![]() Drives: 2013 Red Tint Metalic 2SS/RS Join Date: Sep 2009
I have a rear-entry garage and a sloped driveway. I can't get the garage to open when the house is on the right (passenger side) of the car, but opens fine from the left (driver side).
Is anyone having range issues with the built-in garage opener? Is there some sort of directional antenna inside I can move around to make it work better? I just can't stand having to pull up to the garage door to get it to open, plus wear on my clutch taking off on my steep driveway right at the door just to stop in the garage
Whipped
i have to be about 30' from my garage door before it will open.
![]() Drives: 2010 CGM 2SS/RS 6M Join Date: Feb 2010
Same here. But, I did notice that if I accidentally obscure the bulging area around the buttons when I press it that I have problems getting it to transmit the signal efficiently. I have to put my finger on and only on the button that I press without my hand getting in the way.
30' sounds about right for mine.
"Never argue with a fool, onlookers may not be able to tell the difference." - Mark Twain "Never argue with an idiot, they drag you down to their level and beat you with experience" - Unknown |
![]() ![]() ![]() ![]() Drives: 04 Ram 2500 & 2010 Camaro 2SS/RS Join Date: Feb 2010
#6 |
40-50';;with no obstructions
#7 |
I guess I'll try to get my fat hand out of the way. Funny thing is I get the 30 ft range when driving up on the drivers side maybe better, but driving up with the garage on the passenger side I have trouble. I have to get the car at an angle or facing the garage before it opens. I guess I'll see if the antenna on the opener can be moved or extended. Thanks for replying all!
#8 |
War Damn Eagle!!
Mine is the same way..I can sometimes get lucky when I first pull into the subdivision and get it to work, otherwise I have to wait until I'm about 30'-40' away before it will work...
VR 2SS RS M6
![]() Hot Wife, 2.8 KB, LS9 Cam, SPEC 3+ clutch, KW Variant 1 Coilovers, Pfadt F/R Sways, BMR Sub-Frame Connectors, BMR Tunnel Brace, LSR Performance Tri-Ax Shifter, BMR Trailing Arms, Kooks 1 7/8" LT Headers, MagnaFlow 3" Cat-Back Exhaust, Fesler Dual Gauge Pod w/AutoMeter A/F & Boost, ShowStopper UnderHood Accessories.....Tuned by John@APF = 627RWHP/542RWTQ ![]() |
#9 |
I'm getting better luck keeping my hand back and away from the hump by the airbag light. Thanks for the suggestion. It's still flakey if chevy is listening
#10 |
![]() Drives: 2010 RS LT2 Olympic White Join Date: Jul 2010
Try increasing the length of the antenna wire on the garage door opener. Tell you what, I'll try it on mine, and report back.
#11 |
my camaro does not have the garage door homelink buttons. Can I buy one from gm and install it on my own?
#12 |
![]() Drives: 2010 synergy green and a 1991 rs Join Date: Jun 2010
I would like to know as well thanks
#13 |
I can open my from about 300 ft. Do not know why you guys are having such a hard time. I do have a extra tall garage though, my door is 10 feet high.
#14 |
I'm in the ole 30' bunch. Its a royal pain in the kester. Wifes Nissan will open it at about 300', hope someone has found out whats up and will report it here.
| Tags |
| garage, homelink, opener |
