Old 06-09-2010, 10:06 PM   #1
B.Buster
B.Buster's Avatar
Drives: 2010 AquaBlue 2SS/RS
E-Force uses Ford supercharged MAP senser
Edelbrock uses Ford 2R3A 9F479 AA MAP senser on the E-Force supercharger. Also has IAT senser built in. I believe this is used on Ford supercharged motors.Can this be tuned like a 3 bar GM MAP in 2010 SS.Thanks
B.Buster is offline   Reply With Quote
Old 06-09-2010, 10:37 PM   #2
DSteck
Drives: 2006 Corvette Z06
If a person knows the pressure range that the sensor operates with, then you can recalibrate the sensor settings in the tune file. I can't find the data on that sensor, though.
Below shows the calibration data from a stock LS3 MAP sensor.
If possible, use a ZR1/LS9 MAP sensor (part number 12592525, MAP Sensor Linear 312.50 kPa, MAP Sensor Offset -11.25 kPa).
DSteck is offline   Reply With Quote
Old 06-09-2010, 10:55 PM   #3
B.Buster
B.Buster's Avatar
I wonder if these are interchangable.Would love to stay GM LOL
Old 06-09-2010, 11:28 PM   #4
DSteck
If the hole size on the Edelbrock setup is the same as on the LS3 intake, and you can make sure the MAP stays clamped down, then there's no reason you can't use an LS9 sensor.
Old 06-10-2010, 02:05 AM   #5
Busy_Boi
SoCal C5 Family Member
Busy_Boi's Avatar
Drives: RJT 2010 camaro 2SS
Send a message via Yahoo to Busy_Boi
I just found that out last week and had a problem get my car tune because of this. Edelbrock had to send and update so you can tune it ask Mike at Haddad Motorsports he can help you with any question about this.
Busy_Boi is offline   Reply With Quote
Old 06-10-2010, 05:47 AM   #6
B.Buster
B.Buster's Avatar
Because of where this senser is located it is hard remove . My other quesion is about the IAT part. Seems like temps seem higher then they should be.
Old 06-10-2010, 08:26 AM   #7
99-LS1-SS
Waiting...
Drives: 2009 G8 GXP M6
Can you supply a picture of the MAP sensor location?
What IATs are you seeing? Mine usually run around 25 degrees higher than ambient temperatures when cruising and can go as high as 35 degrees above ambient when running hard or sitting in traffic.
SOLD 2009 Maverick Silver G8 GXP M6
Engine Mods: TVS 2300 Magnacharger 6.5lbs, ARH 1 7/8" long tubes with catted x-pipe Roto-Fab Intake, Custom Fuel System, Tuned by Me
Drivetrain Mods: Stage 4 Monster Clutch, GForce 300M Race Axles
Suspension Mods: Pedders/Wretched basic drag pack - BMR trailing arms and toe rods
Misc Mods: Jamesbiz Catch can - GRRRR8 Heater hose relo kit
99-LS1-SS is offline   Reply With Quote
Old 06-10-2010, 08:45 AM   #8
DSteck
From a discussion on the HPT forum:
Originally Posted by yonson
I had a similar issue, ended up being the MAP/IAT out of calibration.
MAP Sensor Linear use 223.43
MAP Sensor Offset use -7.88
IAT sensor Cal (make sure the labels match as well)
Labels 563 715 918 1191 1564 2080 2804 3273 3837 4515 5337 6335 7556 9056 10908 13216 16092 19696 24239 30000 37352 46797 59016 74940 95851 123485 160313 209816 276959 368896 496051 673787 925021
Temp. 150.00 140.00 130.00 120.00 110.00 100.00 90.00 85.00 80.00 75.00 70.00 65.00 60.00 55.00 50.00 45.00 40.00 35.00 30.00 25.00 20.00 15.00 10.00 5.00 0.00 -5.00 -10.00 -15.00 -20.00 -25.00 -30.00 -35.00 -40.00
Old 06-10-2010, 06:44 PM   #9
B.Buster
B.Buster's Avatar
Hope this pic shows
Old 06-11-2010, 07:49 PM   #10
B.Buster
B.Buster's Avatar
DSteck, here's my numbers off Edelbrock tune
MAP sensor Linear 223.43 kPa
MAP Sensor Offset -7.88 kPa
SCIAP linear 0
SCIAP linear 0
Old 06-11-2010, 07:58 PM   #11
DSteck
SCIAP linear 0
SCIAP linear 0
Looks to be the same as what I had posted off the HP Tuners board. Should work out for you!
Old 06-11-2010, 08:12 PM   #12
B.Buster
B.Buster's Avatar
Tommorow I will test with my wide band to make sure AFR is good. I built a custom GM IAT sensor to test against Ford unit for accuracy.
Old 06-14-2010, 04:47 PM   #13
99-LS1-SS
Waiting...
How did the test go?
Old 06-14-2010, 07:34 PM   #14
topgearsean
Drives: 2002 Camaro B4C
I ran into an issue with the IAT sensor recently when installing an E-Force setup. It would only read 30 degrees fahrenheit. I checked all of the connections and must have had a loose pin in the Edelbrock harness, after checking continuity and having everything check out the IAT read normal. The MAP sensor is for an '03 Mustang Cobra and the tables in the Edelbrock tune are "very" close to being scaled the same as the Ford tables. Don't know if this helps any, just thought I would share the experience.
Sean
topgearsean is offline   Reply With Quote
Help Me Pick An Economy Car Marosolid Off-topic Discussions 75 07-11-2009 07:41 AM
Ford Interceptor Urthman General Automotive + Other Cars Discussion 18 07-24-2007 02:48 PM
Ford to rebrand Five Hundred with Taurus name KILLER74Z28 General Automotive + Other Cars Discussion 9 02-08-2007 04:02 PM
Interesting read on American cars and trucks...... fbodfather General Automotive + Other Cars Discussion 8 12-22-2006 09:47 PM
Financial Problems for Ford??? TAG UR IT General Automotive + Other Cars Discussion 14 10-29-2006 07:17 PM
