Old 11-06-2008, 07:17 PM   #1
kozzmo49
Drives: 2010 camaro ss rs
tuning
Im new to this whole tuning thing. I hear that we can tune the top speed, the horsepower etc.. is this safe for the car? and also where do i go to get this kinda stuff done, or can i just buy a couple hundred dollar little plug in computer and do it myslef. pls help me explain this stuff lol
kozzmo49 is offline   Reply With Quote
Old 11-06-2008, 08:01 PM   #2
Chewy
My boredom isn't safe
Chewy's Avatar
Drives: 2010 SS Camaro
Send a message via AIM to Chewy Send a message via MSN to Chewy
tuning mostly involves adjusting the A/F ratio amongst a few other things. like autos sometimes get different shift points. its usually safe unless u get some insane tune (which i've never heard of happening) most people get a tune to compliment mods like intake/exhaust. downside is a lot of the time you'll lose some MPGs - but thats to be expected when your squeezing out more power.
i'm not too sure where to get muscle cars tuned, but i believe its easier than the german cars. there are also A/F controllers that u can plug into either ECU or wide-band O2 sensor and manually tweak and adjust your A/F ratio yourself.
Chewy is offline   Reply With Quote
Old 11-06-2008, 10:29 PM   #3
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
You tune after doing mods. Plain and simple.
Headers, intake, exhaust, cam, what have you......let the motor breath better. You adjust the amount of fuel and spark accordingly. Also lets you change redline, line pressure, knock retard, and a couple hundred other things. Generally these things are done by datalogging on the street and/or on a dyno.
Don't do it yourself, especially if you don't know what you're doing. You can still piss off/blow up your motor with a plug in Predator or Hypertech. It's been done. A dyno tune at a reputable shop will run you 4-500 dollars and you get a little graph showing you what you made to the wheels to frame and put on your wall to boot, if you're one of those guys. Reputable shops hire reputable tuners, and they've been doing this for years.
And you don't tune top speed. You can remove a limiter, but that's it. You want to change the top speed, either make more power or change your rear gear.
What is this, CorvetteForum Lite?
LSxJunkie is offline   Reply With Quote
Old 11-06-2008, 10:34 PM   #4
LS3SSRS
LS3SSRS's Avatar
Drives: 2010 IBM SS/RS
tuning makes a world of a difference. i got my silverado tuned, 2000, 5.3L ext. cab by http://gowheatley.com. He asked me what i wanted, i got it tuned for 91 octane, firmer/quicker shift points, top speed limiter removed, i also listed my mods...cold air, throttle body spacer, catback exhaust..etc... Anyways, point is, i get more power, AND better mpg if i can keep my foot off the pedal....
i don't know if i would tune the camaro thou... if you're in for warranty work, the dealer can now tell with their computer if the ecu has been flashed. :(
**sold** 2010 2SS/RS, 6spd manual, imperial blue metallic w/black leather
Blacked out tail/signal lights, 5% rear tint, 20% sides, Dynomax Bullet mufflers, Barton short throw shifter, Clear Image offroad downpipes
LS3SSRS is offline   Reply With Quote
Old 11-06-2008, 11:02 PM   #5
TheMadHatter99
Kept the Faith
TheMadHatter99's Avatar
Drives: '10 Camaro 2SS/RS CGM
I was under the impression that we'd established modding your car does not void any warranty unless said mod is deemed to be the cause of any defect you want fixed under the warranty.
TheMadHatter99 is offline   Reply With Quote
Old 11-06-2008, 11:37 PM   #6
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
You guys must be new at dis game.
Old 11-07-2008, 12:04 AM   #7
crippled
Drives: MB clk430 02
you can unplug the negative on your battery for like 30mins should reset your computer to auto tune, but its still not like getting it tuned at a shop
crippled is offline   Reply With Quote
Old 11-07-2008, 01:01 AM   #8
divvichild
Corvette Owner
divvichild's Avatar
Drives: '06 MS Corvette Coupe
Wouldn't that just return it back to default settings?
divvichild is offline   Reply With Quote
Old 11-07-2008, 05:57 AM   #9
TheMadHatter99
Kept the Faith
Seriously? I've been around these parts almost since the site started (a lurker for a long while).
We've had quite a few threads regarding modding vs warranty considerations and a few of our more legal-minded members have provided links to federal laws regarding just this. If I recall correctly, the jist of the law was that the mod has to be directly responsible for a defect in order for it to not be covered under the factory warranty.
That isn't to say that dealers won't blame just about anything they can on a mod, but technically that's the law.
Feel free to chime in if this is incorrect.
Old 11-07-2008, 06:13 AM   #10
jimbo57
jimbo57's Avatar
Drives: 2010 SS, '06 EQUINOX, 72 MONTE
i worked in dealers for years. law or no law, if a guy brings a car in that has been modified, perhaps resulting in a parts failure, we were'nt likely to go out of our way to cover it.
jimbo57 is offline   Reply With Quote
Old 11-07-2008, 06:15 AM   #11
jimbo57
jimbo57's Avatar
as an addendum, GM's zone office would have to OK/deny replacement, AFTER your car has left the dealer.
Old 11-07-2008, 06:22 AM   #12
playhard67
come to poppa
playhard67's Avatar
Drives: 67RS,09 Harley FLHX
I've read other posts...that technically this is correct, but if the dealer brings in the GM rep and the rep says your mod caused the failure, then you will have to prove otherwise. If lawyers get involved, it'll cost you more to fight it, then to just pay for the repair.
What i learned from these other posts - if you're not prepared to pay for the warranty repairs, then don't mod your car.
Cancelled the 2010 SS/RS (for now) and bought this instead (2009 Harley FLHX)
playhard67 is offline   Reply With Quote
Tuning the Camaro Exhaust note Mr. Wyndham 5th Gen Camaro SS LS LT General Discussions 74 05-15-2012 09:57 AM
Blue Devil KILLER74Z28 General Automotive + Other Cars Discussion 71 02-20-2009 02:03 AM
Tuning LS3 vs L99 Evilangel Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 10-30-2008 10:22 AM
Tuning the L99 Lifted07Sierra Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 09-02-2008 10:28 AM
Best LS Blower/Turbo Systems. TFord 4th Generation Camaros 6 06-18-2008 05:25 PM
