Old 06-20-2010, 09:55 PM   #1
pacecarguy
pacecarguy's Avatar
Drives: 2010 Indy 500 Pace Car
Trailering a 2010 Camaro SS
Hi, I'm used to trailering my Corvettes, need to go pick up a new ride I bought. What is the recommended way to trailer a car on a trailer? Are there factory slots in the frame or somewhere, or should I use axle straps? Any help would be appreciated.
Thanks.
pacecarguy is offline   Reply With Quote
Old 06-20-2010, 10:14 PM   #2
Camaro54
Camaro54's Avatar
Drives: Camaro SS2/RS orange/black stripes
I've never trailered my car but if I did I'd tie it down the same way they do on the dyno machines ( through the spokes for the wheels ). This way holds the car steady at 6000 rpm. Seems enough for hold the car for trailering. Just make sure you stretch out your tie off straps so they are pulled tight with the car in between and not straight down from each wheel which would still let the car rock. I hope you can picture what I'm saying.
Camaro54 is offline   Reply With Quote
Old 06-22-2010, 12:54 PM   #3
Russell James
Russell James's Avatar
Same way as your Vettes, there are oval slots on the bottom for shipping tie downs using T-hooks or J hooks in the slots.
When you get it, you'll see underneath where there is some reinforced areas (the steel is doubled up) with an oval hole for the hooks. Same areas where you would put a hoist lifting pad. They reinforced that area for hoist lifting and tow hooks.
Old 06-22-2010, 01:01 PM   #4
Freezy
Synergy Green Lantern
Freezy's Avatar
Drives: to win.
Done and Done
What he said Excellent detail!
Freezy is offline   Reply With Quote
Old 06-27-2010, 12:37 PM   #5
pacecarguy
pacecarguy's Avatar
Thanks. There was a dealer nearby that had a car on an elevated platform so I did get a good look today and I see what you mean. Thanks for the feedback.
Old 06-27-2010, 12:54 PM   #6
boatingbent
boatingbent's Avatar
Drives: 69 Pontiac Firebird
My car has like 3000 miles on the Odometer and like 6 or 7000 Trailer miles.....
I use J Hooks .....There is a cross beam pretty much right under the Engine where I put my J hooks then I cross them and Strap them to my D rings in the Trailer....
On the Back there is Oval holes right in front of the rear wheels where I hook my J Hook and again cross the 2 and Starp them to the rear D rings in the floor.....
Wish I had better pictures
1100, Ordered car May 22nd 09
2000, Order accepted by GM - 26 May 2009
3000, Order accepted by production control 5/27
3300, Order scheduled for production
3400, Order broadcast
3800, Order produced..2G1FT1EW4A9125913
Delivered to me July 28th
boatingbent is offline   Reply With Quote
Old 06-27-2010, 01:28 PM   #7
pacecarguy
pacecarguy's Avatar
Thanks.
Found the points in the front. In the rear, I see some on the lower A-arms, or are they along the sides of the car?
Old 06-27-2010, 01:54 PM   #8
boatingbent
look in front of the rear wheels (On the sides)
Old 06-27-2010, 01:55 PM   #9
pacecarguy
pacecarguy's Avatar
Great, thanks!
Old 06-27-2010, 01:56 PM   #10
Mr Twisty
Mr Twisty's Avatar
Open trailer I use tire or axle straps... Lets the car bounce over bumps and gives me a better ride. (open trailer only)
-- Benjamin Franklin
lib·er·ty
/ˈlibərdē/
noun
1.
Old 03-14-2011, 09:46 PM   #11
2010 Indy Pace Car
NCCOA Ch 1
Drives: 2010 Camaro 2SS/RS - Z4Z # 44
I'll be doing the same (trailer) when I head up to Indy for the Pace Car Reunion in May. Good topic.
2010 Indy Pace Car is offline   Reply With Quote
Old 03-15-2011, 11:50 PM   #12
Cully
Drives: 2011 1SS/RS Synergy Green Camaro
How do you get out if that car in the trailer? Must be like gumby.
Cully is offline   Reply With Quote
Old 03-16-2011, 02:28 AM   #13
Rockslam
The Noob
Rockslam's Avatar
Drives: 2006 QSM GTO
Really? They push the car into/onto the trailer. Or ride it out back there the whole way.
http://www.camaro5.com/forums/image.php?type=sigpic&userid=34286&dateline=130273  5644
Rockslam is offline   Reply With Quote
Old 03-16-2011, 08:27 AM   #14
boatingbent
Winch it in and winch it out
