Old 08-01-2010, 12:53 PM   #1
bono83
bono83's Avatar
Drives: 1969 Chevelle, 2010 1LT
Brakes Lock Up after washing the Car
I have a 1Lt. Every time I wash the car, my brakes stick. I use only Zaino products to wash the car. I'm not using any kind of wheel cleaner, just the Zaino car wash. I thought it was the parking brake that was sticking so this time I washed the car and put it in the garage for 2 days but did not use the parking brake. When I went to back out of the garage today, the brakes were completely locked up. The car would not move in forward or reverse. I finally dumped the clutch in reverse at about 2000 RPM's and they broke free with a large jolt/clunk and a squealing of the rear tires. My wife came running out of the house into the garage thinking I just crashed the car because the clunk was so loud. After that, the car seemed to drive fine with no noise, vibration, or noticeable drag. This doesn't happen with my other cars using the same cleaning products.
Is anyone else experiencing this? Any ideas why the brakes are sticking? I'm wondering if it has to do with the the factory pads. Maybe they have a high metal component and the metal in the pads are rusting and attaching to the rotors?
Any input is greatly appreciated.
Order: 5/23/09 - Deposit given with order at dealer.
1100: 6/26/09 - Order placed by dealer - no allocation
2000: 8/15/09 - Accepted by GM.
2500: 8/18/09 - Preferenced.
3000: 8/18/09 - Accepted by Production Control.
3100: 9/9/09 - Available to Sequence.
3300: 9/9/09 - Scheduled for Production.
3400: 9/19/09 - Broadcast.
3800: 9/29/09 - Produced.
4000: 9/29/09 - Available to Ship.
4150: 9/29/09 - Original Invoice.
4200: 10/6/09 - Shipped.
5000: 10/13/09 - Delivered to Dealer.
6000: 10/13/09 - Delivered to Customer.
bono83 is offline   Reply With Quote
Old 08-01-2010, 06:17 PM   #2
cowjazz
Drives: 2010 2SS
It is normal. Drive your car around the block, and apply the brakes to get the rust off of your rotors.
cowjazz is offline   Reply With Quote
Old 08-01-2010, 06:41 PM   #3
rydahog
rydahog's Avatar
Drives: camaro ss
the metal rotors rust a lot on many cars, causing this situation.and it happens fast...maybe cover the wheels before you wash,.. good luck
rydahog is offline   Reply With Quote
Old 08-01-2010, 08:52 PM   #4
bi11ymc
"Silver Street"
bi11ymc's Avatar
Drives: 2010 2SS/RS L99
After washing, drive around the block using the brakes liberally to clean the water off them. Then put the car away.
Silver Street - 2010 Camaro 2SS/RS, SIM, Gray, Cyber Gray Rally Stripes, Polished Wheels, Automatic (L99) - 553 RWHP/510 RWTQ
CAI Inc., ARH LT Headers with Cats, Borla Touring Cat-Back; Pfadt Coil Overs, Sway Bars, End Links, and Trailing Arms; Comp Cams Blower Cam, Dual Springs, Push-Rods, and Lifters; GM LS2 Lifter Trays, 6.2 MLS Head Gaskets, Crank Bolt, and LS2 Front Cover; 3-Bolt Conversion Timing Gear, Katech C5R Timing Chain, ARP LS2/LS3 Head Bolt Kit, Melling Hi Volume Oil Pump, TVS 2300 Supercharger (Black); Build by Vengeance Racing; Custom Tune by Vengeance Racing
bi11ymc is offline   Reply With Quote
Old 08-01-2010, 09:30 PM   #5
JProberts
Drives: 2SS RJT RS/Sunroof
I have to disagree here, I'm no mechanic by any means but I have never had a problem like the one you described on this car in the 1 year I have been washing it......or any other car in my 20+ years of washing my cars.
It almost sounds like you have a caliber sticking or something.
I can't really say honestly but that can't be from just washing....not what you described. Take it to the dealer and have them look at it....still under warranty so nothing lost by taking it in.
Are your rotors hot when you wash the car and this happens?
Good luck
JProberts is offline   Reply With Quote
Old 08-01-2010, 09:51 PM   #6
Inspector 17
I love crepes
Inspector 17's Avatar
Drives: 2017 ZL1 NGM A10
This definitely doesn't sound normal. Squeaking brakes after getting wet or damp I understand, but a complete lockup just doesn't jive. Do you hear any noise (like dragging brakes) from your car under normal driving conditions? Perhaps the brakes are adjusted too closely to the rotors? I would definitely take it to the dealer.
Inspector 17 is offline   Reply With Quote
Old 08-01-2010, 10:26 PM   #7
JusticePete
Drives: Camaro Justice
The brakes sticking after washing or being put away wet is normal. I finally dumped the clutch in reverse at about 2000 RPM's doesn't sound normal. They should have come loose without having to do a mini drag launch. If everything seems to be normal, maybe they were just more rusty than normal after this particular wash.
Old 08-01-2010, 10:33 PM   #8
dannkimmel
dannkimmel's Avatar
Drives: 1lt,rjt,m6 &2004 harley
ever since i started washing my car inside the garage i have had the same problem.(not moveing car after wash)
metalic pads and rotors rust alittle and stick to each other.
i see no reason to be alarmed..like others said drive around the block to dry off the brakes before putting car away.
dannkimmel is offline   Reply With Quote
Old 08-02-2010, 10:38 AM   #9
bono83
bono83's Avatar
The problem is definitely related to washing. Before washing, there is no drag, grinding, pulsating or anything like it. After washing and parking the car in the garage is the only time they stick. This last time was by far the worst when they were completely locked. I didn't think I was going to be able to get the car to move they were stuck so bad. Once I get them freed up, everything goes back to normal.
Thanks to all of you for the input. I'm gonna have to try driving it after washing to make sure I get all the water and flash rust off the pads and rotors.
Old 08-03-2010, 01:49 PM   #10
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
I've never has any problems with brakes sticking after washing, and I always wash the wheels. The rust that can appear after the rotors get wet is normal, but if it causes more than a slight resistance, I'd be worried. I think you have a caliper problem as well.
I'd suggest that the next time this happens, try and determine which wheel is the problem and examine the caliper. This assumes that you can get the car jacked up, which may be a problem if its in the garage. I do not recommend the 2K clutch dump again...
Old 08-03-2010, 01:58 PM   #11
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
Mine stick after a wash too. I don't like driving at all after I wash. Since I usually cover it up when I'm done. (It is not a DD). I don't have to do much more than just take off in first gear in a normal fashion though. If you seriously had to give it that much of a launch, I would have your calipers checked out.
Fishdadddy is offline   Reply With Quote
Old 08-03-2010, 03:00 PM   #12
Rickerbucks
HP addict
Drives: 2 SS RS,
I have had my Brakes 'freeze' on a rare occassion after a wash. Again, i have always assumed it was a little occidization / rust. That being said....it does nto take very much to release them.
Yellow, Davenport 700, Pfadt coilovers and sway bar, Seibon CF hood, CF roof, custom CF trunk, Savini CF wheels, custom interior....you know what?....too much to list.
http://www.camaro5.com/forums/showthread.php?t=74691
Follow my 2013 One Lap Of America Blog here: https://www.facebook.com/#!/ShaunAnd...page_new_likes
2014 Jeep SRT 8 - stock
2010 Challenger SRT 8 - stock
2007 Charger SRT8 Super Bee - not stock at all.
Rickerbucks is offline   Reply With Quote
Old 08-03-2010, 03:05 PM   #13
Russell James
Russell James's Avatar
It's normal. Mine does it. Many cars with performance brakes (high metallic content pads) do it.
After washing buzz it up and down the driveway a few times applying the brakes hard. The rotors are bare iron. They will rust in seconds after getting wet.
When I picked up my car brand new from a dealer with 2 miles on it, it was stuck in place. They had washed it and then let it sit for a couple hours before I got there. Had to rev it a bit more and a pretty quick clutch release to break it free.
Old 08-03-2010, 03:37 PM   #14
motorhead
common problem, I've had many cars do the same.
Do you need a car alarm when you have Onstar? 2Muchmark 5th Gen Camaro SS LS LT General Discussions 45 02-19-2011 11:12 PM
What's considered a Muscle Car? SyN General Automotive + Other Cars Discussion 125 09-25-2010 01:04 AM
2010 Chevy Camaro SS Indy 500 Pace Car Drive linkwpc Camaro Photos | Spyshots | Video | Media Gallery 0 05-23-2009 10:47 PM
What makes a car a "tuner" car? Dentyneice General Automotive + Other Cars Discussion 8 05-11-2009 11:19 PM
