Old 07-27-2010, 02:55 PM   #1
jagssrsbeast
Drives: inferno orange ssrs
Wax, clay bars, polish???
What are clay bars for? and what is the difference between polish and wax?
jagssrsbeast is offline   Reply With Quote
Old 07-27-2010, 03:16 PM   #2
Moose
Moderator
Moose's Avatar
Drives: '99 Camaro SS #1392
Clay is for removing surface contaminants.
Wax will correct minor blemishes. It can also clean paint.
Polish will provide the better shine and durability IMO.
DO some browsing in this section, and you'll find alot of thoughts/opinions as well as experiences from using each of these items.
Ed
Moose is offline   Reply With Quote
Old 07-27-2010, 03:42 PM   #3
ud_lose
#34873
ud_lose's Avatar
Drives: '04 Ford F250 6.0L/'69 vette LS6
Clay is to clean the surface.
-Put your hand in a plastic bag and lightly rub over your paint. If you feel very
small bumps (like sand in the paint) you need to clay bar your surface.
Polish is to correct problems (minor scraches).
Wax is to seal/protect the surface against future problems.
ud_lose is offline   Reply With Quote
Old 07-27-2010, 03:43 PM   #4
2LTRS
Detailing Connoisseur
2LTRS's Avatar
Drives: 2010 Rally Yellow 2LT RS
Ed
Flip the wax and polish around and I'm on board.
[Most] Polish will remove / correct minor blemishes.
Wax will bring out the shine and protect the finish left by the polish.
2LTRS is offline   Reply With Quote
Old 07-27-2010, 04:18 PM   #5
Tallboy
Say "when"...
Tallboy's Avatar
Drives: 11 2LT
Ed
The opposite is true.
Tallboy is offline   Reply With Quote
Old 07-27-2010, 04:25 PM   #6
2LTRS
2LTRS's Avatar
Here comes a whole lot of confusion!
Old 07-27-2010, 05:55 PM   #7
jagssrsbeast
ok so then i use wax to make my car shine?
Old 07-27-2010, 06:04 PM   #8
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
No, you use polish, which cuts clearcoat to make it shine. You use wax to protect and seal that shine in.
Clay bar- pull off surface contaminents in paint that washing won't touch (road tar spots, paint transfer, stubborn water spots, etc.)
Polish- most people define as a way of cutting the clear coat by a tiny amount to reduce blemishes, swirls and minor scratches. This is where the shine comes from.
Wax- Seal everything up, protect from the elements, make your car a lot easier to clean.
[B]
Old 07-27-2010, 06:09 PM   #9
jagssrsbeast
so is this the order? clay bar, polish and then wax? could polishing or using the cly bar to much over time harm the paint?
Old 07-27-2010, 07:14 PM   #10
CamaroDreams07
Drives: Slow V6
Here's what you wanna do.
1. Wash with Dawn dish soap. This strips off any waxes you may have already had on the paint.
2. Don't bother drying, just pull into the garage and go to town with the clay bar.
3. Do another full wash using your car soap of choice
4. Dry thoroughly, polish until you achieve the results you want.
5. Wax the car.
6. Enjoy all the compliments!
To answer your question about harm- claying isn't abrasive so it doesn't remove clearcoat. It can cause some marring if you don't use enough lubrication or use it on a hot surface. Polishing does remove clearcoat, but you should be able to withstand at least 15-20 or so full polishes before any damage occurs. If you properly wash your car, you shouldn't need to polish your car any more than maybe once a year, because you shouldn't be getting many swirls. So that gets you 15 years or so until you have to worry about anything.
[B]
Old 07-27-2010, 07:17 PM   #11
2LTRS
2LTRS's Avatar
Correct.
Clay bar - no way
Polish - depends on what your using to apply it. If you use a rotary buffer to polish and your not experienced you could be on the road to the paint shop. If you use a safe dual action / random orbital buffer like the PC7424XP - its almost impossible to do any damage.
Old 07-27-2010, 07:25 PM   #12
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Well heck, you guys don't need me around here anymore... I'll just retire to the nearest tropical island and spend my remaining years carving coconuts into monkey sculptures with googly eyes.
Old 07-27-2010, 07:34 PM   #13
CaniacFan
CaniacFan's Avatar
Drives: '10 SS CGM #75,288, '14 Stingray
I'm coming with you, Dylan... We're getting pretty good on here, aren't we?? A year ago, I was still waiting on my car and reading so many threads on washing, waxing, polishing, detailing that my head was spinning..
Thankx for all you guys do for our Camaros..
CaniacFan is offline   Reply With Quote
Old 07-27-2010, 08:00 PM   #14
ud_lose
#34873
ud_lose's Avatar
Don't worry Dylan, your shine monkeys have this one.
Washing/Detailing for Newbies MRK III Z28 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 124 02-05-2024 10:55 PM
My experiences with Zaino, Meguiar’s NXT & Turtle Wax Ice on my 2010 Camaro renderinfo Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 59 01-13-2011 09:18 AM
Clay baring Mike2ss Wash/Wax/Detailing and Cosmetic Maintenance Parts 0 04-25-2010 11:02 PM
Products For Highend Enthusiasts Mr CLuTcH Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 0 01-28-2010 12:34 AM
CHAOS & MAYHEM.... Victoria Wax 2010 Chris@glimmerglass Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 0 11-05-2009 10:43 PM
