![]() Drives: 2018 1LT RS V6 Nightfall Grey Join Date: Jun 2009
whistle while accelerating...help
I just installed a k&n cia and i'm getting a whistle while i accelerate, anyone else have this problem, if so is there a fix, sounds like i have a birds nest in my car!!
![]() ![]() ![]() ![]() ![]() Drives: 2010 IOM 2LT 334HP Join Date: Feb 2010
Thats normal. Its just your engine getting some fresh air.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ( . )( . ) Join Date: Feb 2010
i have the Injen, and i get that sound aroun 2k RPM, i really like it, it actually sounds like a turbo with no BOV
sounds horrible with my exhaust, not really a whine with the engine, just doesn't sound right.
It it all across the RPM range or at a certain RPM? Double check you're connections, make sure they are snug.
#6 |
![]() Drives: 2010 Camaro rs/ss inferno orange Join Date: Mar 2010
Go back and recheck all the connections are good and tight, might be the vent line to the valve cover. I have the K&N CAI also, with out any abnormal sounds. Usually a whistling sound is an air leak between the air filter and the engine.
HOT ROD SS MTH35115 |
#7 |
Yep, every CAI I have known does that. I have the Injen installed on mine and every time I floor it, it sounds like its whistling Dixie!!
#8 |
seems to be a certain rpm, i'm gonna re check, the only thing it could be is the small hose from the adapter, it's plastic screwed onto a brass fitting, hose didn't seem perfect but it looked good, i checked before i started it.
#9 |
Not if you have Longtubes like I do! LOL............I can't hear anything but the damn exhaust......LMFAO
Formerly owner of:
2012 2SS/RS Build Thread - Totaled by red light runner 2010 LT/RS Build Thread - Traded in for 2012 2SS 2007 Acura TSX 1992 Oldsmobile Achieva V6 1992 Mercury Sable Last edited by Blade; 06-22-2010 at 06:43 PM. |
#10 | |
#11 |
![]() Drives: 2010 Silver Ice Metallic Camaro LS Join Date: Feb 2010
yeah, they all whistle a bit, my k&n does it, my AFE intake did it on my 05 Hemi powered Ram.
#12 |
whistling coming from my typhoon as well when I step on the gas..
#13 | |
![]() ![]() Drives: 2006 White Corvette Convertible Join Date: Feb 2010
The Corvette is an animal.
#14 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 1LT RJT Join Date: Feb 2010
| Squeaky Rattling noise only when accelerating | woody | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 10 | 06-30-2014 07:29 PM |
| Whistle from the vent blower motor | Big_T | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 43 | 02-28-2012 11:07 AM |
| Steam Whistle Camaro | Main | Canada | 9 | 04-11-2011 04:38 PM |
| whistle sound from vents | tom692010 | 5th Gen Camaro SS LS LT General Discussions | 9 | 11-05-2009 12:07 PM |
| Scratchy whistle noise from shifter area | Alvin@PCMofNC | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 1 | 11-05-2009 11:46 AM |
