Old 07-06-2010, 08:09 PM   #1
crzycicada
crzycicada's Avatar
Drives: 2SS/RS/LS3
Stubborn Water Spots
After researching all of the threads and even contacting Sal Zaino himself, I still have many water spots on my Camaro.
Here's the breakdown of what I've tried:
1. CamaroScotty's recommendation of 50/50 vinegar to water solution
2. Z-7 car wash
3. Z-7 car wash and Z-18 (clay bar)
4. 100% vinegar (recommended by Sal)
5. Meguiar's Swirl X 2.0 (saw that someone here recommended it; it sort of worked and got out about half of the water spots on one panel that I tested it on but it seemed to have caused a lot of swirls in the paint. Ironic I know; maybe it's an illusion or something else?)
Any other thoughts? Based on Sal's recommendation, after trying everything he's recommended, his last tidbit of info was to use Z-AIO, in which he said, "If the above still fails, then use Zaino Z-AIO by hand, using very light pressure. This should do the trick."
It's on order now but thought I'd ask other experts like Moose and other forum members what has worked for them for tough (and I mean very very tough) water spots that have probably etched into the clear coat.
Order date: 7/17/09
3000 TPW: 8/17/09
3400 status on 8/11/09
3800: 8/21/09
4200: 8/24/09 on rail car ETTX850796
5000/6000: 9/2/09
crzycicada is offline   Reply With Quote
Old 07-06-2010, 08:18 PM   #2
2LTRS
Detailing Connoisseur
2LTRS's Avatar
Drives: 2010 Rally Yellow 2LT RS
Sounds like its etched into the paint to me. Can you feel the marks with your fingernail? Like an indent in the paint? If so its definitely etched into the paint.
So assuming it is etched, you can use Zaino's Z-PC with a porter cable (PC) to polish out the etching. If you don't have a porter cable 7424, you may want to take it to a *quality* detailer who specializes in paint correction.
2LTRS is offline   Reply With Quote
Old 07-06-2010, 09:29 PM   #3
DetailAddict
Drives: .
pics?
DetailAddict is offline   Reply With Quote
Old 07-06-2010, 09:38 PM   #4
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
somoene offers a mountable filter that removed the chemical that causes water spots. i forgot who sells it
SSTony is offline   Reply With Quote
Old 07-06-2010, 09:41 PM   #5
DetailAddict
Drives: .
you mean this thing?
Old 07-06-2010, 09:44 PM   #6
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
I use Meguiar's Quick Wax occasionally. You spray it on while the car is wet. Then dry and polish it off. Works well, but I don't have spots etched into the clear coat.
The only time I've had spots is when I've left soap/water on the car too long.
1968 Camaro Convertible LS1, T56
ckaram is offline   Reply With Quote
Old 07-06-2010, 09:50 PM   #7
crzycicada
crzycicada's Avatar
Drives: 2SS/RS/LS3
It's not quite like an indent in the paint. It's more like a splattered bug and when I run my fingernail across it, the water spot edges start to come off. The issue is that there are too many to do this to each one of them! I've looked into Z-PC and I was surprised Sal didn't recommend that. That might be the last resort if Z-AIO doesn't work. I'm definitely calling him if Z-AIO doesn't work! Thanks for the response and if you have any other ideas, please let me know!
Order date: 7/17/09
3000 TPW: 8/17/09
3800: 8/21/09
5000/6000: 9/2/09
Old 07-06-2010, 09:51 PM   #8
crzycicada
crzycicada's Avatar
Drives: 2SS/RS/LS3
Originally Posted by DetailAddict View Post
pics?
It got too late to take some pics outside. Will do tomorrow! I'm not sure that they will come out in a pic though because of the glare but I'll give it a shot.
Order date: 7/17/09
3000 TPW: 8/17/09
3800: 8/21/09
5000/6000: 9/2/09
Old 07-06-2010, 10:04 PM   #9
crzycicada
crzycicada's Avatar
Drives: 2SS/RS/LS3
I guess I forgot to mention how these darn water spots got to be left on my car. I was taking a cross country trip (Houston to Orlando last month) and spent the night in Lake Charles, LA at a casino. The casino unfortunately is next to some sort of plant (chemical, concrete, power, oil, ???) so when I woke in the morning to drive out, the car was covered in these water spots. I went straight to a car wash but it was obviously too late so whatever was in the water that was exhausted by the plant, it obviously contained some sort of mineral/chemical a la acid rain. For the past month I've been trying all the things listed above multiple times.
I also forgot to mention that these water spots are obviously on the black rally stripes as well so any suggestions to get those out would be appreciated as well (not sure if a different product is needed or whatnot).
My lessons learned from this trip are:
1. bring a spray bottle of vinegar/water and some towels in preparation for this again
2. don't be surprised that after driving such a long way that there will be lots of rock chips in the car (I have lots of tiny ones!)
3. the gulf coast other than Texas must not have a lot of Camaros because I felt like a celebrity with tons of people coming up to me whenever I would make a pit stop!
Order date: 7/17/09
3000 TPW: 8/17/09
3800: 8/21/09
5000/6000: 9/2/09
Old 07-06-2010, 10:56 PM   #10
GRSCAMARO
RS 10 SS
GRSCAMARO's Avatar
Drives: 2010 ABM RS/2SS L99
I just fixed my car this weekend.....
I was on a business trip and parked my car at the airport next to a shrub. Much to my surprise, the hood was covered with large filthy water spots when I returned 6 days later. I believe the shrubs were watered with reclaimed water.
I tried washing the car and tried using Zaino detailing spray but the spots were too deep. Finally I broke out the Porter-Cable and the Zaino Z-PC. The white applicator took out most of the spots after an hour of buffing but I had to switch to the more agressive orange disk with the Porter-Cable on 6 to remove the spots. End result the hood looks better than new!
Best 1/4 Mile Run: 11/20/2010 SGMP 13.299 @ 106 mph (2.05s 60ft)
Mods to Date:
Painted Rally Stripes by Body's by Doug
ABM Painted Splash Guards & Engine Cover
Tinted Windows by Sunbusters
CAI Kit by Cold Air Inductions (installed at C5FestI)
GRSCAMARO is offline   Reply With Quote
Old 07-06-2010, 11:03 PM   #11
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Now I maybe missing something here, but I saw no mention of clay... did you claybar?
Old 07-07-2010, 01:00 AM   #12
BdNflnc
Drives: 1995 Z28
The thing I never see ANYBODY ever realize or mention is the fact that these spots are created from mineral deposits in the water, left behind after the water evaporates. So if you have water spots, just lightly wipe them with a damp cloth. You are reintroducing water the the deposits, and will lift them right off. Simple fix... and its free!
BdNflnc is offline   Reply With Quote
Old 07-07-2010, 07:19 AM   #13
GRSCAMARO
RS 10 SS
GRSCAMARO's Avatar
Clay did nothing for the spots on mine. I did not try the vinegar trick.
Unless the car was just washed, you might scratch the car by wiping off the water spots. I wiped the morning dew off of mine at the C5F with a micro fiber towel and put fine scratches all over the car. I guess the ABM shows every flaw.
Mods to Date:
Old 07-07-2010, 05:02 PM   #14
Viral
Viral's Avatar
Drives: 2010 2SS/RS LS3
Like Dylan, I was about to suggest a claybar. I'm surprised to hear that didn't help. Well, sounds like Sal is working his way up the abrasive ladder, trying to have you use the least abrasive at a time. I'd do as he suggests and try Z-AIO first and if that doesn't work, Z-PC on an orange pad WILL remove the water spots, if you have to go that aggressive.
2010 Camaro 2SS/RS ( Corsa Catback Exhaust | Vararam | VMAX TB | Custom Tune - 386HP/383TQ)
Viral is offline   Reply With Quote
Terrible water spots on fire truck. help! Zaino? LosingReality Off-topic Discussions 13 05-05-2010 08:19 PM
Car Washing.................... Angelo@Autopia Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 5 03-08-2010 07:48 PM
Water spots on plastic SirZoltan Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 6 11-20-2009 09:23 PM
How to dry your Black Camaro without water spots gzartman Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 55 10-27-2009 04:46 AM
Mr Clean Auto Dry & waterblade? Matt'sSS Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 3 08-17-2009 01:19 PM
