Old 08-10-2010, 11:15 PM   #1
code3 ss
code3 ss's Avatar
Drives: SW,SS1 RS,GRND EFFCS,ORNG STRPS
epoxy removal from paint!
OK. So I finally got my night rider scanner to stick inside the mail slot by using the gorilla epoxy but ofcourse some of the epoxy dripped on the paint and dried up. How do I remove the epo:(xy without damaging the paint? So far I know acetone is a no no. Any suggestions? ? Anyone? Pleeease!!
code3 ss is offline   Reply With Quote
Old 08-11-2010, 12:12 AM   #2
2LTRS
Detailing Connoisseur
2LTRS's Avatar
Drives: 2010 Rally Yellow 2LT RS
Unless you had a good coat of wax on there - your likely hosed. Resin/Epoxy will bond with clear coat (because clear coat is essentially a resin). You might be able to chip it off with your nail if you had a coat of wax or sealant on there.
2LTRS is offline   Reply With Quote
Old 08-11-2010, 12:25 AM   #3
code3 ss
code3 ss's Avatar
all i had on there was mcguires spray on detailer!
Old 08-11-2010, 04:03 AM   #4
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Damn. Hope the scanner was worth it.
[B]
Old 08-12-2010, 01:00 AM   #5
2LTRS
2LTRS's Avatar
Depending on the one you used, it may actually help your situation. If you used the "ultimate quick detailer" it has "hydrophobic polymers" in it which can work in your favor trying to chip it off.
Old 08-12-2010, 06:44 AM   #6
JB @ C and L Machine
Drives: Ordered 2011
JB @ C and L Machine is offline   Reply With Quote
Old 08-12-2010, 06:57 AM   #7
garcmol
garcmol's Avatar
Try this...
http://www.autogeek.net/scraperite-p...or-blades.html
...use it with detail spray to lube the surface. Use carefully!
Old 08-12-2010, 07:22 AM   #8
Russell James
Russell James's Avatar
If solvents or a plastic scraper don't get it... possibly a very sharp razor blade, and then a buff out of any marks left behind.
Paint your own stripes? blackZbandit Cosmetics and Lighting Modification Discussions 44 09-18-2011 10:22 AM
PROTECT YOUR PAINT from rocks & road debris! ! TKO Performance Wash/Wax/Detailing and Cosmetic Maintenance Parts 51 11-12-2010 03:31 PM
►PROTECT YOUR PAINT with Cleartastic's 2010 Camaro paint protection kit. TKO Performance Wash/Wax/Detailing and Cosmetic Maintenance Parts 17 07-21-2010 03:35 PM
►PROTECT YOUR PAINT with Cleartastic's Camaro Paint Protection Kit! ! TKO Performance Wash/Wax/Detailing and Cosmetic Maintenance Parts 9 05-13-2010 08:22 PM
Adam's Polish & Car care Products Charlie@STILLEN Wash/Wax/Detailing and Cosmetic Maintenance Parts 50 04-01-2010 04:28 PM
