Old 06-27-2010, 12:48 AM   #1
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Smile Excessive bounce with Eibach?
Hey all!! I'm new here, originally from New York city now residing in North Carolina . Just wanted to introduce myself real quick.
I have Eibach springs and sway bars on my SS. I find that the ride is now "bouncy" and unsettled over uneven pavement. Anyone else get this unsettled "feeling"? I did not have my bump-stops cut. Could this be the issue?
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 06-27-2010, 02:27 AM   #2
monstertodd
monstertodd's Avatar
Are you in fact, THE Lex Luger, of WWF fame?
Old 06-27-2010, 08:53 AM   #3
lexlueger
lexlueger's Avatar
Eer.... no . I'm a bit more "tan" with lots more muscle.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 06-27-2010, 09:04 AM   #4
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Drives: 2SS/RS Oct 2009
I recently added Eibach springs, but not the sway bars.. I don't have any bounce. Seems to be a firmer ride. After i fitted them i took them around a not so good road, then to an area that has a bunch of rumble strips to get them grounded....So far have not felt any bounce
GET-TORQ custom CAM 223/243 LSA113, Full LS3 conversion, 3200 stall Multi-Disk TC from Circle-D, B&M Supercooler to cool that tranny down....1 7/8" Kooks Headers and High flowCats. MACH XL Catbacks. Eibach springs, R2C Performance CAI, powdercoated calipers, Footwell lighting in tune with dome lights, tints, ABL Lighting, ACS T3 ports and ACS Eagle T3 triple LED lighting kit. Heritage grill, Hex vents, ZL1 rockers, ZL1 Diffuser, Quad tips...the list keeps getting longer - whats next??
markmass is offline   Reply With Quote
Old 06-27-2010, 10:17 AM   #5
lexlueger
lexlueger's Avatar
I might be alone on this one : I have had tons of lowered vehicles, many with lower drops than the eibachs. Bad install maybe? Any suspensions guru's on this morning?
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 06-27-2010, 01:07 PM   #6
monstertodd
he he, lol.
I read in another thread, Apex Chase was saying that if you use lowering springs on stock dampers, if you go below 1.25" of drop, that the ride will become bouncy and unsettled. How low is your car? This is because once you lower the car past a certain point, the dampers become ineffective.
Old 06-27-2010, 03:08 PM   #7
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
I have Eibach springs and bars. Lowered the car 1 inch. I cut the bump stops 1 inch. No problems here and overall car rides much better with none of the traits you are describing. I also had to realign the front and rear of the car as the alignment goes out of spec's. Camber was the most out of spec. Good Luck.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 06-27-2010, 04:29 PM   #8
lexlueger
lexlueger's Avatar
Monster Todd : I only went 1 inch on the drop with the stock dampers. Got some good info on possible solution... stay tuned, lol.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 06-27-2010, 04:34 PM   #9
lexlueger
lexlueger's Avatar
Sack rat : The shop that did my drop did not cut my bump stops. I also did a full alignment after the drop. Cutting my bump stops next week, hopefully that resolves this issue.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 06-27-2010, 05:51 PM   #10
lexlueger
lexlueger's Avatar
Thanks for all the input fellas
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 06-28-2010, 03:26 AM   #11
monstertodd
Anytime!
Old 06-28-2010, 04:01 AM   #12
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
You should NOT cut your bump stops. It's not necessary for this kit, nor recommended. If it's that bad, the install may be a little off. Give it some time to get seated too.
[B]
Old 06-28-2010, 11:43 AM   #13
Camaro427
Drives: 2010 SS2 Camaro
There are several threads discussing centering the OE bushings. Dropping the Camaro can put a preload on a OE bushing, which can add to rebound rates
Camaro427 is offline   Reply With Quote
Old 06-28-2010, 03:36 PM   #14
JusticePete
Drives: Camaro Justice
You are correct. A substantial amount of the OP's bounce is coming from uneven preloads in the bushes.
Think of it this way. If you removed your lower front control arm and set it in a vice by clamping down hard on the steel ferule bonded to the rubber bush would it hold straight. The answer would be yes. Is the jaws grip the ferule as tight as the bolt on the car you can raise of lower the arm, but with resistance. When you release it, it will spring back to where it was before you twisted the rubber around the ferule. That is why bushes must be timed to ride height.
Take your car to the alignment shop. Have the tech loosen every rotational bolt / bush in the suspension. Drive the car SLOWLY and CAREFULLY around the lot with the bolts a couple of turns loose. Put it back on the alignment lift. Without taking any weight off the wheels, tighten all the bolts. All the bushes are now timed to your new lowered ride height.
Eibach Lowering Springs & Sway Bars @ Phastek Performance Jason@Phastek Suspension / Chassis / Brakes 0 01-29-2010 04:56 PM
Want to Lower Your Camaro? Step Inside! Eibach Springs and Sways Now Shipping! Kris@BMCPerformance Suspension / Chassis / Brakes 20 01-15-2010 10:09 PM
Eibach Lowering Springs and Sway Bars Now Shipping @ BMC Performance Kris@BMCPerformance Suspension / Chassis / Brakes 6 11-14-2009 09:34 PM
Eibach Pro-Plus Kit SPECIAL!!!!!!!!!!!!!! SupremacyCustoms Suspension / Chassis / Brakes 0 11-03-2009 02:57 PM
