![]() Drives: S10 283 V8,Jimmy 4wd 4dr bk/bk Join Date: Dec 2008
friend is goin to watkins glen, upgrade brakes?
so a friend is planning on taking his 2ss to watkins glen soon.
what should he do with the brakes. the manual says to go to DOT 5, will the stock brakes and rotors hold up? |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
How long are the sessions?
I did 4 - 20 minute sessions on California Speedway's road course with my stock breaks and fluid with ZERO issues. I have well over 20k miles on my stock pads with the time at the track. I'll have to replace them here in the next 2-3k miles. (about 25k) Hope this helps.
#3 | |
![]() Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28 Join Date: May 2009
From a google search: Always refer to vehicle owner's manual for what the manufacturer recommends or warns against. As a rule, vehicles equipped with antilock brakes (ABS) should not use DOT 5 brake fluid. DOT 5 brake fluid is silicone based. DOT 3 (standard) and DOT 4 (heavy-duty) are glycol-based. It can be distinguished from conventional brake fluids by its purple color (which comes from a dye). Silicone does not absorb moisture. DOT 5 brake fluid does not become contaminated with moisture over time as conventional DOT 3 and 4 brake fluids do. Silicone is also chemically inert, nontoxic and won't damage paint like conventional brake fluid. It also has a higher boiling point. Because of this, it is often marketed as a premium "lifetime" brake fluid. It is often used to preserve brake systems in antique vehicles and those that sit for long periods of time between use. DOT 5 silicone brake fluid is also very expensive (costing four to five times as much as ordinary brake fluid), and it won't mix with glyco- based brake fluid (creating concern over sludging if all old fluid isn't removed when a system is refilled with silicone). Silicone also has slightly different physical properties and compressibility, making it unsuitable for ABS systems calibrated to work with DOT 3 or 4 brake fluid.
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected - Sold 1968 Camaro - Sold 2019 Corvette Grand Sport ![]() |
#4 | |
Drives: Several Join Date: Nov 2009
If he does fully enjoy high speed driving, the OE brake pads will probably ruin his day. I would suggest a track pad (maybe a Ferodo DS3000 for starters -- at least up front). Make sure he beds them in before he goes, removes them and then installs them at the track. It would be best to change back to the stock pads before leaving, but I know many people just want to get home first. Track pads do not work nearly as well cold, which is why they are not recommended for street use. Chris |
Drives: Camaro Justice Join Date: Jun 2007
I use Cobalt Friction XR1 compound front and XR3 compound rear. I love CF pads because they require absolutely no bedding and have 90 or 95% stopping power dead cold. Just put them on and go. I run them street and track except when the weather gets cold. There is no binder in the pad material. If the pads are wet and they freeze the pad will crumble. So one set of track pads and rotors and the OE pads and rotors for cold weather work great.
The CF XR1 and XR3 pads are a huge upgrade to the OE pads. They are so good I should probably put a Pedders part number on them and start selling them.
| ZL1 / CTS-V Brakes | JusticePete | Suspension / Brakes / Chassis | 584 | 10-14-2021 09:33 AM |
| The Elimination Game: Camaro colors | Ant | Cosmetics and Lighting Modification Discussions | 2739 | 04-10-2014 09:37 AM |
| UPGRADE BREMBO BRAKES | MirandaBuilt | Suspension / Chassis / Brakes | 1 | 02-26-2010 09:07 AM |
| EWB Electronic Wedge Brakes | KILLER74Z28 | General Automotive + Other Cars Discussion | 10 | 11-13-2006 12:12 AM |
