Old 06-14-2010, 12:17 PM   #1
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Forced Induction Supplements
Methanol/Water Injection
Excerpts from Wikipedia:
"In internal combustion engines, water injection, also known as anti-detonant injection, is a method for cooling the combustion chambers of engines by adding water to the cylinder or incoming fuel-air mixture, allowing for greater compression ratios and largely eliminating the problem of engine knocking (detonation). This effectively increases the octane rating of the fuel, meaning that performance gains can be obtained when used in conjunction with a supercharger or turbocharger, altered spark ignition timing, and other modifications.
Many water injection systems use a mixture of water and alcohol (approximately 50/50), with trace amounts of water-soluble oil. The water provides the primary cooling effect due to its great density and high heat absorption properties. The alcohol is combustible, and also serves as an antifreeze for the water. The purpose of the oil is to prevent corrosion of water injection and fuel system components. [1] Because the alcohol mixed into the injection solution is often methanol (CH3OH), the system is known as methanol-water injection, or MW50. In the United States, the system is commonly referred to as anti-detonant injection, or ADI.
In a piston engine, the initial injection of water cools the fuel-air mixture significantly, which increases its density and hence the amount of mixture that enters the cylinder. An additional effect comes later during combustion when the water absorbs large amounts of heat as it vaporizes, reducing peak temperature and resultant NOx formation, and reducing the amount of heat energy absorbed into the cylinder walls. This also converts part of combustion energy from the form of heat to form of pressure. As the water droplets vaporize by absorbing heat, it turns to high pressure steam (water vapor or steam mainly resulted from combustion chemical reaction), that would add engine output. The alcohol in the mixture burns, but is also much more resistant to detonation than gasoline. The net result is a higher octane charge that will support very high compression ratios or significant forced induction pressures before onset of detonation.
Fuel economy can be improved with water injection, although the effect on most engines with no other modification, like leaning out the mixture, appears to be rather limited or even negligible in some cases.
Some degree of control over the water injection is important. It needs to be injected only when the engine is heavily loaded and the throttle is wide open. Otherwise injecting water may simply drown the engine and cause it to quit.
Direct injection of water is possible. In a piston engine, this can be done late in the power stroke or during the exhaust stroke.
A limited number of road vehicles with large-displacement engines from manufacturers such as Chrysler have included water injection. Saab offered water injection for the Saab 99 Turbo. With the introduction of the intercooler the interest in water injection disappeared, but today, water injection is also of interest because it can potentially decrease nitrogen oxide (NOx) emissions in exhaust. The most common use of water injection today is in vehicles with aftermarket forced induction systems, such as turbochargers or superchargers. Such engines are commonly tuned with a narrower margin of safety from detonation and hence benefit greatly from the cooling effects of vaporized water."
Products
Alcohol Injection Systems
Coolingmist (sponsor )
Snow Performance
Heat Exchanger/Intercooler Spray Kits
Excerpts from Xplosive Performance Inc.:
"The CryOČ is a revolutionary new, award wining product designed to reduce the temperature of the air/fuel intake charge thus creating power. Through the science of aerodynamics and cryogenics, Design Engineering has developed a system to harness the cryogenic properties of liquid CoČ to lower the air/fuel intake charge by up to 60%. The system is modular and can be easily expanded. The CryOČ system provides two methods of cooling the air charge and one method of cooling the fuel charge, all utilizing the same burst of liquid CoČ. CoČ is readily available at any welding supply shop or where paintball guns are charged. Welcome to the future of power.
The foundation to every CryOČ System. Must have this kit to utilize CryOČ components. The kit includes a 10 pound CoČ tank, cryogenic solenoid valve, all necessary fittings, 14 ft. stainless steel hose, full wide open switch, arming switch, and wiring kit. Only one kit is needed to operate all the CryOČ components.
The CryOČ Intercooler Sprayer mounts directly to the front of the intercooler or aftercooler and vents the liquid CoČ directly onto the cooling fins, thus enhancing the performance of the intercooler by more than 50%. This component must always be the last in the CryOČ system as it vents the liquid CoČ charge. The CryOČ Intercooler Sprayer mounts directly to the front of the intercooler or aftercooler and vents the liquid CoČ directly onto the cooling fins, thus enhancing the performance of the intercooler by more than 50%. This component must always be the last in the CryOČ system as it vents the liquid CoČ charge.
The dramatic purge effect that people have come to love is now availiable at a fraction of the cost of other systems on the market. They can be used as a vent to a CryO2 system or as a stand alone show system. Must be used with a CryO2 Tank and Install kit (#080100 or #080102 or #080108 ). The purges come in single or dual vents and the supply line can be split multiple times for multiple bursts around the car. You can also use the purge system seperate from the CryO2 performane system buy utilizing the purge kits that includes a solenoid vave and extension hose. This set-up will seperate the performance from the show purge. CryO2 Purge Systems Get the Nitrous look without the Nitrous cost. The CryO2 purge system purges CO2 at a fraction of the cost."
Products
Xplosive Performance Inc. (sponsor )
Some more information from DEI
Old 11-02-2010, 10:29 AM   #2
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
Products
Snow Performance
Products
can this be applied to a maggie air to liquid cooler ?
2010 Hennessey HPE650 2SSRS Blk/Blk
Magnuson TVS2300,ported heads,cam,Hotchkis suspension. Weld 17”s, Mickey Thompson’s.
klatterblast is offline   Reply With Quote
Old 11-02-2010, 10:35 AM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Yup - many have with great results
'20 ZL1 Black "Fury"
Old 11-04-2010, 12:13 PM   #4
klatterblast
thanks thats a great idea
ENGINE & FORCED INDUCTION Milk 1027 Wiki 1 08-07-2012 12:48 AM
Forced induction help/advice! Chewy USA - California 11 06-09-2010 11:39 AM
v6 forced induction section bng804 Site Related Announcements / Suggestions / Feedback / Questions 2 01-13-2010 01:16 PM
Supercharger or Forced induction gzartman USA - Northwest / Pacific Northwest 4 01-11-2010 08:07 AM
Free Installation on all Forced Induction Systems through the end of the year!! ZZcamaro Forced Induction 6 11-16-2009 09:39 AM
