Old 06-25-2010, 01:16 PM   #1
monstertodd
monstertodd's Avatar
MTI racing hot spark plug wires
Hi,
I was wondering if any of the you fine Camaro folks here have experience with these plug wires? Notice any difference in performance? Any issues installing them, routing them, etc.?
Should I stay with the factory spark plugs, or go with something else? What do you recommend?
Thanks in advance......
Todd.
Old 06-26-2010, 07:48 AM   #2
monstertodd
No one has advice on spark plug wires?
Really????
Old 06-26-2010, 08:04 AM   #3
R1CH
R1CH's Avatar
Drives: 2010 CGM 2SS/RS 6M
From what I've read on here; the factory plug wires provide us with all we need.
R1CH is offline   Reply With Quote
Old 06-26-2010, 08:25 AM   #4
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
That's what I've read also
Fishdadddy is offline   Reply With Quote
Old 06-26-2010, 10:27 AM   #5
R1CH
R1CH's Avatar
Unless you are running a highly modified engine, then they are just for looks really.
Old 06-26-2010, 11:00 AM   #6
MTI Racing
MTI Racing's Avatar
Drives: 2010 Camaro SS
No, not really.
They are not just for "highly-modified engines". They provide benefits even on stock engines.
IN FACT: Heat causes electrical resistance, and that robs ignition energy.
The MTI Racing wires tolerate the underhood temps better by using protective heat sleeving and fire braiding to keep heat away from the conductor wire. When the heat is on, the MTI Racing wires keep on delivering full energy, day after day, after day, after day.
Factory wires...not so much
The MTI Racing wires are also easier to use with all header systems. They provide more clearance to the spark plug boot.
MTI Racing Hot Spark Wires
-Protective Heat Sleeving
-Fire Braiding over wire
-Provides more consistent ignition for all applications
-Better clearance to headers
-Enhances engine compartment appearance
-Even available in custom lengths (for variety of valve covers and coil relocation options)
Feel free to call us if you have any questions...
-Stephen
MTI Racing is offline   Reply With Quote
Old 09-26-2010, 09:40 PM   #7
alfie43
alfie43's Avatar
Drives: S/C 2SS/RS Camaro-6M-VicRed
Location: Alfie (Mariano) lives in Shelby Twp, Metro-Detroit
Send a message via ICQ to alfie43
Originally Posted by MTI Racing View Post
No, not really.
-Stephen
Stephen
Do the ignition wires simply "wiggle and pull" off both the spark plugs and coils? Thanks.
Alfie
alfie43 is offline   Reply With Quote
Old 09-26-2010, 10:01 PM   #8
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
Ohhhh me likey the red wires! Would look great with my VR baby!
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 09-27-2010, 12:11 AM   #9
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
Not to bash a vendor (MTI), but while those claims you are making can't be refuted, because they are all true, the difference is negligible and will not show up on a dyno, the road, the racetrack, or otherwise on a stock style setup. There simply isnt enough heat/wasted spark/needed magneto energy. The stock setup is extremely robust.
Ovenmitt is offline   Reply With Quote
Old 09-29-2010, 11:38 PM   #10
CamaroFTW
CamaroFTW's Avatar
Drives: 2010 Camaro 2SS/RS-Rally Yellow
Send a message via MSN to CamaroFTW
Originally Posted by alfie43 View Post
Stephen
Alfie
Alfie, I just had MTI make me custom yelllow cables and I love the way they turned out! Yes they just wiggle on and you hear a bit of a "pop" when they are snapped on. The driver side took like 5 minutes to change. The passenger side was a bit of a PITA and took me almost 1/2 hour trying to get to those hard to reach wires! Arms were a bit "beat up" but it was worth it! I did not buy these for more HP but for an equal quality or better cable than stock that looks alot better. Here are some pics of the cables (just installed tonight):
CamaroFTW is offline   Reply With Quote
Old 09-30-2010, 08:20 AM   #11
MTI Racing
MTI Racing's Avatar
Lookin' great!
Old 09-30-2010, 10:31 AM   #12
CamaroFTW
CamaroFTW's Avatar
Thanks and got you a
Hot air Intakes -By Kenne bell ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 66 02-08-2011 09:33 PM
List of Intakes that will work with the TVS-2300 MagnaCharger JJ2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 03-19-2010 03:11 AM
New Edition to MTI Racing "Six Shooter Shifter" MTI Racing V8 Bolt-Ons & Tunes 0 09-17-2009 02:31 PM
Tom Henry Racing Announces a Special Edition 2010 Camaro! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 72 04-30-2009 01:57 PM
