Old 01-28-2012, 10:14 PM   #211
Moreno1
Drives: G5.R
Originally Posted by mikepage0007 View Post
did you consider running the coils inside the fenders?..i have seen some guys do it, just curious if it was something you considered, if so..why did you choose the frame rails...i am going to pull engine in a couple weeks and need to decide where to move them to...want to find all the pro,s and con,s of both..thanks
Mike, the only reason I didn't run them behind the fenders is because you either have to weld the bracket in or if you bolt them, you need to remove the fenders. A little more than I was looking to undertake at this point. You can bet if I were removing engine, I would definitely go that route. I will down the road when I do pull my engine.........
I would also relocate the ABS if I was removing the engine. Can't do it with the engine still in.
Keep us posted of how your projects is coming along. By the way, why are you pulling it out?
Moreno1 is offline   Reply With Quote
Old 01-29-2012, 11:02 AM   #212
The Stig
knows 2 facts about ducks
The Stig's Avatar
Thanks for the tip, those look good.
Click to view my build thread
Old 01-29-2012, 11:31 AM   #213
NC-V
NC-V's Avatar
Drives: cts-v
Originally Posted by The LSX Dr. View Post
Have you guys seen these new fittings by Russell? They make different sizes, this one pictured is for the fuel lines. These will push onto the factory male fuel line. Then you can make your own custom line to the fuel rail.
http://www.edelbrock.com/new_products/russell.shtml
yes! these are very handy and make it very easy to dress up your fuel and evap lines with some nice AN lines. Good suggestion Doc
NC-V is offline   Reply With Quote
Old 01-29-2012, 07:15 PM   #214
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
fo the 427lsx/whipple/nos 200 shot direct port -4l80 swap..i,m starting inside 1st and working my way outside..lol..here is link..http://www.camaro5.com/forums/showthread.php?t=195970
mikepage0007 is offline   Reply With Quote
Old 01-29-2012, 08:03 PM   #215
Moreno1
Drives: G5.R
Mike! that's going to be sick. Thanks for sharing. Can't wait to see how it turns out.
Old 01-29-2012, 10:07 PM   #216
Moreno1
Drives: G5.R
I could be mistaken but I don't think that fitting will connect to our hard line. There's a lot of manufacturers that make QD "quick disconnect" fitting for our cars. They look more like the one in the picture below made by Fragola.
I agree, they do look trick. I did four days of research just on fuel lines and fittings. I spoke with many techs at different companies. Here the reason I decided to go with TechAFX.
1. Even though those fitting look trick. The inside is plastic which could lead to problems.
2. TechAFX uses OEM style fittings for the QD which have no plastic.
3. I already have a bunch of AN fittings, so I thought that having OEM QD for the Fuel line and EVAC would keep it interesting.
4. More important then all of the above, with the other QD's, you have to use there traditional braided fuel line. These line, although they look cool, are known for emitting gas fumes in your garage in passenger compartment. Which isn't cool in a new car.
Before I found TechAFX, one of the companies I spoke with was Fragola. They recommended I use Gates Nylon hoses which would avoid emitting fuel vapor. But they look like a regular rubber hose. I was thinking I'd cover them with braided nylon sleeves to male them look attractive.
Than I stumbled onto TechAFX web site and they had the solution for me. Their fuel hoses are braided steel but they are cover with a nylon sleeve. Therefor, eliminating any possibility of emitting fuel vapor into the passenger compartment. And they were attractive to boot. So theres was no need to Foosesify them, LOL.
Hope that helps
Old 01-29-2012, 10:14 PM   #217
Ivan @ Southwest Speed
Changing my underwear now.....thank you very much.
Swell pic brotha!
Ivan
Old 01-29-2012, 10:30 PM   #218
Moreno1
Drives: G5.R
Coming along.......
Here's some work I did on the factory harness to clean them up.
Below are the step I did with all the factory harness:
Next, I remove the factory plastic tubing:
Next, I taped them completely with harness tape (different than electrical tape you get at HD)
Lastly, I covered them with Russell's harness wrap.
Next came doing the harness that runs down the fender.
I felt no need to reinstall this plastic shield.
You can see all the crud that came out when I pulled the sheild.
Here the harness completed.
Well almost, I felt the connectors could use some help. Didn't much care for all the scratches on the fuse box lid either.
I used three different tones of black to keep it interesting.
repainted the lid, no more scratches and now the connectors......much better than purple, etc.
And after countless of hours of sanding, priming and painting. No more big Vararam Logo, no more cheap looking casting seem down the side and much nicer finish.
Before:
After:
One last shot of a mock-up. You can see in this pic I painted the power steering cap. I also did the brake, radiator and water bottle caps.
Got these in the mail. Will be using them to replace all the fender and radiator core support. They are made by the AWESOME Ring Brothers.
Hope it inspired to get out into your garage .
Old 01-30-2012, 10:49 AM   #219
Moreno1
Drives: G5.R
The fitting pictured here is for GM fuel lines. It does not have any plastic inside. It is made from billet aluminum and seals with a O-ring. The second horseshoe shaped piece is the retainer. The 2 thread together providing a positive seal. I have been using stainless steel braided hose for years with no leak or fume problems.
The reason I thought this fitting wouldn't work is because our factory hardline were the QD will connect have no threads to thread this fitting too.
I first learned about braided lines emitting fumes from speaking with the tech guys at different fuel line companies. They did say it's kind of a hit and miss situation. You can have them for years and never have a problem. Or go 6 months without one and then start smelling the gas vapor fumes. Just didn't want to take the chance when there's solutions out there to address the potential problem.
Old 01-30-2012, 07:44 PM   #220
NC-V
NC-V's Avatar
Drives: cts-v
Nope these work great, the internal threaded side slides over the end of the hard line(seals with an o-ring inside) and the retainer threads in from the back locking up against the "bulge" in the line. There is also another style that uses a plastic retaining squeeze clip.
Old 01-31-2012, 09:08 AM   #221
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Hi Nathan. A little help please. I am relocating my evap solenoid and have everything ready to go. How did you get yours under the fuse box and how is it oriented? I can hardly get my hand in there! I also notice where ypu bolted it there are more holes than in mine, I just have one small square hole. Thanks!
Old 01-31-2012, 10:21 AM   #222
Moreno1
Drives: G5.R
Ahhh, got it....... thanks
LOL, I actually recruited a female with small hands.
First thing I did was to run the hose that attaches to the intake through the space between the water pump and block. It comes out the bottom by the heater hose. I than ran it up the front by the frame rail. Next, I attached the hose to the solenoid. This way I could use the hose to manipulate the solenoid through the the front opening off the fuse box bracket. Next, I aligned the solenoid where I could put the bolt through. Miss "Small Hands" stuck her hands through the back side of the fuse box and installed the nut. FYI, the nut fell of her hands several times, so it's a good idea to have one of those magnet to grad it each time fall.
Hope that helps.
Old 01-31-2012, 10:49 AM   #223
PAUL SS
PAUL SS's Avatar
Thanks, that does help, I knew there had to be a trick to it.
Old 01-31-2012, 02:48 PM   #224
RocTrux
RocTrux's Avatar
Drives: Summit White 2011 2SS/RS
Hope that helps.
Or you can do it the easier way and just remove the fuse box like I did its simple.
I had the Tech FX lines shortened that one up a lot and took the 90 off and used the straight one from the factory hard line its still accessible if you need to take it off. Under the fuse box on the mount you can drill a new hole to mount the bracket, or theres a hole there you can use but theres a long tap coming off of the bottom of the fuse box that goes through that hole to line up the box on the mount it can be cut off if you wish but I opted to just zip tie the e-vap bracket to the mount using that hole and keeping the alinement tab. I ran the manifold line along the coolant line under the CAI tube across the top of the raditor and under the cover out of sight then through the front part of the fuse box mount on that I did like Nathan did attaching it to the solenoid first and pushing it through and i used the stock 45 degree end on that side instead of the 90.
So thats another option if you don't have an extra set of small hands to use.
RocTrux is offline   Reply With Quote
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ AutoAgenda Exterior Parts & Accessories 14 02-06-2013 08:43 PM
New Texas Speed & Performance Engine Machining Center! Trevor @ Texas Speed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 01-16-2013 03:46 PM
Hawk Performance Brake Pads part HB247Z.575 $85.00 Rogan USA - Florida 2 10-07-2011 12:10 PM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 08:57 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
