Old 08-09-2010, 04:55 PM   #1
Yellojacket
Yellojacket's Avatar
Drives: 2SS/RS Inferno Orange
18.62 hp increase from just an intake??
Looking at JRE tests of various intakes for the LS3 there isn't anyone coming very close to 18hp increase from a bolt on intake but K&N is claiming a 18.62hp increase?? Wonder if this is legit or just wishful thinking???
http://spreadsheets.google.com/pub?key=tQetE2V6iXkPIRG35oX6CFQ&single=true&gid=1& output=html
http://www.knfilters.com/search/product.aspx?Prod=63-3074
http://www.knfilters.com/dynocharts/57-3074_dyno.pdf
When it comes to classic American muscle cars, the Chevy Camaro is on top of many lists. Chevrolet introduced the Camaro in the early 1960's to compete with the well-respected Ford Mustang. In 2002, Camaro sales were down and Chevrolet ceased its production. An all new Camaro has emerged for the 2010 model year bringing style and performance back to the table. Available only as a coupe, the 2010 Chevy Camaro SS is equipped with a powerful 6.2 liter V8 engine.
For those looking for a performance boost, K&N has released an air intake system (63-3074) that is guaranteed to increase horsepower. The 63-3074 was engineered to the specific design of the Camaro's engine compartment and uses only factory holes and mounting points. K&N made installation of this air intake simple by providing written instructions and a detailed installation video that takes you through the process step by step. Installation of the 63-3074 is usually done in 90 minutes or less and only requires common hand tools.
K&N's air intake system 63-3074 uses a non-metallic intake tube and oversized high-flow air filter to replace the restrictive factory intake housing and air filter. A heat shield is standard with this air intake and is designed to allow cooler air to enter your engine. Less restriction and cooler air means more power throughout the rpm range. K&N dyno tested this intake and the results were outstanding. After installation the K&N 63-3074 air intake produced an amazing 344.27 rear wheel horses at 5161 rpm on a 2010 Chevy Camaro SS. This was a net gain of 18.62 horsepower at 5161 rpm.
The 63-3074 comes with a large K&N air filter (RF-1042) that is washable and reusable. This high-flow air filter captures harmful particles and it will perform for up to 100,000 miles before service is required depending on driving conditions. This K&N air intake system, like all other K&N air intakes, is backed by the famous K&N Million Mile Limited Warranty. K&N air intakes can be purchased at most auto parts stores and performance shops. Use the K&N dealer search to find a K&N dealer near you. Find K&N products for any vehicle using the K&N application search on www.knfilters.com.
Yellojacket is offline   Reply With Quote
Old 08-09-2010, 05:01 PM   #2
mikeSS
mikeSS's Avatar
Drives: 2015 c7
i have K&N CAI... i think if you buy a top name brand its going to work fine.... keep in mind they will do this testing with the perfect dyno conditions... with perfect engine temperatures.. to get best results to make there product look good.
Old 08-09-2010, 05:02 PM   #3
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Vararam claims 35+hp and 3-5 tenth in the 1/4 mile.
So I guess my car should run 12.0 flat because it ran 12.5 without the Vararam.
Most the intakes on the market make around 10 rwhp or so (give or take a few HP).
Old 08-09-2010, 05:13 PM   #4
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
First rule of buying car parts is, NEVER trust the manufacturer claims. This is the very reason JRE did the first test and why he's doing another one for the CAI's that weren't out yet. If we all went with what the manufacturers claim, we'd all be sporting Vararam's.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 08-09-2010, 05:47 PM   #5
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
The trick a lot of the "big name" air intake manufacturers use is that they test their intakes on an engine stand which gives you a nice number but that is not what it will put to the wheels. A lot of them also claim big numbers and forget to mention that those numbers are only achieved with a tune on top of the intake.
Old 08-09-2010, 05:47 PM   #6
Scruffage
Drives: 2011 2ss Rs LS3 manual in black
How much for the Vararam CAI?
Scruffage is offline   Reply With Quote
Old 08-09-2010, 07:06 PM   #7
east TX Muscle cars
east TX Muscle cars's Avatar
Drives: 2x 05 Vettes/65'AC cobra/68 camaro
we have seen the BEST gains with the ROTOFAB CAI in house....... if you want one let me know! our results are posted on here for NA and FI applications. :-)
east TX Muscle cars is offline   Reply With Quote
Old 08-09-2010, 07:09 PM   #8
ArkySS
Camaroless for now...
ArkySS's Avatar
Drives: 2014 Blue Topaz Silverado
I've also noticed that those claims are at different points in the powerband. One CAI might make significantly more power than stock at one point in the powerband but the gap narrows quickly. A good CAI is obviously a cheap way to more horsepower but it's not like you are going to get big numbers out of a CAI. It's the combination of CAI and other power adders (typically adding a tune) that make it worth while. There are cars on this forum that have seen 15% to 20% gains in power from CAI, LT Headers, Exhaust and Tune. That is significant considering we aren't talking gains over 200RWHP!
It was fun while it lasted.....
ArkySS is offline   Reply With Quote
Old 08-09-2010, 08:33 PM   #9
axis
Search Ninja
axis's Avatar
Go look in the forsale section. Several people are switching for one reason or another.
Halltech CF 102 fed
Old 08-09-2010, 09:19 PM   #10
mulletman
Drives: 2017 Camaro SS
Some are complaining of surging after the install of Vararam. You might want to do a search.
mulletman is offline   Reply With Quote
Old 08-09-2010, 11:47 PM   #11
axis
Search Ninja
axis's Avatar
I guess he didn't get the sarcasm in SGO's and my post.
Halltech CF 102 fed
Old 08-10-2010, 12:45 AM   #12
CamaroFTW
CamaroFTW's Avatar
Drives: 2010 Camaro 2SS/RS-Rally Yellow
Send a message via MSN to CamaroFTW
You don't have to convince me
I am not one of the big "lid thumpers" here.
CamaroFTW is offline   Reply With Quote
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 151 05-07-2015 05:52 PM
JDP Motorsports Airaid Intake Specials! PM for Coupon Code! JDP Motorsports V8 Bolt-Ons & Tunes 13 12-02-2009 11:44 AM
Camaro Deal of the Day - 9-21-09 G5CR Intake! MoranoRacing V8 Bolt-Ons & Tunes 0 09-21-2009 09:43 AM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 10:06 AM
LS3 Specs, and Descriptions Mr. Wyndham Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 11-06-2007 01:04 PM
