Old 07-24-2010, 11:35 AM   #1
GrinderSS
Drives: IOM 2SS/RS
Solved my drone problem!
I installed the JBA competition 3" exhaust on my SS. It sounded great, but had a bad drone at 1800 RPM. I searched high and low for a solution and found a reference on a Mustang forum to these: http://www.carchemistry.com/shop/ind...duct_list&c=11
I was skeptical at first, but figured I'd try them before replacing the exhaust (yes, the drone was that bad). To my amazement they worked, they toned down the exhaust just enough to eliminate 90% of the drone. Also, they cut down on the exhaust popping quite a bit.
If you're wrestling with drone, you've got to try those inserts.
They're sold on Summit and Jegs sites too.
GrinderSS is offline   Reply With Quote
Old 07-24-2010, 12:13 PM   #2
Blastin' Metallica
Blastin' Metallica's Avatar
Drives: 2010 Black 2SS/RS, 2005 Mag Red C6
Do these inserts go into the exhaut tube? Wouldn't they restrict air flow?
Blastin' Metallica is offline   Reply With Quote
Old 07-24-2010, 01:03 PM   #3
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
That explains the 90% reduction....
brantley847 is offline   Reply With Quote
Old 07-24-2010, 04:25 PM   #4
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Those are nothing new. They are just baffles and yes they might add some restriction.
9/26/09 Took delivery!
Old 07-24-2010, 08:26 PM   #5
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
Question
Where did you install them in the exhaust? Which part of the pipe? How do they stay put and not slide out or further into the pipe you put them in?
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 07-24-2010, 08:30 PM   #6
skar
skar's Avatar
Drives: 2010 2SSRS headers/CAI/tune/corsa,
Don't understand
skar is offline   Reply With Quote
Old 07-24-2010, 08:38 PM   #7
GrinderSS
Drives: IOM 2SS/RS
Yes, they go into the exhaust tube and do restrict the exhaust flow. But the restricted flow is minimal and with a 3" exhaust and straight through mufflers I wasn't too worried about it.
Old 07-24-2010, 08:43 PM   #8
GrinderSS
Drives: IOM 2SS/RS
I put them in the anterior portion of the mid pipes just before the axle pipes. I tack welded them inside the pipes, but you can pop rivet them in place too.
Old 07-24-2010, 08:45 PM   #9
Wilburbeest
Think With Your Dipstick!
Wilburbeest's Avatar
Drives: 1997 Camaro Z28
Wouldn't a couple bullet style mufflers before the main mufflers do the same thing without restricting flow?
- Willy
1997 Camaro Z28 (LT1/T56): K&N CAI | Kooks 1 3/4" LTs | 3" Custom Duals | UMI LCAs w/ relocation brackets | UMI adj. panhard bar | UMI adj. torque arm | Koni SA shocks | Strano Springs | Ram Powergrip clutch | Pro 5.0 shifter | skip shift eliminator kit | WS6 Store rotors | Hawk HPS pads
Wilburbeest is offline   Reply With Quote
Old 07-24-2010, 08:46 PM   #10
BigRed585Lbs
Drives: Sierra and Tahoe
Sometimes it's hard to get 'em to think outside the box.
BigRed585Lbs is offline   Reply With Quote
Old 07-24-2010, 08:47 PM   #11
GrinderSS
Drives: IOM 2SS/RS
Originally Posted by IndeedSS View Post
Might want to scan for KR. I had soemthing like that on my Impala SS (supercharged V6). No matter the tune or pulley I was getting 6 degrees of KR. Removed the restriction and the KR was gone.
I'm not sure what "KR" is, but it can't be worse than brain splitting drone. Maybe it's just me, but the car seemed to feel stronger with the inserts. A certain level of back pressure is needed. As for your V6, it could have been that the exhaust was already too restrictive. I doubt that's the case for those of us with headers and 3" exhaust pipes.
Old 07-24-2010, 08:50 PM   #12
GrinderSS
Drives: IOM 2SS/RS
I'm not sure, but there is not much room near the mid pipes to add anything that has a larger diameter. These inserts come with center caps that allow you to set the level of restriction you want. I used only one cap with a large hole in it, you could omit the caps all together.
Old 07-25-2010, 12:54 AM   #13
PHEOX
Drives: '06 Jeep Wrangler
Eh, I dislike. Some drone is to be expected and you just gotta get used to it.
PHEOX is offline   Reply With Quote
Old 07-25-2010, 12:30 PM   #14
Russell James
Russell James's Avatar
How large is the hole in the cap you used? I was thinking of adding resonators to a system I have, but this might look like an easier solution. My system after the LT's has a 3" X and mid pipes, then necks down to 2 1/2 at the rear axle. I could probably put something like that near the end of my 3" section instead of trying to splice in some resonators. I'm getting a little a drone in 6th between 70 and about 82ish mph.
USB Port problem w/ Ipod touch Arsenal11 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 8 06-03-2011 06:42 PM
Lesson Learned:Muffler Delete Drone JMROD Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 154 06-02-2011 04:43 PM
Found a problem with my camaro Agostino13 5th Gen Camaro SS LS LT General Discussions 19 04-27-2010 11:59 AM
Main Pulley out of Alignment. Problem? Die Zielscheibe Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 04-08-2010 03:51 PM
Problem with my v6 TonytheTiger 4th Generation Camaros 12 08-22-2008 02:34 PM
