Old 08-04-2010, 06:41 PM   #1
alfie43
alfie43's Avatar
Drives: S/C 2SS/RS Camaro-6M-VicRed
Location: Alfie (Mariano) lives in Shelby Twp, Metro-Detroit
Send a message via ICQ to alfie43
Removing my windshield wipers
I have removed the protective cap, the hex nut, and pulled up on the wiper arm, but it's not budging. Does anyone here know if a puller or other special tool is needed to remove the wiper arm off it's shaft.
Alfie
alfie43 is offline   Reply With Quote
Old 08-04-2010, 06:52 PM   #2
Mach
Mach's Avatar
Drives: White M6 1LT RS
You kinda have to give it a firm wiggle as you pull on it.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 08-04-2010, 07:53 PM   #3
Camarofan69
The Autoglass Guy
Camarofan69's Avatar
Drives: 1969 SS 396, 1969 SS , 2010 RS
or you can use a battery terminal puller that works well, but if you close your hood and lift up on the arm itself (make sure it doent hit the hood) andpush down and pull up it should let go.
Camarofan69 is offline   Reply With Quote
Old 08-04-2010, 10:17 PM   #4
Huck1974
Drives: 2011 2SS
Alfie
Sorry man to chuckle. You have a Maggie and actually advertise it in chrome. Having trouble with wipers is a bit of an oxymoron.
Huck1974 is offline   Reply With Quote
Old 08-04-2010, 10:20 PM   #5
INTIMIDAT3R
Drives: '11 2SS/RS L99, '12 2LS LFX
Alfie
Some wipers have a little locking latch underneath by the post that you have to flip to actually remove the wiper arm. My old Sunbird had them.
Once I flipped them, they came off with a little wiggling while I pulled it up.
INTIMIDAT3R is offline   Reply With Quote
Old 08-04-2010, 10:31 PM   #6
alfie43
alfie43's Avatar
Huh?
Sorry man, but I don't see the contradiction between me having a supercharger a couple of emblems and not knowing if there is a hidden retainer or cir-clip under the wiper arm.
Ya gotta explain that one to me bro.
ox•y•mo•ron \ˌäk-sē-ˈmȯr-ˌän\ noun
a combination of contradictory or incongruous words (as cruel kindness); or incongruous elements
Alfie
Old 08-04-2010, 10:37 PM   #7
Huck1974
Drives: 2011 2SS
On American cars, they only make so many kinds. I apologize. I just figured that if you owned such a nice car and took the care to modify it properly, you could figure it out. Hence the reference. I was just ribbing you a bit.
How about "simply complicated"?
Old 08-04-2010, 10:47 PM   #8
alfie43
alfie43's Avatar
Apology not necessary. Perhaps I over reacted. I've pulled on more than a few wrenches in my past....just like to know how things are assembled before I try to dissemble.
Did you ever break something because you didn't have an assembly drawing?
Regards, Alfie
Old 08-04-2010, 11:00 PM   #9
Huck1974
Drives: 2011 2SS
Regards, Alfie
Yes. In the younger hasty days. Plenty of times. Wiper assembly is not one you need to study on.
Love your car.
I'll finish mine in a month or two. I'm going to really beat my head against a wall. I will have to write my own manual.
Old 08-14-2012, 12:03 PM   #10
nicave13@gmail.com
LED god
nicave13@gmail.com's Avatar
Drives: 2010 Inferno Orange Camaro SS/RS
Took off bolts, twisted pried and pulled for 5 min. No luck, not a mm. I drive a early 2010 and have never been off. Any suggestions? Gonna buy a battery terminal puller today. I did all this on the one I could reach, the other...
Thanks in advance
nicave13@gmail.com is offline   Reply With Quote
Old 08-14-2012, 12:53 PM   #11
AntiPriuSS
Drives: Black 2012 Camaro 2SS/RS
Take off the snap on cap at the base and there is a nut under it. Some cars also have to have the arm in the UP like off the window, hinged up to come off.
Im not sure if this would help. But I found it on this site after a quick google search.
AntiPriuSS is offline   Reply With Quote
Windshield wipers croyal1974 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 08-29-2010 02:18 AM
Windshield problems tilapia2005 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 8 07-28-2010 09:19 PM
Removing Swirl Marks using a Flex and Meguiars M105/M205 Angelo@Autopia Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 5 05-22-2010 11:36 PM
Stress Riser .. Check your windshield ASAP sigma_1966 5th Gen Camaro SS LS LT General Discussions 17 08-26-2009 09:53 PM
Windshield Wipers levi1922 5th Gen Camaro SS LS LT General Discussions 26 04-29-2009 12:15 PM
