Old 07-24-2010, 02:28 PM   #1
G.E.
G.E.'s Avatar
Drives: black on black twenty ten ss/rs
Difference in levels of cams
So there are three levels of cams for the camaro but they are all the same price. What's the difference?
I GOT MINE! Where's yours? :(
G.E. is offline   Reply With Quote
Old 07-24-2010, 03:09 PM   #2
SK360
Drives: 2005 Pontiac GTO
Their all names that companies make up.
They all come from the same source.
Pick a cam based on your wants with the car and goals, not a fancy name.
SK360 is offline   Reply With Quote
Old 07-24-2010, 03:11 PM   #3
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
the difference is how much fun your car will be. The higher the stage number, the more fun your car is. You decide on the fun limit on your car.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 07-24-2010, 03:50 PM   #4
ddavis
boostalicious
ddavis's Avatar
Drives: Blown Ls3
+1
Look at the specs not the names. A cam has to work well with your setup. One cam that might work well with one engine might not work as well with another.
ddavis is offline   Reply With Quote
Old 07-24-2010, 05:43 PM   #5
jordan 572
jordan 572's Avatar
Drives: none
And the more money you spend.
jordan 572 is offline   Reply With Quote
Old 07-24-2010, 06:01 PM   #6
danhr
BAMF SS
danhr's Avatar
how do you figure? valve springs cost about the same. tune costs the same. pushrods cost the same. cam shaft costs the same. and it's really hard to fit a cam big enough to max out the stock fuel system/injectors on a stock ls3... so you won't need injectors. and you can't fit a big enough cam into a stock ls3 to justify going to a solid roller.
Stock Longblock
Old 07-24-2010, 11:16 PM   #7
jordan 572
jordan 572's Avatar
Drives: none
you sound like your trying to drown me in all these fancy words. He is going to have to put in new valve springs if he does anyhthing more than a mild cam. And if he gets a big cam his power band will be all screwed up. He might make more power but at different rpm's. He is a teenage kid like me. Cams sound sick. I want one but i doubt he wants to send big money. Get a turbo.
Old 07-25-2010, 01:38 PM   #8
danhr
BAMF SS
danhr's Avatar
the words aren't fancy. Just common used words when referring to cam specs.
Any camshaft, if bigger than stock, will require new valve springs. even mild ones.
a full cam swap costs about $1,000 in parts... regardless of size, as long as it's on a stock bottom end motor. That's to include camshaft, valve springs, pushrods, and tune.
A turbo is going to run you over $7,000.
How is doing a cam swap referred to as "spending big money" and then you tell him to go turbo?
Might I suggest reading the cam sticky and maybe learning about cam shafts a little more?
Stock Longblock
Old 07-25-2010, 01:56 PM   #9
SK360
lol at not spending big money, so get a turbo.... I lol'd
Old 07-25-2010, 02:31 PM   #10
ddavis
boostalicious
ddavis's Avatar
Drives: Blown Ls3
Ive been enjoying the debate personally
Old 07-26-2010, 11:27 AM   #11
Jason 98 TA
Drives: Camaro
I agree 100% if someone names there camshafts in levels you should probably run! We engine dyno develop all of our camshafts looking to make power in specific areas & work hard to produce tons of data that we can use to help the customer meet his/her goals.
Jason 98 TA is offline   Reply With Quote
Did the deed and the difference is incredible c6vettepilot 5th Gen Camaro SS LS LT General Discussions 54 06-01-2010 11:12 AM
400 - 425 HP What's The Difference??? ParisTNDude 5th Gen Camaro SS LS LT General Discussions 20 04-16-2010 09:35 PM
CAI Sound Difference? kdbolt70 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 02-10-2010 08:25 PM
Sound difference with Cold Air Intake drtwo Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 01-03-2010 04:39 PM
For the L99 Hesh Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 38 01-11-2009 11:44 AM
