![]() Drives: 2010 2ss w/rs&77 honda civc Join Date: Jun 2009
LSA VS. LS9?
Does onyone know if these are 2 completely different engines and if not what is it that makes the LS9 so F****ng awsome?
Retarded One-Legged Owl
Drives: 2010 Black Camaro 2SS Join Date: Oct 2008
As far as I'm aware, more of the internal components are beefed up in the LS9 and the supercharger is bigger...
Drives: 2SS/RS Join Date: Mar 2010
LS9 is a stronger engine.
![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: May 2009
Well it makes what, 70 more HP? I'm going guess it's a bunch of different things... heads, cam, stronger/forged rods, pistons, intake.
I am the Stig
Drives: Black w/ IOM stripe 1SS Join Date: Jan 2010
LS9 - forged internals (crank, rods), Supercharger is 2.3L
LSA - cast internals, Supercharger is 1.9L, and slightly less static compression ratio I hear (around 9:1, LS9 is slightly over 9) I believe their intercoolers are slightly different as well. Different compression suggests different heads because I think the block and bore/stroke are "shared". And with a different supercharger, you're probably lookin' at different cam and intake as well. EDIT: just found this too LSA Cam specs Valve Lift .480" intake / .480" exhaust Duration(@.050 in) 198 intake / 216 exhaust LS9 Cam specs Valve Lift .562" intake / .558" exhaust Duration(@.050 in) 211 intake / 230 exhaust
2010 Camaro - 1SS, Black w/ Orange stripes
#6 |
Blessed
Drives: 2013 Sonic RS MT Join Date: Dec 2007
LSA
http://www.gmperformanceparts.com/En...1708&engCat=ls LS9 http://www.gmperformanceparts.com/En...0199&engCat=ls
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
#7 |
I am the Stig
For interest sake haha
LS3 spec http://www.gmperformanceparts.com/En...1992&engCat=ls looks like you throw in a forged crank and a super charger and the LS3 would be on top of the LSA. On paper anyway
#8 |
Very good info thank you.
#9 |
Blessed
#10 | |
CaRaHoLiC
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp Join Date: Aug 2011
huh? |
#11 |
![]() ![]() ![]() Drives: 2000 Z28. 2010 1SS IMB. Join Date: Aug 2009
Wow that's a tiny cam in the LSA. I thought there would be more lift than that.
1990 RS = First Car -SOLD
2000 Z28 = SOLD 2010 1SS/RS = Mysstique Whipple Supercharger Dyno= 618hp 555tq at the wheels IMB Silver Stripes VIN#44025 Born: 9/9/09 Delivered: 9/28/09 |
#12 |
Fourmz
Drives: 2010 2SS/RS 1968 Firebird 1994 Z28 Join Date: Sep 2009
Also , I believe the LS9 is a dry sump whereas the LSA is a wet sump. I could be wrong though.
Black-in-Black/Blue out 2010 2SS/RS LS-3 -Magnacharger TVS2300,OD cog belt drive, 3.4" pulley, Janetty smooth idle blower cam,ID-850 injectors,ZL1 fuel pump,MSD boost a pump, ADM FPCM Janetty custom tune,Doug Thorley long tube headers, Corsa catback,C.A.I. Intake, Roto-Fab Big Gulp Scoop, Monster LT1/SC Clutch assembly,Eibach pro kit plus, BMR cradle/diff bushings, Barton Shifter,JRE 3.91 Eaton Tru-Trac rear diff,Barton Short Throw SHifter, Boss 339 20" wheels,Painted heritage grille, Sparks Restoration Inverted blue/black SS emblems, Seibon BB carbon fiber hood, ZL1 front bumper conversion.
#13 |
Holy revive old thread batman!
The LS9 is dry sump. It also has forged crank and rods, a different cam and valves/valve springs, oil cooled pistons, and a bigger supercharger. I'm taking my L99 and converting it to a mock LS9. LS9 cam and valve train and then in using the Edelbrock SC
2011 2SS/RS L99
2017 Chevy SS 1979 Z28 Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495 MY BUILD THREAD ![]() |
| The mighty LSA supercharged V8. | Mr. Wyndham | Camaro ZL1 Forum - ZL1 Specific Topics | 137 | 05-07-2011 11:05 PM |
| Will the Z28 engine be a version of the LSA and the LS9 combined? | OldJedi | Camaro ZL1 Forum - ZL1 Specific Topics | 15 | 04-06-2010 08:44 PM |
| LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue | 13F20 | 5th Gen Camaro SS LS LT General Discussions | 15 | 09-22-2008 05:35 PM |
| All this LS9, LSA, and DI Speculation. | Good53X | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 1 | 12-12-2007 03:42 PM |
