Old 08-07-2010, 01:09 PM   #1
1985airborne
One Slow Automatic
1985airborne's Avatar
Drives: 2017 GS 2010 CAMARO SS
LS 9 internals for LS3 so I can use the LS9 Superchager on the LS3
Im not sure If there is a parts list for the LS9 internals for the LS3, but if there is one can somebody point me in the right direction!
650HP 2010 CAMARO SS 710HP 2017 GRAND SPORT
1985airborne is offline   Reply With Quote
Old 08-07-2010, 02:47 PM   #2
HaddadMotorsports
HaddadMotorsports's Avatar
Drives: Camaro
You technically would not have to upgrade your internals.
We are doing the exact same thing with the eforces, magnachargers, vortechs, prochargers, etc. without internal modifications and are able to make up into the high 500 rwhp #'s.
If you were going to upgrade internals, there is a myriad of combo's that you can put together via the aftermarket that would cost you less money and net better results over LS9 internals.
Thanks
Mike Haddad
HaddadMotorsports is offline   Reply With Quote
Old 08-07-2010, 03:36 PM   #3
dmax86
dmax86's Avatar
Drives: 2016 Z06 C7R
2013 ZL1 BONE STOCK! LOL
dmax86 is offline   Reply With Quote
Old 08-07-2010, 06:06 PM   #4
SonnyakaPig
Drives: C63 P31
Thanks
Mike Haddad
Good points.
I would, however, be interested to know the power limits of the LS9's internals.
SonnyakaPig is offline   Reply With Quote
Old 08-07-2010, 08:23 PM   #5
Slowhawk
Drives: 1999 Trans Am
We just tuned a LS9 Vette and stock it only made 530hp/500tq. I see no problem at all putting a LS9 blower onto a stock LS3.The only big difference is to NOT run a tune from a LS9 since the heads are completely different and the LS9 runs a ton of timing.
If you are going with motor work, no reason to not just do a 418ci forged shortblock.More power/torque everywhere.
Slowhawk is offline   Reply With Quote
Old 08-09-2010, 10:57 AM   #6
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
You can call you local GM dealer and get pricing on pistons and rods if you like, but you may be better suited to just install a forged piston (diamond, CP, Arias ect) and forged rod (callies, oliver, carillo ect) this may be more cost effective and a better solution for long term engine longevity.
however the stock ls9 block we have pushed to 905 wheel horsepower in our twin turbo Zr1, it is the highest hp to date that we are aware of, so the LS9 can certainly handle the power!
Regards
IPS Brandon is offline   Reply With Quote
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
LS3 vs LS9 BumbleDs Forced Induction - V8 9 10-02-2009 10:27 AM
Supercharger or LS9 Swap? digidigi Forced Induction - V8 17 02-20-2009 11:43 AM
stock ls3 vs. a ls9 w/ no charger? 454lsxss 5th Gen Camaro SS LS LT General Discussions 4 11-01-2008 06:05 PM
Advice---Supercharged L99, S/C'd LS3 or LS9? CamaroZR1 Forced Induction - V8 25 09-25-2008 10:21 AM
