Old 11-12-2008, 10:37 AM   #1
2001ragtop
2001ragtop's Avatar
Drives: V8 american car
Is camaro gas pedal drive-by-wire
Does anyone know if the new Camaro has a drive-by-wire gas pedal (like the new mustang GT)? I would assume if the CTS or GTO has that, then the Camaro has it. I don't think I like that.
2001ragtop is offline   Reply With Quote
Old 11-12-2008, 10:42 AM   #2
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
LS3s and the 3.x DEI motors are drive by wire.
What is this, CorvetteForum Lite?
LSxJunkie is offline   Reply With Quote
Old 11-12-2008, 10:48 AM   #3
TomServo
Drives: 2007 Z06
It's been on the vette since 1997. GM has it dialed in real nice. I never had any issues on my 2 C5's and 2 C6's.
TomServo is offline   Reply With Quote
Old 11-12-2008, 10:54 AM   #4
Mr Twisty
Mr Twisty's Avatar
The technology was a little buggy in the early 90's, It's good enough now if no one told you, you wouldn't know it. You may have already driven a 'by wire' car and didn't realize it.
-- Benjamin Franklin
lib·er·ty
/ˈlibərdē/
noun
1.
Old 11-12-2008, 10:56 AM   #5
The_Blur
Moderator
The_Blur's Avatar
Expect all new cars to be drive-by-wire.
warn 145:159 ban
Old 11-12-2008, 11:09 AM   #6
Urthman
Future Camaro Owner
Drives: 2010 Jeep Wrangler Sahara 4dr
Maybe I'm wrong...but I thought the "old" way was called drive-by-wire...of course I don't know what the "new" way is called if that is the case...It makes more sense to me that if the gas pedal in most new cars is essentially a potentiometer telling a computer how to manipulate the engine it wouldn't be called "drive-by-wire".
Like I said...I might be wrong...in fact, probably am. Can someone clarify this for me?
Urthman is offline   Reply With Quote
Old 11-12-2008, 11:17 AM   #7
The_Blur
Moderator
The_Blur's Avatar
I think it is an ever-improving system, much like comparing early blowers that stick out of muscle car hoods to new blowers that are much more efficient. Before drive-by-wire, there was a mechanical system. Drive-by-wire improves as research and development finds better ways to tune engines to use fuel and feel more responsive to the driver. Someone else, I'm sure, will be able to elaborate more on the specifics of both mechanical and electronic methods of driving.
warn 145:159 ban
Old 11-12-2008, 11:24 AM   #8
Mr Twisty
Mr Twisty's Avatar
The old way was 'throttle cable' like on your lawn mower. Throttle by wire is basically like you describe, a throttle position sensor at the pedal feeding signal to the ECU and it feeding signal to an electric motor opening and closing the throttle body.
That's also how they can integrate systems like traction control, the ECU calculates how much throttle you need without roasting tires, not how much throttle your foot wants.
I guess the correct term would be "throttle by electronic signal" rather than cable
lib·er·ty
/ˈlibərdē/
noun
1.
Old 11-12-2008, 11:32 AM   #9
CDBiker220
Drives: 98 camaro z28
Will it be better than on the newer mustangs? I worked at a ford dealership, and if you suddenly stabbed the gas and let off, the car wouldnt even respond to the pedal motion till a half second after you had let off the gas. It wasnt terrible but always annoyed me, it wasnt as responsive as my 98 z28, that has a cable. I havent driven any newer GM cars lately though to compare the mustang too.
CDBiker220 is offline   Reply With Quote
Old 11-12-2008, 11:36 AM   #10
The_Blur
Moderator
The_Blur's Avatar
That won't be a problem. GM wants you to feel in control of the car. They've worked harder on this car than any in recent memory. I can't imagine them overlooking such a simple problem.
warn 145:159 ban
Old 11-12-2008, 11:38 AM   #11
Stevo
Drives: Camaro 2010 SIM
I wonder if this will mean that when you hit the gas and the brake at the same time the gas will shut off? I find it hard to trail-brake and drift with that!!
Stevo is offline   Reply With Quote
Old 11-12-2008, 11:42 AM   #12
The_Blur
Moderator
The_Blur's Avatar
How much drifting are you really going to be doing?
warn 145:159 ban
Old 11-12-2008, 11:47 AM   #13
xl1200r
Drives: 2006 Cobalt SS/SC
This is probably more a result of the time it takes for the fuel charge you just dumped into the engine at idle to take effect. These sensors and servos work pretty quick.
xl1200r is offline   Reply With Quote
Old 11-12-2008, 11:48 AM   #14
Stevo
None if I can't get control with my outta control ways.
Automobilemag.com: 2010 Chevrolet Camaro - Q&A Scotsman 5th Gen Camaro SS LS LT General Discussions 23 10-12-2008 01:13 AM
'ello & mt 'Camaro: First Drive' ls1vert 5th Gen Camaro SS LS LT General Discussions 7 09-24-2008 10:31 PM
What is your dream drive in the NEW CAMARO? CamaroScotty Off-topic Discussions 13 07-28-2008 11:19 PM
