Old 05-31-2010, 03:04 PM   #1
Dentyneice
Drives: 2010 Camaro 2ss
Fuel Injection cleaning
So I was looking around some Two Guys Garage videos and came across this one mentioning a good 3M fuel injection cleaning system which sparked a few questions.
Do we even need to worry about cleaning the fuel injection?
Where is the spot on our car to hook up that hose to from that first can in the video (when the dude put the clip on the throttle thing)
When should we worry about cleaning our fuel injectors?
Just gathering materials for future maintenance
(Skip to 0:33 to skip the intro)
Note that the audio is glitchy around the 1:10 mark
2010 CGM/Black 2SS M6
20% Tint -:- Hurst 44% Short Throw Shifter -:- Viper 5901 Alarm/Remote start -:- High Gloss Black Painted Calipers + White Brembo Decal
Dentyneice is offline   Reply With Quote
Old 06-03-2010, 06:46 PM   #2
Dentyneice
After looking up some info on SIDI, do we even need to worry about fuel injection? Fuel gets squirted directly into the cylinder and doesn't go through the intake valve
Old 06-04-2010, 01:16 PM   #3
Russell James
Russell James's Avatar
Should only need to clean the injectors if they get dirty and cause a rough running condition. So for many vehicles they may never need to be cleaned. All depends on the gas quality. I've seen cars 1 yr old or less running real rough, and smooth right out after an injector cleaning. I've also owned many vehicles for many years and never once needed an injector cleaning. I stick with name brand gas.
My dad was having injector clogging problems repeatedly with a Caddy a few years back. His Caddy dealer cleaned them twice. Then I asked him where he get's his gas? Krogers Grocery Store, because he has a discount card from Krogers. I convinced him to switch to the name brands... Mobil, Shell.... and he's never had a problem since.
Bottom line is don't buy your gas at the same place as your groceries and you'll probably be fine. The better brands have that little bit of cleaning detergent that keeps the injectors clean.
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 273 08-15-2023 05:44 PM
Modifying for " Dummies" Dr Jkel Tuning / Diagnostics -- engine and transmission 209 06-18-2012 12:24 AM
GM Reveals Small-Block V-8 with Direct Injection - wardsauto.com Mr. Wyndham Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 176 06-17-2010 12:31 AM
PERRIN Performance Water/Methanol Injection Kit PERRIN_JOHN Forced Induction 4 03-17-2010 10:57 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
