Old 08-05-2010, 08:56 PM   #1
ITGuy11
Burning up tires
Drives: 2023 ZL1 Vert
LS3 Factory Exhaust Removal
When I was under the car installing my Kooks long tubes I was looking at how the stock exhaust system is mounted. It looks like the hangers above the mufflers are in a very tight spot and not easily accessible. Are there any tricks to removing the rubber isolators/hangers while keeping the stock setup intact?
ITGuy11 is offline   Reply With Quote
Old 08-05-2010, 09:09 PM   #2
mikey8
mikey8's Avatar
Drives: 2019 SS 1LE
If you are looking to just remove the rubber hangers... Spray with WD-40. They'll pop right off.
mikey8 is offline   Reply With Quote
Old 08-06-2010, 01:46 AM   #3
LS3 SS
Drives: 2010 Cyber Grey Camaro SS (LS3)
Just removed my complete factory exhaust system today. The Hangers are accessible, either spray them with WD40 or use VERY Soapy water (slightly more soap than water solution) and they will slide right off. But it will be easier if you drop the exhaust from the Cats first, and then try to remove the hangers.
LS3 SS is offline   Reply With Quote
Old 08-06-2010, 02:47 AM   #4
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
I used a pair of channel lock pliers to push them out. It's tight and I had the plastic bottom piece half off but it's not to bad.
9/26/09 Took delivery!
Old 08-06-2010, 12:54 PM   #5
WheelmanSS
Logic is dead
WheelmanSS's Avatar
Drives: 2010 Camaro 2SS/RS
Send a message via AIM to WheelmanSS
WD40 is a good idea. Let them soak for about 20 minutes, then start the fun ol' pull-push method. It helps if you have a couple friends pulling from the front or back so that when you pull the exhaust from the fascia, you don't damage it.
2010 Camaro 2SS/RS (LS3)
573 RWHP 498 RWTQ
- Vortech V3 Supercharger
- Kooks Stepped Headers, Magnaflow 16580
- Suspension by Pfadt, Hotchkis.
2007 Trailblazer SS- Sold
2001 Trans Am WS6 431 RWHP 408 RWTQ - Sold
1994 Camaro Z28 - Sold
WheelmanSS is offline   Reply With Quote
Old 08-06-2010, 03:56 PM   #6
MarylandSpeed
Drives: 2012 ZL1 & 2010 2SS/RS
It's worse ona ground effects car..haha.
MarylandSpeed is offline   Reply With Quote
Old 08-08-2010, 04:28 AM   #7
Beyond Limits
Pushin a rock...
Drives: 2010 Camaro SS/RS
Instead of WD-40 get a spray bottle and fill it with water and some dish soap. Spray around where the pin goes through the rubber bracket. It will slide off nice and easy. Just spray some more to get it back on. But it will dry and it will not leave a slick oily residue behind like d-40 will.
Also, unbolt the lower valence and gently pull down on the clips along the sides of the valence (be careful because they are plastic). You are not taking the whole rear valance off, but just giving yourself some more room to work.
Once you get into it you will realize it is a lot easier to deal with then you think it is. Just make sure you either have someone to help you, or a spare floor jack or stand to hold up the exhaust can on one side while you remove the other. It is not the lightest thing in the world (certainly manageable by yourself), however if you let the exhaust rest on the rear valance there is a very good chance it will damage the urethane bumper.
Check out Borla's site. You can download the install instructions for their cat-back system and it contains some really well written instructions with pictures on how to remove your stock exhaust.
Beyond Limits is offline   Reply With Quote
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 02:41 PM
Watched a 2011 5.0 GT at the track. JJ#48Racing Chevy Camaro vs... 143 07-21-2010 07:56 PM
FS: 2010 Camaro SS LS3 M6 factory exhaust MasterZ V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 0 03-24-2010 09:19 PM
Is the factory exhaust good enough to use? caverman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 11-21-2009 10:15 PM
LS3 MBRP exhaust videos ? BELLSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 11-14-2009 10:18 PM
