Old 05-27-2010, 09:13 PM   #1
OldJedi
Use the Force
OldJedi's Avatar
Drives: 2015 Corvette Z51, 2018 Porsche GTS
Send a message via AIM to OldJedi
Why does Camaro have lower skidpad numbers than CTS-V?
I have a question for all of you really good suspension technicians out there. In reading the testing that was done on the Camaro by a lot of the magazines, the Camaro was showing skidpad g numbers of .88 and the CTS-V had numbers of .94. If both cars are on the same chassis and neither one is lowered why does the CTS-V have better handling numbers?
Walk softly, carry a light saber and drive a ZL1!
OldJedi is offline   Reply With Quote
Old 05-27-2010, 09:27 PM   #2
Rob@WretchedMS
Drives: His Wife Crazy
Wheel base, magnetic ride control, 19" wheels, not sure about the tires on the cts-v
that's off the top of my head, but you can make a camaro turn ~1g no problem
Rob@WretchedMS is offline   Reply With Quote
Old 05-28-2010, 02:38 AM   #3
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
Hey
the Pedders Camaro measured 1.38g's
rob is 100% correct
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 05-28-2010, 11:58 AM   #4
OldJedi
Use the Force
OldJedi's Avatar
Originally Posted by dms View Post
Hey
rob is 100% correct
mike
dms
Thanks for the info. Are the Magnetic shocks better than the Pedders coilovers?
Old 05-28-2010, 12:20 PM   #5
Mr Twisty
Mr Twisty's Avatar
CTS-V is Sigma II chassis
Camaro is Zeta II chassis
Just FYI
I think GM knowingly left some handling on the table, compromising NVH numbers over performance.
-- Benjamin Franklin
lib·er·ty
/ˈlibərdē/
noun
1.
Old 05-28-2010, 12:48 PM   #6
Info@PeddersUSA.com
Depends on what your perameters are. the Magnetic shocks are better for offering a larger adjustable range automatically, but in terms of a performance strut, they are not.
Case in point, there was a CTSV that ran the autocross I posted about several weeks ago. The Custom Alignment Camaro, with our Xa Track system with street tires and a performace street alignment, with only a CAI and custom exhaust, was much faster on the coarse than the CTSV that had performance wheels and tires. Now, I have know idea how good the driver was on the CTSV, which makes a difference of coarse on ETAs.
But our Pedderized Camaro with our Xa's outperformed all the BMW M3s except one that had compound tires and was very modified.
Thanks
mike
dms
Old 05-28-2010, 10:55 PM   #7
OldJedi
Use the Force
OldJedi's Avatar
Thanks
mike
dms
Thanks for the info, I appreciate it.
Old 05-30-2010, 01:07 PM   #8
boxcar
boxcar's Avatar
Drives: 2LT/RS
test
boxcar is offline   Reply With Quote
Old 05-30-2010, 08:12 PM   #9
mws444
mws444's Avatar
Drives: 701 RWHP Lingenfelter/Pedders Beast
Originally Posted by boxcar View Post
test
Test of what?
Lingenfelter forged balanced and blueprinted LS3, Maggie TVS 2300 LPE 9.5" Rearend 3.73,LPE dual disk clutch,10/14 rib belt drive,
MTI shifter,RPM Level VI,Corsa stainless cat back, Racing Brake Rotors, LPE calipers, LPE twin fuel pumps, American Racing long tube headers, GT9 cam Port and polished heads and an ADM majic tune.
701 RWHP,Fully Pedderized w/complete bushings and Sportsryder Supercar Remote resevior coilovers.
CCW 505t's Nitto Invo's and DR's
Beware of the LPE Brotherhood!
mws444 is offline   Reply With Quote
Old 06-22-2010, 06:00 PM   #10
JusticePete
Drives: Camaro Justice
You would get a spirited debate on this from an OE engineer that has worked on the magnetic systems. You'll find various forms of electronic ride control on top shelf vehicles made around the world. The idea is that they adjust as you need them too and taken to the extreme become part of the vehicle dynamic stability system. They work really well.
Now if you talk to drivers, really skilled drivers, you will see that many prefer the predictability of a manually adjustable coilover. The reasons are that the manually adjustable coilover can be dialed in for a specific track or driving style. The response will be exactly what the driver is expecting with no surprises from the computer making an adjustment the driver didn't want made. The second would be height. You cannot corner weight a car with electronic shocks at this time.
Your question though was skid pad numbers. Check the tire sizes...
Camaro Laws ChevyNut Off-topic Discussions 107 11-09-2016 05:40 PM
Installation Camaro Needed for Manual for a Justice Install Package in SF Bay Area Info@PeddersUSA.com USA - California 6 04-30-2010 08:02 PM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
