Old 07-28-2010, 06:35 PM   #1
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
2011 Mustang 5.0L vs 2010 Camaro SS Dyno Results
Hi guys,
We had a local customer drop by with his new 5.0L Mustang. Given you guys are going to run into one on the street, I thought I would show you a comparison of exactly what these cars make to the tires on a dyno.
Not that I would have to tell you, but the Camaro is shown by the green lines on the dyno.
Just for kicks we through in a 6.0L 2006 M6 Corvette as well, shown by the blue lines below.
Anthony @ LG Motorsports is offline   Reply With Quote
Old 07-28-2010, 06:41 PM   #2
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
Thanks for posting this info!!
Old 07-28-2010, 07:30 PM   #3
WadeWilson
How U Doin?
WadeWilson's Avatar
Drives: 2014 CTS-V Coupe
Yes, thanks for the info.
Old 07-28-2010, 09:14 PM   #4
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Just what most suspected. The 5.0 makes identical PEAK HP but makes it further up in the power band and the 6.2 is the tq monster.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 07-28-2010, 09:27 PM   #5
Cal 20112SS
Drives: 2019 C7 Stingray
I just looked into your LG prototype Super Pro LT headers. Very very nice setup!
Cal 20112SS is offline   Reply With Quote
Old 07-28-2010, 11:01 PM   #6
wbt
Drives: 2010 Challenger R/T;2011 Mustang GT
2 things missing here that the dyno does not factor for:
1. Less weight
2. Better gearing
wbt is offline   Reply With Quote
Old 07-28-2010, 11:07 PM   #7
more torque for the Camaro
Old 07-28-2010, 11:11 PM   #8
mr_desmo
Banned
Drives: beated up old mini austin
You guys have to remember the 5.0l is geared miles more aggressively then the ss even with the low 3.31 rear end (3.66 first gear-3.73 rear end for the 5.0 and 3.01 first gear for the camaro and 3.45 rear end PLUS the fact that the mustang 235/50/18 and 255/40/19 are 2 inch shorter tires then the ss giving an advantake of 0.24 gearing piting the 3.73 to 3.97)
A car mag (cant remember which one of the 3 us big ones) tested the max torque in gears....
-ss 1600 pounds of thrust
-5.0l 3.73 axle 2200 pounds
So the dyno dont tell the entire story and stock for stock even if less torquy engine .
The mustang is the torque monster of the 2 because even if it got 10 less tq its geared 30 % more aggressively!
mr_desmo is offline   Reply With Quote
Old 07-28-2010, 11:22 PM   #9
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
The dyno measures engine performance. The LS3 shows it to be stronger than the 5.0.
Put the same gearing in both cars. What motor do you want now?
Old 07-28-2010, 11:24 PM   #10
exactly
Old 07-28-2010, 11:28 PM   #11
mr_desmo
Banned
with a flash right now (base xct tuner flash ) they rev 7500rpm...i wouldnt do that to a STOCK ls3 that would be useless
Old 07-28-2010, 11:35 PM   #12
wbt
Not to turn this into another vs. thread....
Ford is doing almost the same thing with 1.2L less. That is impressive.
I have owned both the SS 6.2 M6 and the new 5.0 M6 and without a doubt my GT is faster regardless of what the dyno says. (I am talking bone stock 5.0 vs. my old 6.2 with a CAI and cat-back.)
Old 07-28-2010, 11:40 PM   #13
Jekyll-N-Hyde
I put the FU back in FUN
Jekyll-N-Hyde's Avatar
Drives: 1969 SS 396 , 2010 Camaro SS
Why cant we just admitt they are neck and neck Geeze.
I have driven both and imo they are neck and neck ! both very fast cars yes the mustang feels leighter however the torque on the camaro SCREWS excitement.
Both ford and gm made awsome cars.
Now mod those two cars and then we can see which car is stronger.
Jekyll-N-Hyde is offline   Reply With Quote
Old 07-28-2010, 11:42 PM   #14
BackinBlackSS/RS
Go Blue!!!!!
It is a little faster due to weight and gearing, but that is not what we are discussing. The dyno clearly shows the LS3 is more powerful. You put same gearing and same weight and you would see the LS3 walk away. I'm not saying the Camaro is better or faster, just that from just a motor standpoint, the LS3 has more power.
Latest Camaro Products - March 2010 Sean@Phastek V8 Bolt-Ons & Tunes 26 08-04-2010 05:42 PM
Magnaflow 2010 Camaro SS Systems JDP Motorsports V8 Bolt-Ons & Tunes 61 12-12-2009 01:13 PM
