Old 07-30-2010, 10:44 AM   #1
JANNETTYRACING
JANNETTYRACING's Avatar
JRE FUEL SYSTEM UPGRADE EDELBROCK SUPERCHARGERS
For all you Horsepower Junkies who are looking for more power than what the base Edelbrock system provides, we offer a fuel system upgrade to further improve an already great system.
While doing a 415 Stroker build on a car already equipped with an Edelbrock supercharger we were looking things over on Reassembly.
Looking at the fuel rails, (The Proverbial Light Bulb went on).
I have designed and built thousands of fuel systems over the last 30 years .
Looking at the fuel rails we discovered that the Passenger side Rear of the fuel rail is where the Feed is located, all of the fuel has to pass by all 4 injectors, then across the front of the engine then down the Drivers side Rail.
This pretty much Leaves Cylinders 5-7 Dead last to get fuel, in Higher than delivered HP applications this could be a concern.
There are a lot of Dynamics going on inside the fuel rails, every time a single injector opens is sends a shock wave back through the fuel, like throwing a rock in a Pond.
Also as the fuel is passing by injectors it is losing Pressure.
The Solution is the JRE Edelbrock Fuel system upgrade kit.
What it does, is Move the feed to the BACK of Both Rails and leaves the crossover in the front alone.
Now Both Rails will be fed evenly with fuel, and Cylinders 5-7 will be much Safer, again at Higher than delivered HP levels.
Even the Factory Rails are Fed From the Center to make fuel supply as even as possible to all injectors.
Also, the Injectors supplied with the Edelbrock are 52 lb hr.
We Recommend this upgrade along with 65 lb hr. injectors for anything over 550 RWHP.
Anyone with an Edelbrock Supercharger Looking to Make More Power should contact me for this fuel system Upgrade Kit.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 07-30-2010, 11:24 AM   #2
oachalon
Drives: 2010 Camaro 1SS
Ted, If we plan on running stock edelbrock pulley, with maybe a rotofab cai, solo hf cats, and a safe tune, is this something we should consider?
At what power should we consider making this upgrade?
oachalon is offline   Reply With Quote
Old 07-30-2010, 11:30 AM   #3
JANNETTYRACING
I truly believe this upgrade should be made on Edelbrock superchargers that are combined with other performance enhancing Products or higher than delivered Horsepower applications.
You can have the safest tune in the world, if you starve an injector you Lose a Piston.
Ted.
Old 07-30-2010, 11:38 AM   #4
tony1
tony1's Avatar
Drives: 2SS/RS Vortech/L99
Juat a question with the 65 lb hr. injectors from 52 .. will the same amount of Fuel when the injector opens? Would gas milage remain the same?
tony1 is offline   Reply With Quote
Old 07-30-2010, 11:45 AM   #5
Z_Rocks
Z_Rocks's Avatar
Drives: everyone crazy...
I hope Edelbrock is reading this thread or perhaps someone (who is using Edelbrock) would notify them as of this issue.
I'm sure many Edelbrock users are grateful to Ted for sharing this info.
Z_Rocks is offline   Reply With Quote
Old 07-30-2010, 11:46 AM   #6
JANNETTYRACING
If all you did was change the injectors the car would be extremely rich, because they flow more fuel at same pulse width.
The tune must carry the new injector flow info.
Ted.
Old 07-30-2010, 11:48 AM   #7
JANNETTYRACING
I have spoken with Rex and we both agree that the system is fine as delivered and this upgrade is for guys who want to take the Edelbrock to the next level.
Ted.
Old 07-30-2010, 06:31 PM   #8
B.Buster
B.Buster's Avatar
Drives: 2010 AquaBlue 2SS/RS
Ted,How much for this fuel upgrade kit ?
B.Buster is offline   Reply With Quote
Old 07-30-2010, 06:47 PM   #9
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
Old 07-30-2010, 07:16 PM   #10
victoryred1ss
victoryred1ss's Avatar
Drives: 2010 SS M6 2016 2SS A8
Does Magnacharger have the same fuel feed as Edelbrock or is it in the center like the factory setup?
TVS 2300 721RWHP 686RWTQ
Built by Me
Suspension done by JDP
Tune done by JRE
victoryred1ss is offline   Reply With Quote
Old 07-30-2010, 07:30 PM   #11
Busy_Boi
SoCal C5 Family Member
Busy_Boi's Avatar
Drives: RJT 2010 camaro 2SS
Send a message via Yahoo to Busy_Boi
I wish you have found this out 2 weeks ago I got an EDELBROCK SUPERCHARGER with the same setup and was having fuel problems. I just upgraded the fuel pump to a ZR1 vette pump and injectors to 72lb hr. injectors.
Busy_Boi is offline   Reply With Quote
Old 07-30-2010, 07:43 PM   #12
Z_Rocks
Z_Rocks's Avatar
I see what's keeping you "Busy"
Old 07-30-2010, 08:18 PM   #13
ADM PERFORMANCE
Drives: Anything I want
Good find Ted
ADM PERFORMANCE is offline   Reply With Quote
Old 07-31-2010, 07:29 AM   #14
JANNETTYRACING
We will have it listed on our site this coming week.
Ted.
Lets Talk About Extended Warranties for our 2010 Camaro's from the Dealership a Sec.. Black LS3 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 39 03-21-2010 11:38 AM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
"Green" Car of the Year Silverado General Automotive + Other Cars Discussion 17 11-28-2007 11:37 AM
