![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 IOM Camaro Join Date: Jul 2010
Does this Work?
I was browsing on ebay and came across this item. Now, I need some input: Does this work? It sounds logical. Is it safe?
http://cgi.ebay.com/ebaymotors/ws/eB...em=#vi-content |
BlackonBlack
Drives: 2010 Blk Camaro 1LT Join Date: Jul 2009
+80 HP is so ridiculous, maybe 10 if you're lucky
-Teskey |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Really Slow Join Date: Apr 2010
You should get it and do some real world testing for the camaro community
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
no way does that work
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
Those kits are notorious for using cheap plastic fans and coming apart and getting sucked into the motor... OUCH!
#6 |
I didn't think 80 hp was logical. I thought maybe 15hp?
![]() If I had $200 to spare right now, I would buy it just to see if it did anything, but my college tuition is coming up soon...
#7 |
#8 |
#9 | |
#10 |
I thought that it did happen to a member on here that posted the photos when it came apart.
#11 |
![]() ![]() ![]() ![]() ![]() Drives: 2006 Dodge Charger / 2SS IOM Join Date: Dec 2008
lol someone did put it on their camaro, and the fan blades broke and flew into the engine.
#12 |
![]() ![]() ![]() ![]() ![]() Drives: White M6 1LT RS Join Date: Mar 2010
You need CFM to make PSI... These fans don’t put out enough CFM...Especially at WOT. The motor will actually pull more air then the fan can provide thus creating a vacuum and hurting performance.
Long story short... Its worthless. However... if you need to vent a bathroom in a RV. They work great.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done! |
#13 |
White Lightnin
Drives: 2010 Summit White Camaro LS Join Date: May 2010
No its a scam...
You should buy my dilithiem crystals instead....you'll have warp power....LMAO! |
#14 |
Or Flux capacitors.
Next mod: Done! |
| Instrument Panel Dont Work On Hot Days... | gadgetguru4life | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 5 | 03-17-2011 04:15 PM |
| PWA "The Lounge" | DGthe3 | Off-topic Discussions | 143773 | 11-06-2010 11:00 AM |
| Staten Island Tuner - Excellent Work | talwell | USA - NY / NJ / PA | 4 | 07-09-2010 09:30 AM |
| Will the Corvette CAGS By-Pass work on the Camaro SS | TomServo | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 10 | 05-25-2009 08:08 PM |
| FAT32 40GB Portable HD Didn't Work | Embalmer | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 26 | 05-07-2009 12:09 AM |
