![]() Drives: 2011 2SS Black w/Orange Stripes Join Date: Aug 2010
Sound Deaden or Not?
I plan to put 1 JL 12W7 in the trunk, is it going to sound bad if I do not use sound deadener? Is it worth paying 100.00 for? Thanks everybody!
Sound deadening is a MUST!!!!
ciandrew, would i be fine to only sound deaden the trunk? Thanks
I applied sound deadener to the trunk area using FatMat Trunk Kit ($50) and I'm very happy with the results. I am not an audiophile and rarely turn music on but it noticeably reduced the drone from the exhaust and road noise coming up through the rear of the car.
Took about 2hrs to install and there was a faint butyl-like smell in the trunk for the first 48hrs but went away after that, even on hot sunny days. |
knows 2 facts about ducks
how much does the FatMat weight?
#6 |
I plan to go with Rammat, I have not recieved my price quote back, but I have heard nothing but great things about the owner and his products.
#7 |
I utilized Fat Mat in my Avalanche and again in the trunk of my Camaro.......Huge Difference .....This winter I will be completing the Camaro .......
#8 |
![]() Drives: 2010 SS2, 03 vette supercharged, Join Date: Feb 2010
for sure
#9 |
Virologist in the making
Drives: 2010 VR SS/RS LS3 Join Date: Aug 2009
Please for the love of all that's good deaden your sound!
Its amazing to see people roll by with their bass booming and they are COMPLETELY oblivious to the disgusting rattling their trunk leaves behind them. They think they are tunring heads with the cool sound but people are just concerned that their car is going to fall apart. In my last car I used dynamat and some weather sealing foam tape to line the edges of the trunk. Dynamat on the rear liscense plate is a must. In my G6 i noticed if I drove with the back seat down (so you can see into the trunk from inside the car) the sound was deadened even more because the vibrations had more surfaces to hit and was not just limited to the trunk. Turning the box into the car was bad because the windshield and mirrors all rattled which was weird and scary.
6000, Delivered to the customer - 12/21/09 ![]() |
#10 |
Sounds great guys, It is official I will use the sound deadner. I just hope the trunk is enough I don't want to get into having to pull door panels and seats out.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
Keep the rear seat up and you should be fine. Drop the seat and your roof will start flexing. (depending on the power your running)
#12 |
![]() ![]() ![]() ![]() Drives: 11 IOM 2SS/RS M6 w/Hurst Join Date: Nov 2009
I used second skin damplifier pro on my trunk and on my trunk lid as well. THIS IS A MUST!!! Its a pita to do but worth it.
Cheers K |
#13 |
![]() Drives: 2010 SIM Camaro 2LT/RS Join Date: Jun 2009
Where in Indy are you? I just installed a 12W7 in my trunk w/a 1000/1. I used Stinger RoadKill to line the trunk area successfully. There is little to know vibration and the depth of sound is incredible. Definitely go with a sound deadener with this strong of a sub.
I would love to see your setup. I'm installing an audio battery + isolator as well. I'm running into some issues with fabricating the stanchions I need to put the battery in the spare tire well. REALLY snug fit, but I have faith it can be done. When successful, I will post pics.Are you using factory head unit? Do you have BA or non-BA Camaro? How are you feeding signal to your amp? I am using a ******** stealth enclosure with the T harness. This is an awesome way to go plus it's easy to work on for making changes. |
#14 | |
The trunk is a must though. You should do the trunk lid as well (under that piece of carpet that's there) |
| Weird sound, hard to place... | El Chorizo | 5th Gen Camaro SS LS LT General Discussions | 2 | 03-01-2010 07:01 PM |
| completely new to sound.. questions | dect | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 15 | 02-26-2010 05:08 PM |
| L99 Corsa Exhaust Sound? | VALOR | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 4 | 08-10-2009 12:31 AM |
| Mystery Sound....I need your help | ZZcamaro | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 9 | 08-09-2009 08:41 PM |
| Muscle car exhaust sound | linkwpc | 5th Gen Camaro SS LS LT General Discussions | 19 | 12-09-2007 07:50 AM |
