Old 08-06-2010, 01:38 PM   #1
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
Oil Catch can not needed on L99??
Since the PCV is pumped back into cyl heads and not the valley on a L99 why would a catch can be needed?
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 08-06-2010, 02:03 PM   #2
KnightRiderSS
Voodoo Medicine Man
KnightRiderSS's Avatar
Drives: Black 2SS with RS package
http://www.camaro5.com/forums/showth...ight=catch+l99
KnightRiderSS is offline   Reply With Quote
Old 08-06-2010, 02:14 PM   #3
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
I know it needs neg pressure to draw oil, but why do they say its routed back to Cylinder head?
Build Thread
Old 08-06-2010, 02:20 PM   #4
bmbbl be
bmbbl be's Avatar
Drives: 2010 CAMARO SS
its goes into the throttle body
bmbbl be is offline   Reply With Quote
Old 08-06-2010, 03:14 PM   #5
Scruffage
Drives: 2011 2ss Rs LS3 manual in black
If the LS3 has air/oil separator on both the clean and foul side as the article below states, why is a oil catch can needed?
This catch can stuff is new to me, just asking.
http://www.camarohomepage.com/ls3/
Scruffage is offline   Reply With Quote
Old 08-06-2010, 04:19 PM   #6
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
There are only two places that will produce negative pressure, that you can draw from. One is the exhaust, the other is the intake. Since the intake provides more vacuum, this is the optimal place. Since the intake is used, it draws that pressure (with oil vapor) into the intake air which goes into the intake plenum, then to the cylinder heads. This isn't the ideal situation for maintaining high performance. It won't kill your engine but it will degrade it's performance. A $100 catchcan is cheap insurance to keep your engine running at peak performance.
Not sure where that oil/air seperator is located, but there isn't one between the valve cover and the intake pipe.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 08-06-2010, 04:25 PM   #7
KnightRiderSS
Voodoo Medicine Man
I'm glad for the info about it needing the pressure from the intake to operate correctly...I was thinking about just slapping a filter on the end of the hose from the catch can like I did on my bike
Old 08-06-2010, 04:29 PM   #8
axis
Search Ninja
axis's Avatar
You can do that but it won't be as effective and what happens to the oil when the filter gets soaked? Had one on my old Talon Turbo and it got oil EVERYWHERE under the hood.
Halltech CF 102 fed
Old 08-07-2010, 01:03 AM   #9
KnightRiderSS
Voodoo Medicine Man
Well I was thinking if I put it past the catch can...so it shouldn't do that? But since the intake provides vacuum for the system I am planning on just hooking it all up.
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 02:41 PM
L99 Revextreme oil catch can problem?? Silver Ice Man Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 07-12-2010 09:36 PM
excessive exhaust smoke kam 5th Gen Camaro SS LS LT General Discussions 31 03-25-2010 06:51 PM
How about a barrel of oil for around $16? Blownhotrodder General Automotive + Other Cars Discussion 19 03-06-2009 08:25 PM
