![]() Drives: L99 cyber grey Join Date: Aug 2009
Check Engine Light
My check engine light came on over the weekend. A few months back I got the car tuned when I installed the vararam intake and long tube headers, but have not had any problems since then -- Odd! Any thoughts on what it may be?
I would take it back and have the tune checked just to make sure nothing has changed
1 7/8 AR headers, roto-fab CAI with radiator, fuse box, and valve cover, cam, upgraded fuel system with 85lb injectors, under drive pulley, TVS 2300 S/C, muffler delete, aftermarket wheels, AAC headlights fogs sidemarkers footwell dome and trunk lights.....That's 659.9 RWHP 611.9RWTQ
T |
Pull the code and post it.
Choke on that causality!
Drives: 2010 2SS/RS Join Date: Sep 2009
When you change the air flow characteristics (intake & headers in your case) its easy to generate a code. Also your tune may not be accommodating the changes fully. Call OnStar and ask them to run a diagnostic, they can give you the actual code.
Think this will hurt the car?
#6 |
Without knowing the code its impossible to know.
#7 |
below are the codes:
p1133 po171 po174 p1153 |
#8 |
P0171 System too Lean (Bank 1)
P0174 System too Lean (Bank 2) P1153 HO2S Insufficient Switching P1133 HO2S Insufficient Switching from http://www.engine-light-help.com/oxy...sor-codes.html "These codes tell you that despite the computers attempts to correct fuel trim (the amount of time the injectors stay on, delivering more or less fuel as needed); it can not obtain the correct air/fuel ratio. The most common issues for lean codes are: 1. Vacuum leaks - check for failed or loose vacuum lines, leaking intake gaskets, intake air tubes loose or any other source of un-metered air leaks (leaks after the Mass Air Flow Sensor) 2. Restricted fuel filter or bent/pinched fuel system lines 3. Incorrect input from other sensors, such as the Mass Air Flow Sensor, which may not always drop a separate code " All look to be oxygen sensor related. |
#9 |
I should be able to take it back to the tuner and he should be able to correct this pretty easily, correct?
#10 |
Yes take it back. I saw this on two other cars (friends of mine) and it was an easy fix for them.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS IOM L99 Join Date: Jan 2010
take it back and have it retuned.
#12 |
Is there a key trick or anything to view the codes on the dash?
#13 |
no, called on-star
#14 |
Please remember to share your findings & results with us so that others will have a heads up.
| check engine light question | shroomjohn | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 7 | 08-02-2010 02:25 PM |
| P0300 Misfire Code Help | black-knight | 4th Generation Camaros | 4 | 02-08-2010 02:45 PM |
| Anyone have their engine light come on and stay on...Advice please (Pic) | DCJ | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 38 | 09-07-2009 06:26 PM |
| New 4.5 L Duramax Diesel V8 for light duty pickups | Scotsman | General Automotive + Other Cars Discussion | 8 | 12-01-2008 07:21 PM |
| Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-05-2008 06:29 PM |
