08-08-2010, 02:57 AM | #1 |
Drives: blacked out 2010 Camaro Join Date: May 2009
L99 CAM Installation
What is the price range of having a cam installed and tuned? and would you recommend having the internals done also?
Thanks |
08-08-2010, 07:54 AM | #2 |
"Silver Street"
Drives: 2010 2SS/RS L99 Join Date: Oct 2009
I am getting an L99 to LS3 conversion with new cam, lifters, push-rods, valley trays and timing parts. I not only wanted to get rid of the AFM, but the lifters, too. Also, dual-springs are recommended for a higher lift cam. This is the most expensive route, though.
Silver Street - 2010 Camaro 2SS/RS, SIM, Gray, Cyber Gray Rally Stripes, Polished Wheels, Automatic (L99) - 553 RWHP/510 RWTQ
CAI Inc., ARH LT Headers with Cats, Borla Touring Cat-Back; Pfadt Coil Overs, Sway Bars, End Links, and Trailing Arms; Comp Cams Blower Cam, Dual Springs, Push-Rods, and Lifters; GM LS2 Lifter Trays, 6.2 MLS Head Gaskets, Crank Bolt, and LS2 Front Cover; 3-Bolt Conversion Timing Gear, Katech C5R Timing Chain, ARP LS2/LS3 Head Bolt Kit, Melling Hi Volume Oil Pump, TVS 2300 Supercharger (Black); Build by Vengeance Racing; Custom Tune by Vengeance Racing |
08-08-2010, 07:58 AM | #3 | |
08-08-2010, 08:01 AM | #4 |
Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
It should run you about 1200-$1400.00 in labor. I went with a VVT cam and DOD delete. Which replaces the AFM lifters,but is not a complete L99 to LS3 swap. The parts depend on what you or your tuner goes with.
MAST 416 STROKER: STAGE 3 TVS 2300 CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS/NANO KIT KDI HEAT EXCHANGER/ROTOFAB RESERVOIR CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES EATON TRUETRAC -LPE 3.27 GEARS DYNATECH HEADERS/MAGNAFLOW EXHAUST SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL BMR/EIBACH SUSPENSION KILL MODE, ON. |
08-08-2010, 08:02 AM | #5 |
"Silver Street"
It is in my signature: Vengeance Racing. They are also doing a supercharger, Pedder's suspension package and sway bars.
08-08-2010, 08:04 AM | #6 |
I was looking a Texas speed and performance, Any other places you guys would recommend looking?
08-08-2010, 08:07 AM | #7 |
It depends ...You looking too do the LS3 swap? or retain VVT ?
08-08-2010, 08:08 AM | #8 |
I wanna get rid of VVT and AFM
08-08-2010, 08:11 AM | #9 |
Thunder racing/ livernois has complete VVT and DOD delete kits. Your labor will be considerable higher.. $3000.00+
08-08-2010, 08:11 AM | #10 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Texas speed is the only "shop" that I know of that's testing their own L99 grinds. The rest of the shops are using the existing L99 cams out there from Mast and Comp. If you do the LS3 swap, you have a whole host of cams to choose from. It all depends on what you want and how much $$ you want to spend. I'd suggest you talk to the shop that will be doing the install and ask them what they recommend. VVT isn't a bad thing. It's actually very good for midrange Tq, while still giving you good peak HP. It's just the degree of VVT that's used in the OEM setup that limits you so much.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
08-08-2010, 04:06 PM | #11 |
Casey Woodside
Drives: a very fun car Join Date: Jun 2010
is there a way to tune the vvt away from the oem set up?
08-08-2010, 04:41 PM | #12 |
Search Ninja
You really don't want to tune it away, in the OEM setup. Think about it. Your cam can adjust A LOT, during all situations, giving you optimal tq and HP. The problem lies in the fact that you can't put a decent sized cam in and still be able to adjust like OEM. It will cause clearance problems and you'll be adjusting into the piston. The newer L99 cams lessen the degree in which it can adjust to keep this from happening. The trick is to balance the size of the cam with the ability to adjust without hitting the piston.
08-08-2010, 05:03 PM | #13 |
This helped me make my decision: http://gmhightechperformance.automot...ges/index.html
08-09-2010, 10:37 AM | #14 |
Casey Woodside
ok thanks for the info. how do you like the mast motorsports cam?
Similar Threads | ||||
Remote Start installation for 1SS (L99) | EDGE_ | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 28 | 12-07-2014 12:37 PM |
L99 Cam Swap | MTI Racing Kevin | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 27 | 08-31-2012 01:39 PM |
L99 Build Video - Time Lapse + Dyno + Cam | Meister@Torq | USA - Southeast | 2 | 03-04-2010 12:30 PM |
L99 TVS 1900 + Cam Dyno #'s ARE IN | pharmd | Forced Induction - V8 | 35 | 09-07-2009 04:36 AM |
cam installation | kozzmo49 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 27 | 08-30-2009 04:42 PM |
