Old 07-10-2010, 11:31 PM   #1
Number_9
Number_9's Avatar
Drives: 2010 2SS/RS L99
ADM TRANS COOLER - YES!
Got my ADM Trans Cooler installed today... Quick and painless... And running 40-50 degrees cooler easily now. Awesome! Cant wait for the track on Friday! Mwa-hahahaha...
Any one else have this installed yet? What kind of temp changes are you seeing?
Number_9 is offline   Reply With Quote
Old 07-11-2010, 01:23 AM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I can appreciate lower temps but what good does it do your tranny fluid to run at 140 instead of 180? If we were tracking our cars, i'd see the need but for a everyday car or even a drag stip car, is it really needed?
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 07-11-2010, 07:10 AM   #3
ADM PERFORMANCE
Drives: Anything I want
Most are seeing well over 200 degrees.
The factory cooler is built into the Radiator,Heat is transfered from the radiator to the trans fluid causing the trans temps to be at or above the engine temps.We have eliminated the fluid running through radiator and directed it directly to our new cooler that is mounted in front of the a/c condenser...first in line to get cool.
Most of our testing was done in the 100+ degree heat
ADM PERFORMANCE is offline   Reply With Quote
Old 07-11-2010, 07:36 AM   #4
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
Anyone with mods to their car, or a stall converter should install a trans cooler. They're too easy to install, for the amount of wear and heat problems they save you from having with your auto trans.
Ovenmitt is offline   Reply With Quote
Old 07-11-2010, 08:56 AM   #5
Apex Paul
Apex Paul's Avatar
Drives: Wagon Queen Family Truckster
Even on a car without any mods a trans cooler ca have some benefits. Don't be looking for gains at the track, but running cooler temps are going to help prolong the life of the transmission.
At the track a nice even temp will help perhaps with consistency, but don't think there will any reduction in ET from a trans cooler.
Apex Paul is offline   Reply With Quote
Old 07-11-2010, 09:04 AM   #6
Melson
Melson's Avatar
Drives: Wild Cherry
Adam,
had it done about 3 weeks ago and now it runs less than 180 all the time.....
2010 RJT 2SS/RS L99 CAMARO
ARH 1 7/8" LT HEADERS W/ HF CATS
MAGNAFLOW 3" COMP EXHAUST
ADM PERFORMANCE CAI
ADM PERFORMANCE CUSTOM TUNE
ADM PERFORMANCE PORTED THROTTLE BODY
ADM PERFORMANCE TRANS COOLER
3.45 GEARS
BMR TRAILING ARMS
Melson is offline   Reply With Quote
Old 07-11-2010, 10:48 AM   #7
JS
JS's Avatar
Drives: 2010 Camaro SS
I live in PA and its hot here, very hot
My trans runs at 190 MAX which is pefect, running a trans at 140 to 150 in not good.
Now with a verter in the car and over 220 temps then YES a trans cooler is a must.
I will see how mine runs once I add the Pro-torque 2800 to my car then make a decision on a trans cooler..
Your kit looks very nice
SOLD
2010 Camaro 1SS/A6
12.59@111.31
Magnaflow Magnapack Axleback & Resonated X-Pipe/OBX LT Headers/Airaid Cold Air Kit/Injection Connection Tuned
JS is offline   Reply With Quote
Old 07-11-2010, 01:00 PM   #8
DanD
DanD's Avatar
Drives: 6 camaros
Did the front bumper cover have to come off?? I just don't feel like pulling it off.
2010 IOM RS/SS TVS2300, cam, stall, headers
2002 Z28 427
2002 SSLE Convertible
1968 383 Camaro
1968 327 Camaro Convertible
1967 RS 327
1967 Pro-Tour LS3 in progress
DanD is offline   Reply With Quote
Old 07-11-2010, 02:14 PM   #9
Jekyll-N-Hyde
I put the FU back in FUN
Jekyll-N-Hyde's Avatar
Drives: 1969 SS 396 , 2010 Camaro SS
Adam you couldnt have said it any better Andy installed one on mine when I did my Cammed Ls3 Conversion
WOW I love it
BEST MOD NO DOUBT DONE TO THIS CAR
Now im not scared to punch on her like I used to since heating the tranny up now is no longer an issue.
with 100degree temps the warmest she gets is 180 normal is below 180
This should HELP Very much with the 3200 stall converter im curious what she will run temp wise after the stall.
Jekyll-N-Hyde is offline   Reply With Quote
Old 07-11-2010, 06:50 PM   #10
Number_9
Number_9's Avatar
Yes.
Old 07-11-2010, 08:01 PM   #11
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
DanD - this is the perfect time to do both the tranny cooler and install a Heritage Grill. This is assuming you like the heritage. Anyway just some food for thought. Good Luck
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 07-11-2010, 10:36 PM   #12
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
my trans runs 130-150*f with the yank ss3200, the b&m cooler with fan i put on my camaro is the same one i have used on a couple of my cars and they all ran in this temp range with no problems,,, unless you are running the car in the winter,, you really cant over cool an automatic trans
also hook a scan tool to your can and monitor the tcm data, you will see the actuall trans temp data is more accurate than the gauges gm gave us.
Old 07-11-2010, 11:09 PM   #13
JS
JS's Avatar
And by looking at your chart I AM EXACLTY RIGHT..170 to 215 is perfect...
Your not implying 140 temps are what u want for the trans?
SOLD
2010 Camaro 1SS/A6
12.59@111.31
Old 07-11-2010, 11:45 PM   #14
camaro1
camaro1's Avatar
why??,, cooler is better, look at the chart
adm performance, trans cooler
ADM Performance Trans Cooler Melson USA - Texas 18 06-23-2010 04:17 PM
ADM Performance "Street" & "Race" intakes in stock and ready to ship! FREE SHIPPING!! Apex Motorsports V8 Bolt-Ons & Tunes 23 05-22-2010 08:14 AM
ADM Performance intakes in stock and ready to ship at Apex Motorsports! Apex Motorsports V8 Bolt-Ons & Tunes 7 04-25-2010 07:14 PM
Aftermarket cooling The_Stache Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 01-11-2010 06:40 AM
