Banned
Drives: Car Join Date: Jan 2010
GFX KIT ON FOR 4 DAYS AND ITS FALLING APART
Like my title states I had my gfx kit on for 4 days and I'm already having issues:( My front splitter is the issue. On the left side my double side tape is not stickin. My splitter right now is unhooked from the left side. Any idea on how to fix it?
When they install these they are supposed to let them sit without driving them for 24 hours. If they don't they fall apart.
2012 ZL1 #1278
2010 2nd Place Fastest 4 5th Gen LSX Shootout 2011 2nd Place Fastest 4 5th Gen LSX Shootout |
Banned
That's the issue I believe. They installed it charged me for 3 hours of labor and called me back your car is ready:( The double sided tape on the left side is hanging on by a thread its all broken away:( I trust my dealer and the mechanic because they installed everything else on the camaro exhaust, grille, subs, tailz, rockers you name it.
I would take it back in and tell them that it is unacceptable.
Banned
#6 |
Drives: 2010 Camaro Join Date: Feb 2010
After I had mine painted by my body shop I told them about the issues that people where having with the nose piece. They put extra rivets in where ever possible to insure that it would not fail. Even my salesman suggested that I don't use their body shop and look elsewhere. The dealership credited me the $$ for the dealer install that I opted out of.
#7 | |
Banned
I always have bad luck with double-sided tape. I had a sct bodykit on my 03 Grand AM GT and my rocker panels kept on falling off because of the double sided tape.:(
#8 |
![]() ![]() ![]() ![]() ![]() Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
i have installed a couple sets and they turned out fine,, also make sure they pulled the front bumper cover off and used the rivets to support the center front,,, lots of people are just trying to use the tape with no rivets and they are falling apart.
#9 |
![]() Drives: 05/07 Chevy's Join Date: Aug 2009
#10 |
Banned
Update
Sooo my right side is falling off now:( I went back to the dealership this morning and talked to the service manager! I'm taking my car back on Thursday morning at 8:00am and hopefully going to get something fixed:(
#11 |
Banned
Another Update
Sooo I took my car in this morning and they put more double sided tape on well this time they put double layers. I guess I'm going to try out that for awhile if it doesn't work they told me to come back and they are going to install some plastic rivets. Sooo I'm hoping it will do the trick
#12 |
Banned
Sooo
Guess what came un loose this morning the double sided tape:( just on one side. Sooo the dealer installed two plastic rivets one on each side. They found black ones so they are not noticable. With my two rivets I should see no fallin off
#13 | |
Voice Of The Voiceless
#14 |
![]() Drives: 2010 2SS/RS Join Date: Jul 2010
Do you have the part number of the redesigned SS piece? My SS Front GFX fell off because the dealer failed to install the rivets. I would sure prefer the dealer reinstalling this redesigned piece using brackets like the base GFX.
