Old 06-28-2010, 01:51 AM   #1
Z Madness
Z Madness's Avatar
Drives: 2010, 2000, 1971 Camaros
Line Lock Brake Control Question with TCS
I just installed the Line Lock that I purchases from Spohn.net (TCI). Has anyone had any issues with the TCS system going nuts when activating the Line Lock? I have three lights going off and the system says "service stabillitrac". After I turn off the car for a few minutes, all of the lights/warning go away. Just want to check if this is normal for everyone. This happens both with TCS ON and OFF. Thanks for your help. (I have a M6 V-6)
Z Madness is offline   Reply With Quote
Old 06-28-2010, 10:36 AM   #2
goodiem18
Drives: 2010 Camaro 2SS RS Inferno Orange
I dont have a line lock on my car but I do know when I dyno'd mine last week that all my traction control lights came on, it told me to service the stabilitrac, and all that other stuff.
I dont think the computer liked the fact that the rear tires were spinning and the rest of the car was locked down...I drove off the dyno and about a mile down the road all the warnings and lights went off and everything was back to normal.
Hope this helps....
goodiem18 is offline   Reply With Quote
Old 06-28-2010, 11:12 AM   #3
ADM PERFORMANCE
Drives: Anything I want
NORMAL
ADM PERFORMANCE is offline   Reply With Quote
Old 06-28-2010, 02:43 PM   #4
Z Madness
Z Madness's Avatar
Thanks to both of you. I guess not many are using line lock. ADM, I will check your website for MODS!
Old 06-28-2010, 02:47 PM   #5
fieldgoal00
Drives: 2010 Chevy Camaro 2SS/RS
stabilitrack senses that the rear wheels are moving at a much higher rate and the front wheels aren't moving at all and that's why it goes off. Same thing happens on a dyno.
fieldgoal00 is offline   Reply With Quote
Old 06-28-2010, 05:44 PM   #6
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
That's normal
Old 06-28-2010, 08:37 PM   #7
flyby
Drives: 2010 Silver SS
Yeah, normal and will reset itself after a "normal" run
flyby is offline   Reply With Quote
Old 06-29-2010, 07:30 PM   #8
Eric Baker
Drives: Black/Black 2SS/RS 6M
Does it do this with a brakestand too?
Eric Baker is offline   Reply With Quote
Old 06-29-2010, 07:37 PM   #9
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Anytime the sensors realize that your rears are spinning different than the fronts it will send the code. When code is sent it will also turn traction control off even if you had left in on. Pain in the ass cause you have to clear it out to get the speedo to show up in the DIC again so just make a habit of hitting the thumb switch on the turn signal to cycle back thru and clear the DIC error message. Remember not to run your line locks longer than 30 seconds to avoid damage to the solinoid. Also note that this control is not part of the engine ecm so you cant just tune it down or off. Bummer for sure.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 06-29-2010, 08:32 PM   #10
chevyss
SS/RS
Drives: 2010 SS/RS IOM w/blk stripes A6
I installed a SJM line lock on my Camaro and works great. Yes, the lights come on and it says service stabiltrac. Goes off after a while. Sure is fun.
chevyss is offline   Reply With Quote
Old 06-29-2010, 08:41 PM   #11
Z Madness
Z Madness's Avatar
Thanks, really appreciate the comment and suggestions.
Old 06-29-2010, 08:51 PM   #12
ADM PERFORMANCE
We make our own inhouse,not for retail. Sorry!
Old 06-29-2010, 09:12 PM   #13
Z Madness
Z Madness's Avatar
No prob. I was going to look since you were so helpful but I guess you don't have much for the V-6 crowd. Thanks a lot, though. Always appreciate vendor comments.
Old 03-12-2011, 06:02 PM   #14
chiel
chiel's Avatar
Drives: 1959 p/u and s/c ls3 th400
So i put in a linelock and 3 lights go on and "service stabilitrac"
So this summer if i go dragracing i use the linelock and then i cant use launchcontrol because these lights are turned on?
Which fuse is for this tractionsystem so i can take the power away (whit a relay) when i use the linelock or is there a better way?
I gonna try the "thumb switch on the turnsignal" tomorrow.
chiel is offline   Reply With Quote
Line Lock? moiy1983 Suspension / Brakes / Chassis 2 06-09-2010 09:32 AM
***STILLEN Camaro SS Brake System Upgrade Package*** Team STILLEN Suspension / Brakes / Chassis 14 03-16-2010 02:00 PM
2010 Camaro Line Lock ( linelock) completed! SJM Wheels and Tires Talk Sponsored by The Tire Rack 15 12-27-2009 08:45 PM
Anyone hear a brake lock up? camaro2011 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 12-15-2009 09:27 AM
Camaro LS Question: Traction Control Beau Tie 5th Gen Camaro SS LS LT General Discussions 2 10-07-2008 01:24 PM
