Old 07-05-2010, 11:32 PM   #1
evilbeef54
tail lights for u
evilbeef54's Avatar
Drives: Bumble Bee 2010 2SS/RS
battery in the trunk, great idea, however...
Forgot to put a non electrically powered opener outside the trunk, great move chevy, lol. So I disconnected the battery since I thought I was shipping out for a few months, plans changed so tonight I go to hook the battery so I can drive to work in the morning, and that's when it hits me... how the hell do I get the trunk open, no electrical power means the door button and remote obviously won't work, time to open the rear seat and crawl into the trunk to hit the emergency release. Which would wrk if you don't have subs mounted directly in the way, lol. Note to file, next time don't shut the trunk all the way.
1972 Camaro 350/Muncie M22 - SOLD
1986 Camaro RS - R.I.P.
1994 Camaro Z28 - SOLD
2010 Camaro 2SS/RS RY M6- LOVIN' it
Kooks LT's & HFC's, Flowmaster Single chamber mufflers, C.A.I. Intake, ADM Scoop, Rotofab w/w relocate
Semper Paratus
You have to go out You don't have to come back!!!
evilbeef54 is offline   Reply With Quote
Old 07-05-2010, 11:47 PM   #2
Z Madness
Z Madness's Avatar
Drives: 2010, 2000, 1971 Camaros
You could "jump" another battery, from another car or a spare. Just hook it up to the positive and negative in engine bay and should be able to "pop" the trunk.
Z Madness is offline   Reply With Quote
Old 07-05-2010, 11:59 PM   #3
evilbeef54
tail lights for u
evilbeef54's Avatar
Hmmm, I like that idea, I'll keep that in mind for next time, I have a bettery charger right here that would work
Semper Paratus
Old 07-06-2010, 07:00 AM   #4
pastohio
Drives: Indy Pace Car
When I put my car to sleep at times, I just don't push closed on the trunk lid, I leave it unopened....sounds good ????!!!!!!
pastohio is offline   Reply With Quote
Old 07-06-2010, 08:37 AM   #5
Number 3
Hail to the King baby!
Number 3's Avatar
Sorry, but you answered your own question.
Did you expect GM to come up with an answer for the few that put subs in?
There are two good things that come from the battery in the trunk, one better front to rear weight bias and two, it takes the battery from a hot environment, which batteries hate.
The only answer would be a key cylinder in the trunk, but those have been pretty much eliminated in the era of RKE.
Definitely an issue if you've blocked the rear seat pass through.
Old 07-06-2010, 08:42 AM   #6
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Cigarette lighter port jumper cables?
Rope to the front for the inside trunk release?
-Mark
Old 07-06-2010, 09:31 AM   #7
oachalon
Drives: 2010 Camaro 1SS
You have a positive term and a body ground under the hood, so like mentioned before all you have to do is unlock your door with the key pop the hood, hook up a power source (jumper, battery box, charger) and you should get enough power to run your accessories
Get yourself a trickle charger/battery saver and hook it up under the hood then you wont have to disconnect your battery. That is what i use for winter time.
oachalon is offline   Reply With Quote
Old 07-06-2010, 08:47 PM   #8
evilbeef54
tail lights for u
evilbeef54's Avatar
yeah, believe me, as a racer, i am a big fan of the battery in the trunk, i just didnt realize that there was no key hole until it was too late, lol. every other car i have had that had keyless entry and trunk release also had a manual trunk release that wasnt IN THE FREAKIN TRUNK!!! lol, i just thought it was humorous and may keep others from having the same issue
Semper Paratus
Old 07-06-2010, 09:41 PM   #9
fastdoc436
Drives: 2010 2SS/RS,35thLE/SS,30thAE/SS
This is exactly what I do for winter storage and if I won't be driving the car for over a week or two due to work/vacation. I use Battery Tender Plus.
fastdoc436 is offline   Reply With Quote
Old 07-07-2010, 11:41 AM   #10
oachalon
I think mine is the battery tender plus as well. Havent looked at it since end of winter.
Old 07-07-2010, 11:44 AM   #11
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
Battery Tender FTW!!!!!!!!!!!!!!
Old 07-07-2010, 11:55 AM   #12
Old 02-10-2012, 04:59 PM   #13
Mike E
Drives: 2011 camaro v6 con . IMO,
On the 11 convert theirs a manual lock cyl @ left rear upper seat back. Is it the same
Mike E is offline   Reply With Quote
Old 02-10-2012, 05:07 PM   #14
midnighter
Drives: nothing
+1
2010 Camaro PRODUCT SAFETY RECALL: Positive Battery Cable Rerouting mcernik Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 171 01-08-2011 02:09 AM
Modesto or Monterey Run April 11th gabraddock California Meets and Events 179 04-15-2010 08:46 PM
Just thought of a great idea to get a 2010 for cheap. Opinions? SZOTSTA24 Camaro Price | Ordering | Tracking | Dealers Discussions 24 03-21-2010 09:12 PM
Drama with a dead battery CTBranson 5th Gen Camaro SS LS LT General Discussions 43 03-20-2010 12:29 PM
Positive Battery Cable issue (not near starter) shiftz33 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 08-12-2009 04:20 PM
