![]() Drives: 2011 Camaro 2SS Join Date: Jul 2010
Car feels BOGGY, HELP!!!!
So I am a proud owner of a summit white SS with automatic transmission. I have about 1,200 miles on it and for some reason, it feels like if I'm in drive mode, not using the paddle shifters, the car seems like it bogs driving around town, like it's in too high of a gear at low rpms. Does anyone else have this with their car. If I use the paddle shifters and shift and higher rpms rather than the computer then I don't seem to have this problem. Any suggestions would be greatly appreciated. Thanks in advance!!!
Booooosted.
Torque Management. Gotta love it.
![]() You might wanna try the fuse pull too. If you are starting fairly slowly from a stop, you start in second gear. Supposedly. |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Have you done the fuse pull? If not, read the sticky.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 RY 2SS with Custom Stripes Join Date: Mar 2009
Not to sure because I have the M6 but I know changing the gears to 3.73 would fix this issue.
#5 | |
Booooosted.
#6 |
What is the fuse pull? I was just reading some threads, do you guys think it is the AFM kicking in? Thanks
#7 | |
Booooosted.
Here is a link to the OP in the fuse pull thread. Not saying that's what's going on with your car but it's a possibility. http://www.camaro5.com/forums/showpo...90&postcount=1 |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
Running wide open your L99 should shift from 1-2 around 37mph. Then the
2-3 shift should come around 63 mph. There are also certain speeds your A6 might feel sluggish, especially in warm weather. One is down around 20-30 mph. If you miss the cut off for 1st gear (around 15-20 mph or so), 2nd gear can feel a little sluggish until you build some rpms. Another speed is around 52 - 60mph, At those speeds the A6 only drops to 3rd gear and it doesn't pull that hard. But if you mash the gas just below 50mph (40-50 mph zone), it pulls really hard because the transmission drops to 2nd gear. Around 45mph is the best speed for the A6. It will throw you back in the seat like crazy from that speed. So knowing your drop down speeds can be important. But if you're mashing the gas going 45mph and you're L99 doesn't haul axx, something wrong (fuse pull maybe). |
#9 |
![]() Drives: Black 2SS RS Auto Join Date: Aug 2009
Pete I had the same problem. when driving at slower speeds its like it needed to downshift, but at the track or highway speeds no problem. I have since modded the car and had it dynotuned. the trans tune and AFM delete eliminated the problem.
ps Fuse pull did not help.
Tune Time Performance built 416 C.I. 17/8" ARH & Exhaust, Airaid CAI, Vigilante T.C. 3600, Farks Supercars 6* Rollbar
Performanced tuned by Matt @ Tune Time Performance Toms River, NJ |
#10 |
![]() Drives: 2010 L99 2SS/RS Join Date: Apr 2010
Are you aware of the Sport Mode? I drive in that mode 99% of the time and the car feels quite responsive.
#11 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#12 |
![]() Drives: 2011 Camaro 1SS Join Date: Jul 2010
Hmm. Could be something stupid, but MANY people saw a huge difference after getting their first oil change. You're still at 1200 and I bet you haven't gotten it, so get one.
#13 |
I have an A6 and understand what you talking about.This service bulletin might help clear up the your thoughts of the AFM situation.
#06-06-05-001D: Information on Change in Exhaust Tone or Sound for Active Fuel Management (AFM) System Equipped Engines in Three or Four Cylinder Mode - (Feb 23, 2010) Subject: Information on Change in Exhaust Tone or Sound For Active Fuel Management (AFM) System Equipped Engines in Three or Four Cylinder Mode Models: 2007 Buick Rainier 2007-2009 Buick Allure (Canada Only), LaCrosse 2007 Chevrolet Monte Carlo 2007-2009 Chevrolet TrailBlazer 2007-2010 Chevrolet Avalanche, Impala, Silverado, Suburban, Tahoe 2010 Chevrolet Camaro 2007-2009 GMC Envoy Denali 2007-2010 GMC Sierra, Yukon, Yukon XL, Yukon Denali 2007-2009 Saab 9-7X with Active Fuel Management System Vortec® GEN IV 5.3L, 6.0L or 6.2L V8 Engine RPOs LMG, LC9, LY5, LH6, L76, L77, LFA, LZ1, LS4, L94, L99 or 3.9L V6 Engine RPOs LZ8, LZG Please Refer to GMVIS This bulletin is being revised to include 2010 models, additional RPOs and V6 engines with Active Fuel Management. Please discard Corporate Bulletin Number 06-06-05-001C (Section 06 -- Engine/Propulsion System). Some customers may comment on a change in the exhaust note or tone when an Active Fuel Management System equipped engine is in 3 or 4 cylinder mode. Some drivers may also notice a very slight vibration in either the accelerator pedal, floor pan and/or the steering wheel. This is a normal condition for Active Fuel Management System equipped vehicles and no repairs should be attempted. Customer Information on Active Fuel Management When the Active Fuel Management System is enabled, physical changes take place within the engine that allow it to run as a 3 or 4 cylinder motor with accompanying additional fuel savings. The change in exhaust tone is expected as all sound from the exhaust is the result of combustion in the engine. The ability to perceive these changes in sound are kept to very minimal levels as the Active Fuel Management System is only activated during steady state/near steady state driving or during coast down. In both of these situations, the load on the engine is minimal and general exhaust volume (sound) is low. You may give a copy of this bulletin to your customer. GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information. WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
JBA High Flow Cats, CAI Intake, Ported Throttle Body, Pfadt Sport Sway Bars, 12.57 @111.6 mph
#14 |
![]() Drives: 2019 C7 Stingray Join Date: Jul 2010
Same here. I only have 400 miles on it. I told the technician that it feels like it's skipping gears. They told me the L99's tend to do that at first but give it at least 2k miles and you should see a difference.
| From my first car to my dream car... | MissingtheMrs. | 5th Gen Camaro SS LS LT General Discussions | 21 | 04-11-2011 11:20 PM |
| What's considered a Muscle Car? | SyN | General Automotive + Other Cars Discussion | 125 | 09-25-2010 01:04 AM |
| Car Cover | domano 68 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 19 | 05-21-2010 10:51 PM |
| Drying after a rain? | KLow7777 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 7 | 02-17-2010 11:41 AM |
| What makes a car a "tuner" car? | Dentyneice | General Automotive + Other Cars Discussion | 8 | 05-11-2009 11:19 PM |
