want to know where they should be mounted, and what to do about the backpressure. Does this not give you enough backpressure?
I had one on my RSX, before the cat, and it slowed it down like crazy
jhyland87 is offline   Reply With Quote
Old 12-02-2010, 08:53 AM   #6
the upcoming
the upcoming's Avatar
Drives: 10'2SS/RS,94'toyoda,02'vette
thanks for reviving the thread ive been looking into cutouts espicially these and noweeds.
these cutouts go any lower than the bottom of the car? i ask this because when im at shows i have an air ride system on my car and its only a few in off the ground.
and i was wondering about any trapped gasses underthere if i had them open while i am all the way laid out?
thanks for any help
the upcoming is offline   Reply With Quote
Old 12-02-2010, 09:35 AM   #7
Santos
Santos
Santos's Avatar
Drives: 1SS Blk 6M ECS 1500
how are these compared to noweeds? pricewise and performance?
Santos is offline   Reply With Quote
Old 12-02-2010, 12:18 PM   #8
the upcoming
price wise they are defently cheaper than noweeds but i have heard from different people that noweeds is a better set up but i cannot say how much truth is in that.
Old 12-02-2010, 12:55 PM   #9
MTI Racing Kevin
Drives: 2010 Camaro
thanks for any help
The DMH cutouts tuck up under the car very nicely. They can be angled down a bit or can be installed coming straight off the pipe. In your situation the Low Profile would be the way to go for ground clearance.
Old 12-02-2010, 01:50 PM   #10
Alain
Alain's Avatar
Drives: 2016 Challenger Hellcat, 2018 ZL1LE
how much are these bad boys?
Alain is offline   Reply With Quote
Old 12-02-2010, 02:48 PM   #11
tarheel34
Go Heels!!!
tarheel34's Avatar
Drives: 2010 Camaro 2SS/RS
So you CAN run the y pipe and round cutouts? Everywhere I've seen people are putting the low profile cutouts on.
Team L99
2010 Summit White 2SS/RS L99: TSP 1 7/8 LTs - Off-Road Pipes | Tuned By BLUECAT | CAI Cold Air Intake | ADM Race Scoop | SLP UD Pulley | VMAX Throttle Body | Magnaflow X-Pipe | Muffler Delete | SLP 160* T-Stat | MSD Wires
tarheel34 is offline   Reply With Quote
Old 12-10-2010, 10:22 AM   #12
the upcoming
what about the heat from me being low to the ground and the gasses not being able to get from out under my car so easily
Old 12-13-2010, 01:08 PM   #13
MTI Racing Kevin
Drives: 2010 Camaro
This is the situation the low profile cutouts were designed for. I do not think you will have any issues with heat or the exhaust gasses. You can install the cutouts to face the outside of the car on each side to help get the exhaust gasses out.
Old 12-15-2010, 12:41 AM   #14
ac223mal
Drives: car
Do you have any pictures of the cut-outs installed using the flowtech y-pipes on a camaro?
ac223mal is offline   Reply With Quote
V8 Camaro Aftermarket Exhaust Video Clips Compilation tjbusa Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 591 07-06-2022 09:38 AM
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 93 08-30-2021 06:56 PM
MTI Racing at Road Atlanta 3/13-3/14 MTI Racing Kevin 5th Gen Camaro SS LS LT General Discussions 0 03-10-2010 10:06 AM
MTI Racing Stage 1 Suspension Upgrade MTI Racing Suspension / Brakes / Chassis 0 01-27-2010 11:14 AM
Tom Henry Racing Announces a Special Edition 2010 Camaro! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 72 04-30-2009 01:57 PM
