![]() Drives: Hall of Fame Join Date: May 2010
Oil change
Looking to see if the standard ramps they sell at auto parts will work to change the oil. Will they hit anywhere on the front of the car when pulled up on them?
I have no life
Drives: 06' Subaru STI, ex-Camaro V6 LLT Join Date: Apr 2010
I made my ramps... just make sure the Slant is long enough or low enough so your car gradually moves up.. shouldnt hit the car.
They should be OK, just watch out for some of the cheap ones that are so lightweight they just slide out of the way when the tires touch them
Sask-man from Sask
Drives: 2010 1SSRS M6 Black of course! Join Date: Aug 2009
I just jack up the car from the middle frame bracket, put jackstands under each side and work away. Dont have ramps and this has always been an easy way for me.
Ah Ha.. I figured I wouldn't get caught behind the 8 ball. Loading a car up Sat. and want to make sure on the distance between the nose and the tires. Thanks for the replies
#6 |
![]() Drives: 2010 Black SS/RS Join Date: Jun 2009
I startle a ditch. LOL Honestly, it's the perfect depth and width to fit my truck and Camaro. Put some cardboard on the grass and I can crawl right under there.
#7 |
Sorry, straddle. #$% Spellcheck.
#8 |
I got a nice set of heavy duty gray plastic ones from walmart and they work great. Not sure how a ground effects kit would do but a normal car has no problem.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS IOM L99 Join Date: Jan 2010
#10 |
![]() Drives: 69Camaro,87IROC,96 SS,Z06&Stingray Join Date: Apr 2010
#11 |
bumper just clears the Autozone ramps(car's plastic guard rubs), even w/ a 1.5" drop...
#12 |
'69 Owned Since '79
Drives: '69 Z/28 LeMans Blue w/White Join Date: Oct 2008
#13 |
![]() Drives: 2017 Camaro SS Join Date: Oct 2009
I thought Bill Clinton was the Arkansas Creeper.
| DIY: Camaro Oil Change | adub4185 | Camaro DIY & HOW-TO instructions & discussions | 180 | 04-23-2014 07:11 PM |
| Oil Capacity LS3 | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 77 | 04-21-2014 11:19 PM |
| 3,000 Miles - No "Metal Shavings" - Anyone Else? | FNKNSTN | 5th Gen Camaro SS LS LT General Discussions | 48 | 10-06-2009 12:46 AM |
| Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 10:47 AM |
