![]() Drives: 2010 Victory Red 2SS/RS Join Date: Sep 2009
92248560 (V8) Ground Effects installation
The installation NOTE states, "Before starting the installiation, check that the vehicle has not been fitted with a GM performance exhaust accessory that has chrome tips. If this is the case this kit cannot be installed".
Can someone explain why the kit cannot be installed? |
![]() ![]() ![]() Drives: '10 2SS/RS, MKIII Supras Join Date: May 2010
I think the tips would be too big to fit in the rear bezels. The stock SS tips barely fit.
![]() ![]() Drives: 2SS/RS White/blk int.M6,GFX Join Date: Mar 2009
Correct.Here is the closet pic i have.If you zoom in you can see it.
Drives: 2SS/RS Join Date: Mar 2010
The stock 3" hardly fit. Anything more and the tips won't fit into the GFX hole.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 c7 Join Date: Nov 2009
idk why they made it so small.... what if someone that bought the car with the body kit.. wants to get a aftermarket exhaust lol
#6 |
Well.. I guess if you're going to buy the car to mod, you really shouldn't be spending $1,000+ on a cosmetic ground effect kit that adds no performance whatsoever to your car.
#7 | |
" no performances whatsoever " ( body kits ) ... say that to a car specialist... see what he says lol. |
#8 | |
![]() Drives: 2002 4 runner Join Date: May 2010
Also, i am just wondering, if you did get the camaro with gfx, could you install aftermarket exhaust? Do any of them fit? |
#9 |
i didn't get the gfx, see the problem is they made it to fit the stock tips. i think theres some tips that might fit... look are for 3" tips is what i think the stocks are
#10 |
I was referring to the GFX body kit. Not body kits in general.
This GFX has NO performance gains whatsoever. |
#11 |
Drives: SuperCharged 2SS/RS IOM MN6 Join Date: May 2009
Don't worry about the fitment of the tip, aftermarket or not. I have 3.5" tips and there is still plenty of room. The only thing to worry about is if the aftermarket tips are one piece (each one is a welded part of the muffler) and stick out too far..which is the issue with the stock tips and GM performance ones...which is why the stock tips are required to be cut when installing the rear GFX. My 3" catback has slip-on tips that I can adjust fore or aft to get the look I like, secured with a band clamp.
#12 |
![]() Drives: 2010 2SSRS RY Join Date: Feb 2010
Question. Do I have to really cut my exhausts tips to install this package? I successfully installed the sideskirts yesterday but I stopped for now since I need to know if the stock exhausts of a 2SS would really need to be cut to fit in the new diffuser? I have 3.5" tips stock, not chromed but polished stainless.
#13 |
![]() Drives: 2012 Triple Black ZL1 M6 Join Date: Jun 2010
Looks pretty slick, I would say find a way to get rid of or replace those crome eyelits.
CenterForce DYAD Dual Disc Clutch, JDP stage 2 Clutch Reservoir, Rotofab CF CAI with Big Gulp and WW Reservoir Relocate, Stainess Works LT Headers and Retro Cat-Back with Cat Delete, MGW ST Shifter with custom Knob, CF Tail light Bezels, more to come...
Build Thread for my Z is in the works..... |
#14 |
Stock 2SS tips fit in it fine. Mine do.
| Does the v6 have enough power? | cstproductions | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 305 | 08-29-2012 10:27 PM |
| Ground effects screw up!! Please Help | ssalter | 5th Gen Camaro SS LS LT General Discussions | 19 | 01-22-2010 08:48 PM |
| Ground Effects. | Bbrock25 | Camaro Photos | Spyshots | Video | Media Gallery | 3 | 06-23-2009 05:00 PM |
| Ground Effects Scam | DkknightX | 5th Gen Camaro SS LS LT General Discussions | 62 | 06-23-2009 12:43 PM |
| News on Ground Effects? | DkknightX | 5th Gen Camaro SS LS LT General Discussions | 7 | 06-22-2009 12:10 PM |
