Old 05-27-2010, 10:35 PM   #1
chevyridinghigh
The Bowtie Is Back
chevyridinghigh's Avatar
Drives: 2010 Silver Camaro SS/RS -Blk Int.
Daytime running light bypass
Does anyone have a DYI on the bypass to the daytime running lights? I would rather no lights be on than those things, as an alternative to buying nicer bulbs. thanks.
2SS RS SIM M6 with Polish Silver wheels
chevyridinghigh is offline   Reply With Quote
Old 05-27-2010, 10:40 PM   #2
guyjusthere
guyjusthere's Avatar
Drives: 2016 2SS Camaro
yep..
ground the dk green wire from bcm, white plug (pin 11)
This wire can be grounded at BCM (by gas pedal) or at light switch (simply pops out )
DARK GREEN -> GROUND
VERY SIMPLE
guyjusthere is offline   Reply With Quote
Old 05-28-2010, 02:58 AM   #3
dmiller66
Tampa Gulf Coast Family
dmiller66's Avatar
Drives: '13 2SS/RS, Blue Ray Metallic, Auto
couldn't you just unplug them?
dmiller66 is offline   Reply With Quote
Old 05-28-2010, 03:11 AM   #4
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
I just keep my halos on during the day. turn the lights on one click to the right so the auto is off.
Old 05-28-2010, 03:40 AM   #5
MinnesotaDream
MinnesotaDream's Avatar
Drives: 2010 RS Inferno Orange
mee too Mindz...
MRT V2 - FOOSE Legends
MinnesotaDream is offline   Reply With Quote
Old 05-28-2010, 02:15 PM   #6
chevyridinghigh
The Bowtie Is Back
I do the same thing b/c I am anal and I don't like the running lights. I would rather no lights during the day in addition to increasing the lifetime on the halos.
Old 05-28-2010, 02:16 PM   #7
chevyridinghigh
The Bowtie Is Back
Originally Posted by guyjusthere View Post
yep..
VERY SIMPLE
How do I ground it? I am assuming unplugging will work but that doesn't seem safe.
Old 05-28-2010, 03:13 PM   #8
asmith10
Drives: Camaro 2LT/RS IBM
Don't you just turn the dial that you use to turn on only the halos to the left? That overrides the auto lighting and turns everything off. (figured it out trying to sneak back home at night)
asmith10 is offline   Reply With Quote
Old 05-31-2010, 02:50 AM   #9
Topdown
The wait is over!
Topdown's Avatar
Drives: 2010 Camaro, IOM, L99, Auto
(dont flame me, have only had my car for a few hours, lol)
but wouldnt turning the switch to the right cause the lights to stay on all the time (even when the car is off) unless you turned the switch every single time you get in and out of the car?
I am wondering how to get my Halo's and my DRL on at the same time... all the time, and saw this post.
Ordered - 4/17/2010
Delivered - 5/29/2010
AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener
Topdown is offline   Reply With Quote
Old 05-31-2010, 03:26 AM   #10
TripleB
SoCal Mayhem
TripleB's Avatar
yeah, just turn the knob to the left and it'll turn them off...you have to do it everytime you start the car, but that's no biggie.
Old 05-31-2010, 08:21 PM   #11
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
If you have an RS, you just turn the dial to the left one click to shut off the DRLs. If you want to just run the halos, turn it one click to the right.
If your turn the halos on, then yes, you need to turn the dial to the left to shut them off when you turn off the car. The car lets you know the lights are on when you open the door, so you won't forget.
Old 05-31-2010, 08:25 PM   #12
boatingbent
boatingbent's Avatar
Drives: 69 Pontiac Firebird
I just take a little Black screw on cap off a Bottle of Pop or I found a smaller Black cap on my Gasoline Stable can... and set it untop of the little eye ontop of my dash ...my lights come on with the key and off with the key....
1100, Ordered car May 22nd 09
2000, Order accepted by GM - 26 May 2009
3000, Order accepted by production control 5/27
3300, Order scheduled for production
3400, Order broadcast
3800, Order produced..2G1FT1EW4A9125913
Delivered to me July 28th
boatingbent is offline   Reply With Quote
Old 05-31-2010, 08:53 PM   #13
Darth_Emma
Darth_Emma's Avatar
If you have them set to auto they will turn on and off with the key. If you turn the halos on during the day by turning the switch one click to the right, then you need to turn them off when you turn the car off. But, your method of fooling the sensor with a cap over it will also work if you want the headlights on all the time when driving (not the halos).
Old 09-18-2010, 11:28 PM   #14
Hotrod6464
Drives: 2011 Black 2SS/RS LS3 M6
I purchased a switch from a lt with the fog light switch in the middle and installed it hoping it would work to turn them on and off. No luck. Does anyone know if gm can reprogram it with the tech2 so the switch works them.
Hotrod6464 is offline   Reply With Quote
New! ABS Hard Plastic Side Marker, Reverse Light and Tail Light Kits! Not cheap vinyl RPI Designs Exterior Parts & Accessories 132 12-31-2020 07:43 AM
KITT light installed and Thoughts ttexxan Cosmetics and Lighting Modification Discussions 3 04-27-2010 07:53 AM
Changing the Light in the Reverse lights? xpanda305x Cosmetics and Lighting Modification Discussions 6 04-18-2010 04:04 PM
How many forum members does it take to change a lightbulb? stovt001 Off-topic Discussions 28 05-26-2009 09:17 PM
