Old 07-19-2010, 02:15 PM   #1
mikeSS
mikeSS's Avatar
Drives: 2015 c7
is it possible that bolt ons can cause the ecu to change
not totally sure what the cars computer is call. maybe ecu?
now people talk about how a cat back or CAI will not void your warranty.
i understand that.. but i have heard that with like a CAI or exhaust people have reported the ecu changes by it self trying to adjust to the new mods...
and a dealership will read the ecu and see its not stock. and give them trouble for it...
Old 07-19-2010, 02:34 PM   #2
jtzako
Drives: 2010 IBM Camaro SS
I doubt anything the computer auto-adjusts for would be a problem. Its the 'tunes' that the dealer could give you grief for.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 07-19-2010, 04:46 PM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
You don't have a grasp of what the PCM can do. The PCM is made to make changes to conditions and changes. If your filter gets very dirty, ambient temps are extremely hot/cold, etc. the PCM will adapt. If it didn't, your car would run like crap for 5+ months out of the year. What the dealership reads is the actual tune indentification numbers. If the OEM indentification numbers are still there, it's read as the OEM tune and there's no problem there. If your car dropped a piston, they will look to see what caused the problem. They'll look at your PCM data to see is was caused by a lean condition. If it was, they'll look to see if any aftermarket parts could have caused the lean condition. If your fuel trims were way out of whack from a poorly built CAI, that could be the problem and might void the warranty. So saying a CAI will absolutely NOT void your warranty is false. Most CAI companies spend lots of time and $$ making sure their CAI's don't affect FT's negatively to prevent their products from cause this problem. The ones that do make large changes to the FT's will usually say it's a tune ONLY CAI.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
AIRAID Intake System For 2010 3.6L V6 Camaro Airaid Filters Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 362 02-26-2010 09:35 PM
ECU Flash Counter? BlackinBlack Tuning / Diagnostics -- engine and transmission 67 11-16-2009 02:13 AM
The proof that i'm changing. Tactical Z Off-topic Discussions 64 02-10-2009 11:38 PM
Obama Climate Change Advisers Holdren and Lubchenco Are Told Global Warming Is Over bigralph Off-topic Discussions 15 02-06-2009 08:07 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
