Old 05-31-2010, 12:57 AM   #1
Dreamer2430
I need to win the Lotto
Dreamer2430's Avatar
Drives: 2010 IBM 1SS LS3
V8 Tranmission Upgrades
Well, I don't need this just yet, but I've seen (as I'm sure we all have) a lot of HP upgrades. At what point in HP or torque would I need to look at upgrading the stock tranmission. I have a huge list of upgrades I would like to do as time and $ allow. I've seen a lot of other drivetrain upgrades (clutch, flywheel, rearend, axels, driveshafts, ect) and I think I have an idea of what I would like to do, but I can't say I've seen or even heard a lot of people talk about their transmission upgrades. I can't recall exactly where, but I thought that I heard that the stock transmission on the SS/LS3 (6L80?) cars was only good to about the point of 600 HP. If any one can point me towards a tranmission that can handle more HP than stock I would appreciate it.
"Drive it like you stole it!"
Dreamer2430 is offline   Reply With Quote
Old 05-31-2010, 07:34 AM   #2
shroomjohn
shroomjohn's Avatar
Drives: Golden Eagle
Dont think you'll need to swap out transmissions just beef yours up some.
Loving this car!
shroomjohn is offline   Reply With Quote
Old 05-31-2010, 10:57 AM   #3
hamidar05
Drives: 10 Camaro/69 Bronco/08 Mazda3
This a great question!
I am sure someone will figure it out soon enough, dimensions and all. I am not sure anyone listed what the current one will take?
Are you going to do the Silver State Classic, or do they still run it? Most these folks have no idea of a real Banzai Run I am sure! We expect pictures and video if you do!
Selection Worksheet - 04/27/09
3300 - 08/03/09
6000 - 08/25/09
VIN# 34612
Bitchin Camaro - Dead Milkmen - http://www.newgrounds.com/portal/view/8092
Thank You Oshawa - Domo arigato Mr. Roboto
~1600 mi so far - 07/18/10
hamidar05 is offline   Reply With Quote
Old 05-31-2010, 11:18 AM   #4
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Here's a listing of all the gm spec sheets. Click on the ss and it will download a spread sheet with the specs for you.
http://archives.media.gm.com/us/powe...a/10car_us.htm
9/26/09 Took delivery!
Old 05-31-2010, 11:31 AM   #5
hamidar05
"SS" Does not say maximum capabilities of the tranny, nor the dimensions of the transmission... hmm have to dig a little deeper. Thank you, this is still a good resource!
2010 Tremec TR6060 (M10) 6/5/2009
Type: Rear wheel drive, six-speed manual overdrive transmission
Engine range: LS3 426 hp
Maximum engine torque: 420 lb-ft ( 569 Nm )
Maximum gearbox torque: 430 lb-ft ( 580 Nm )
Gear ratios: M10
First: 3.010
Second: 2.070
Third: 1.430
Fourth: 1.000
Fifth: 0.840
Sixth: 0.570
Reverse: 3.280
Final Drive Ratio: 3.450 (rear axle ratio)
Maximum validated gross vehicle weight: 3860 lb ( 1755 kg )
Case material: Aluminum
Center distance: 85 mm
Fluid type: Texaco ATF Type III 1863
Transmission weight: Wet: 66.3 kg (146.2 lb )
Fluid capacity (approx.): Dry: 3.45L +/- 0.06L, ( 117 oz +/- 2 oz. )
Fluid capacity (approx): with cooler line Dry: 3.94L +/- 0.06L, ( 133 oz +/- 2 oz. ) with cooler line fill
Power take off: No
Applications: Chevrolet Camaro SS
If you click on the Story, this is there:
Overview
Both the standard Corvette and the high-performance Z06 use the TR6060 designated as MM6, which is validated to 500 lb-ft of torque, while the TR6060 with the Z51 option features higher ratios and is designated as MZ6. It is validated to 430 lb-ft of torque. The ultra high performance ZR1 uses the TR6060 designated as the MH3, which is validated to 650 lb-ft of torque. The CTSv uses the MG9 version of the TR6060 validated to 560 lb-ft of torque. The Camaro uses the M10 gear set validated to 430 lb-ft of torque.
So, sounds like technically, a trans upgrade is in order based on the gears used... for the M10.. need to get the MH3 version, or see what else is out there.. :(
3300 - 08/03/09
6000 - 08/25/09
VIN# 34612
Old 05-31-2010, 12:38 PM   #6
Dreamer2430
I am only asking because I have a giant list of power adding mods I would love to do. I've found a few options for the rest of the drive train, but I haven't heard the full capabilities of the transmission. So, I guess, I'm thinking at a certain point I will have to swap out the trannny, shroomjon
Hamidar05, I won't be able to make it to the Silver State Classic Challenge this year (looks like it's September 16-19). I will be out of the state. :(
v6sonoma, thanks for the link.
Thanks
Old 05-31-2010, 02:02 PM   #7
Eric Baker
Drives: Black/Black 2SS/RS 6M
That's what it's VALIDATED at, not what the maximum capability is. There are people running well over 700 RWHP one the full stock drive train. The real limit has not been found yet for the SS parts, except maybe for the axles.
Eric Baker is offline   Reply With Quote
Old 06-01-2010, 09:25 PM   #8
hamidar05
Anyone from Nevada probably knows about gambling.. and I wouldn't want to gamble on being stranded on one of their lonely highways if the transmission broke...
3300 - 08/03/09
6000 - 08/25/09
VIN# 34612
Old 06-03-2010, 07:23 AM   #9
mstrfdsstr
mstrfdsstr's Avatar
Drives: 2010 SS/RS CAMARO
Thanks
rockland standard gear you need a stronger output shaft and a support bearing in the tail housing at least
IOM 2 SS/RS LS3 vin9862
mstrfdsstr is offline   Reply With Quote
Old 06-03-2010, 07:50 AM   #10
BoostedX2
BoostedX2's Avatar
Drives: VR ZL1 #259/Nissan 370Z NISMO
GFORCE is working on a stronger output shaft...
BoostedX2 is offline   Reply With Quote
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 93 08-30-2021 05:56 PM
Does the v6 have enough power? cstproductions Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 305 08-29-2012 09:27 PM
Richmond Gears V8 and V6 - Group Buy ZZcamaro Transmission / Driveline 175 04-30-2010 12:29 AM
If gas goes up, then get the V8 !! Patriot 5th Gen Camaro SS LS LT General Discussions 37 04-28-2010 01:31 PM
Jay leno hints to the z28 in video!!! tru imperial blu Camaro ZL1 Forum - ZL1 Specific Topics 103 11-27-2009 09:56 AM
