Old 06-05-2010, 10:07 PM   #1
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
Torque Wrench Necessary?
Hi guys,
I'm going to be doing my first oil change in a week =D I bought everything I need... and I bought a Bendy bar torque wrench for the Drain plug. Then I realized... do I really need the torque wrench? 18lb-ft shouldnt be super tight right?
Anyone change their oil without using a torque wrench? I just don't know if I need this.
jagan323 is offline   Reply With Quote
Old 06-05-2010, 11:48 PM   #2
thiggin2
thiggin2's Avatar
Drives: 05/07 Chevy's
I have been working in a GM shop for 20 years and I have never seen anyone every use a torque wrench for that before. You just don't want to over tighten. I just make mine nice and snug.
thiggin2 is offline   Reply With Quote
Old 06-06-2010, 02:24 AM   #3
jagan323
I have no life
jagan323's Avatar
okay, thank you for the reply! I'll return it and save the CASH! =D
Old 06-06-2010, 06:32 PM   #4
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Just snug it up with the socket wrench - its pretty easy to overtighten it.
Be careful with the filter as well. A little new oil on the rubber gasket, then hand tighten before turning another 1/2 turn with the wrench. If you overtighten the filter, you'll have a bear of a time getting it off next time...
Old 06-06-2010, 06:41 PM   #5
jagan323
I have no life
jagan323's Avatar
Thank you the advice. I will make a note of that when I do it =D
Old 06-06-2010, 07:43 PM   #6
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
dont need it but a torque wrench is a must have item to have in the tool box. I wouldn't return the wrench.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 06-06-2010, 10:09 PM   #7
ClaymoreZ28
ClaymoreZ28's Avatar
Drives: 2010 2SS/RS IOM Camaro
Only comment here is that no-one replying here knows how well calibrated your hands are on torque - so using a torque wrench if you have one is cheap insurance - just my 2cents worth. If you have one it just takes a few secs to use it - if you have one and dont use it and mess up - you will be a very unhappy camper
SSMAUG - IOM 2SS/RS/6M
Breathing Fire since October 8th 2009 !
ClaymoreZ28 is offline   Reply With Quote
Old 06-06-2010, 10:16 PM   #8
danhr
BAMF SS
danhr's Avatar
if you can mess up putting a drain plug back on a car, you should not be changing your own oil to begin with.
Stock Longblock
Old 06-07-2010, 11:45 PM   #9
jagan323
I have no life
jagan323's Avatar
lol... what kinda torque wrenches do you guys buy? The Bendy kind? or the Clicky style for the sound? =o
Old 06-08-2010, 03:42 PM   #10
obe1
obe1's Avatar
Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28
The "Bendy Bar" is not very accurate and tough to read; A click style is pretty much fool proof. Also torque wrenches cover dfferent ranges of torque. I have a large 1/2" drive one that works from 25 - 250 lb-ft that is used on many applications, and a small 3/8" drive that covers 25 - 225 lb-in. 18 lb-ft is 216 lb-in.
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected - Sold
1968 Camaro - Sold
2019 Corvette Grand Sport
obe1 is offline   Reply With Quote
Old 06-08-2010, 04:03 PM   #11
danhr
BAMF SS
danhr's Avatar
clicky ftw
Stock Longblock
Old 06-08-2010, 04:05 PM   #12
brandotron
I am the internets.
brandotron's Avatar
Drives: dangerously
Clicky here
brandotron is offline   Reply With Quote
Old 06-08-2010, 04:28 PM   #13
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
I use a clicky kind made by CDI which is a subsidiary of Snap on. I have an inch pounds and a foot pounds one. Basically if you take a 3/8 rachet with the corresponding socket, hold it in one hand and then tighten, holding the ratchet at the bottom with your thumb on the ratchet like you are giving a thumbs up. That is about 12 - 15ish foot lbs. If you put just a touch o muscle in it you will be fine on the oil plug doing it this way.
Cheers
K
Moriartii is offline   Reply With Quote
Old 06-08-2010, 11:45 PM   #14
jagan323
I have no life
jagan323's Avatar
Thanks guys for the feedback. I ended up buying a clicky type torque wrench. 3/8 drive and 10-85ft-lbs. I'll get another for my Wheels prolly get a 50-250 later on =p
Torque Converters CamaroSpike23 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 48 08-16-2014 03:07 AM
2011 Mustang Info (Keep all threads here) RealQuickCamaro General Automotive + Other Cars Discussion 2648 04-15-2010 09:09 PM
Torque Converters Explained tbyrne V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 01-07-2010 01:38 PM
ProTorque Converters - FREE Shipping! tbyrne Transmission / Driveline 0 01-07-2010 01:36 PM
Camaro5.... Recommend me a Torque Wrench Jeanius Off-topic Discussions 24 01-05-2010 10:07 PM
