Old 06-25-2010, 11:07 AM   #1
TopSpeeder
Drives: 2011 CGM SS/RS/A6
Coolant additives worth it?
Are coolant additives worth the trouble or is it just a scam? Do water wetters make a noticable difference in less than highly modified engines or extreme conditions?
Which brand do you think is best?
2011 CGM/2SS/RS/A6
TopSpeeder is offline   Reply With Quote
Old 06-25-2010, 11:13 AM   #2
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
I use Redline Water Wetter in everything I own. Even the tuner put it in my SC cooling system.
When I do track days that require coolant to be drained, I run the Redline and water and the bike runs cooler than with coolant.
EDIT: I forgot to mention that you DO need some coolant to protect against corrosion. Especially with dissimilar metals. BUT, you should reduce the amount of coolant to approx 20-25% of the mix for the best results from the water wetter.
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 06-28-2010, 11:42 PM   #3
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
I used Royal Purples Purple Ice in my truck but couldn't see a big difference. Not that there wasn't I just didn't see it.
9/26/09 Took delivery!
Old 07-06-2010, 04:45 AM   #4
MiSTER
Drives: 2010 2SS CGM Camaro, 1988 6.6L IROC
Years ago, alot of my Buick Grandnational friends had me try using distilled water with RMI-25 only. Been using it ever since. It isn't glycol based so it's safe for the track. I've been using it in my track bike ever since as well.
Unlike Redline Water Wetter alone, RMI-25 is a corrosion inhibitor and actually cleans out your colling system. The cool thing about it (no pun intended) is that it's biodegradable.
http://rmisource.com/learn-more
http://www.turbobuick.com/forums/tur...-rmi-25-a.html
MiSTER is offline   Reply With Quote
Coolant leak (all of it!!) upstateny Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 14 08-16-2010 07:30 PM
Are the foam guns worth it? Blue Angel Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 91 05-29-2010 05:06 PM
FbodFather Meet in Ft Worth 3/10/10 SS-Eric USA - Texas 6 03-10-2010 03:53 PM
LS3 COOLANT TEMP DMAX Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 07-06-2009 10:41 PM
95 chevy cavalier z24, coolant light won't go off diddiyo General Automotive + Other Cars Discussion 3 06-26-2008 08:35 PM
