| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
![]() ![]() ![]() ![]() ![]() Drives: G5R Join Date: Sep 2010
Project Cleaning the Clutter in Our Engine Bay
Hey guys I have spent the last 4 days doing research on what we can do to clean up our engine compartments so that they don't look so much like a plumbers convention.
I thought I start this thread as a log of all the things I'm going to be doing to get there. I will also be doing DIY's of each step and links to those threads here. I also invite anybody that's tackling a similar goal to post what they are doing or have done. I think this will be helpful for all our members as it takes a tremendous amount of time just in research for-thought. I look forward to everybody input and contribution. This is my small way of paying it forward. I had a lot of great folks here who have been very generous with their time helping me. Hopefully other can get benefit also. ************************************************** ********************************** Updated pics: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ************************************************** ************************************************** *** Pictures and link references have been added for faster browsing: Powder coated intake: 479 510 ![]() New front drive: 767 ![]() Recreating upper radiator hose: 445 ![]() Removing all the casting (both inside and out), deburing and media blasting the block: 1245 1220 1177 ![]() ************************************************** ************************************************** *** Tucking and Reworking Wire harness: Reworking wiring harness: 77 78 79 210 220 491 Rerouting coil harness: 71 72 ![]() Rerouting injector harness:72 80 94 ![]() Recreating injector connectors: 324 ![]() ![]() Relocating EVAC solenoid: 57 Relocating Negative battery cable: 94 Relocating EVAC hose: 210 Relocating Positive battery terminal: 245 ![]() ![]() Relocating Coils: 64 ![]() Relocating PCM: 491 ![]() Remounting fuse box: 555 582 ![]() Polishing Water Vapor tube: 118 Polishing the front of cylinder head and welding bolt holes: 154 ![]() Polishing Power Steering Pump: ![]() ![]() Polishing Oil Cooler: ![]() ![]() Polishing T-Bolt clamps and Thermostat housing: 232 ![]() Before...... ![]() After......... ![]() Polishing power steering bracket: 282 285 292 Before........ ![]() After......... ![]() Refinishing the generator/alternator: 428 Before........ ![]() After sanding........ ![]() Done ......... ![]() Refinishing front drive: water pump, alternator brackets: 390 430 483 Before....... ![]() After....... ![]() Refinishing AC compressor: 422 Before....... ![]() After......... ![]() Polishing AC lines: 457 464 Before......... ![]() After....... ![]() ![]() Refinishing motor mounts before sending to powder coating: 913 927 ![]() Refinishing cylinder heads before sending to Lingenfelter to get reworked: 931 981 990 Before...... ![]() After......... ![]() Refinishing timing chain cover before sending to powder coating: 1011 Before...... ![]() After........ ![]() Prepping intake for Powder coating: 388 ![]() ![]() ![]() ![]() ![]() ![]() Create fuel lines: 129 ![]() Refinishing Vararam intake: 143 220 Before..... ![]() After...... ![]() Cutting coil wires to size: 204 210 ![]() Redoing water vapor line: 206 ![]() Refinishing driver side strut tower: 257 359 377 383 451 Before...... ![]() After...... ![]() MISC: How measuring bolts sizes: 152 ![]() Cutting Intake coupler in half: 317 ![]() ************************************************** ************************************************** *** Part used on Project so far: ARP bolts: This is a partial list of all the bolts I've replaced. NOTE: when ordering ARP bolts, you can purchase them in sets of 5 or individual bolts. The sets of five and the individual bolts have different parts number: ![]() 1 - Intake bolts (This is a kit that comes with all 10 bolts. http://www.summitracing.com/parts/ARP-430-2101/?rtype=4 2 - Throttle Body: http://www.summitracing.com/parts/ARP-770-1006/ 3 - Fuel rails. Note: Other fuel rails might require different size. http://www.summitracing.com/parts/ARP-770-1003/ NOTE: OEM rails will use the shorter 6MM by 1 by 20MM length. http://www.summitracing.com/search/?...770-1001&dds=1 4 - Water pump (This is a complete kit): http://www.summitracing.com/parts/AR...3202/?rtype=10 5 - Pulley tensioner: (this part # is for a set of 5 - you will only need three but it's more cost effect to get the bulk amount) http://www.summitracing.com/search/?...772-1005&dds=1 6 - Power steering: Quantity: 3 Size: 10MM X 1.5 by 70MM, Part #: M12AM70-12C 7 - Water vapor lines - Quantity: 2 Size: 6MM X 1 by 20MM Part #: M8AB20-12 Two bolts for passenger cylinder head: http://store.yoastfabrication.com/servlet/-strse-13/Camaro-Head-Plate-Bolts/Detail Stainless fender bolts and washer: http://www.ringbrothers.com/index.cf...Product_ID=369 ************************************************** ************************************************** *** Oil Filter: Pure Power http://gopurepower.com/ ![]() Lokar dip stick: Part #: XED-5008 ![]() ************************************************** ************************************************** *** Coil Relocation set-up: 1 - Coil bracket: http://www.ebay.com/itm/LS1-LS6-coil...item43a9492ba2 ![]() 2 - Plug wires: Manufactor: MSD Part #: 31193 Description: MAD 8.5MM Super Conductor Spark Plug Wire Set Link: http://www.summitracing.com/parts/MSD-31193/?rtype=10 ![]() 3 - 4 Plug wire boot and terminal also needed: http://www.summitracing.com/parts/MSD-3304/?rtype=10 ![]() NOTE: If your using the red plug wires, you wont need to purchase the additional boots and terminals, it's included: http://www.summitracing.com/parts/MSD-32079/ 4 - Wire Separator: Manufactor: Taylor Part #: 42700 Description: Ignition Wire Loom/Separator, Nylon, Black, 7-8mm, Set of 6 Link: http://www.summitracing.com/parts/TAY-42700/?rtype=10 ![]() 5 - Wire heat sleeve: Manufacturer: DEI Part #: 010612 Link:http://www.summitracing.com/search/?...20010612&dds=1 ![]() 6 - Spark Plug Boot Protectors: Manufacturer: DEI Part #: 010512 Link: http://www.summitracing.com/search/?...20010512&dds=1 ![]() ************************************************** ************************************************** *** Fuel Lines and Fuel rails Set-up: ![]() Fuel lines and fittings: http://techafx.com/ Parts: T-609006DTBK Description: -6 90 Deg. PTFE Hose End (AL/ Black) Quantity: 1 ![]() Parts: T-600006DTBK Description: -6 straight PTFE Hose End (AL/ Black) Quantity: 2 ![]() Parts: T-824-06-2 Description: -6 Male An/JIC Flare Tee - Black Quantity: 1 ![]() Parts: T-63006-10 Description: -6 Black Wrap SS Braided Teflon hose Quantity: On web site it's sold in 10 Ft length. NOTE: If you call, you can purchase by the foot. I got 5th and use the rest for the EVAC relocation. ![]() Black anodized fuel rails with no company branding on them: http://www.wegnerautomotive2.com/ NOTE: I don't have a part number but you can call Casey Wegner and he will take care of you. ![]() ************************************************** ************************************************** *** Wiring harness: Injector connectors, map sensor and throttle body extensions: http://www.casperselectronics.com/store2/ ![]() 90 degree injector heat shrink boots: http://www.bmrs.net ![]() Harness tape: http://www.eficonnection.com ![]() Russell Harness sleeving: All 4 sizes Wire Wrap: Manufacturer: Painless, Part#: PRF-70902Description: Protective Sleeve, Power-braid Wire Wrap, Black, .500 in. Diameter, 10 ft. Length, Each Link: http://www.summitracing.com/parts/PRF-70902/ Wire Wrap: Manufacturer: Painless, Part#: PRF-70916, Description: Protective Sleeve, Power-braid Wire Wrap, Black, 1 in. Diameter, 12 ft. Length, Each ![]() Ground cable: http://genuinedealz.com/ ************************************************** ************************************************** *** Carbon fiber valve covers: http://www.katechengines.com ![]() Billet tensioner: http://www.katechengines.com ![]() Powder coated intake: http://thepowdercoater.com/index.shtml ![]() ************************************************** ************************************************** *** Cold Air Intake setup: ![]() Intake: http://www.vararam.com/camaro-ramair-unit2.html Black coupler: http://www.vararam.com/camaro-ramair-unit2.html T-bolt clamps for intake: http://www.mcmaster.com Part #: 5312K23 Description: Type 300 Series Stainless Steel T-Bolt Hose and Tube Clamp, 4-1/32" to 4-11/32" Clamp Diameter Range, 3/4" Band Width Vacuum Line and Fitting: XRP Parts: 209006BB Description: -6 90 Deg double swivel hose end black Quantity: 1 ![]() Parts: 250006 Description: -6 37 Deg male flare push-on hose end Quantity: 1 ![]() Hose: Parts: 3106-00 Description: - 6 XR-31 Nylon Braided Race hose Quantity: Depends on how your routing it. 2 Ft minimum. ![]() ************************************************** ************************************************** *** XRP water vapor set-up: http://www.xrp.com/ ![]() Parts: 82446 Description: Special Tee, Flare -4 Male w/ -6 Male Branch Quantity: 1 ![]() Parts: 109004SN Description: -4 90 Deg Hose End Super Nickel Quantity: 2 ![]() Parts: 100004SN Description: -4 Straight Hose End - Super Nickel Quantity: 2 ![]() Parts: 100006SN Description: -6 Straight Hose End - Super Nickel Quantity: 1 ![]() Parts: 3106-00 Description: - 6 XR-31 Nylon Braided Race hose Quantity: 2 FT ![]() Parts: 3104-00 Description: -4 XR-31 Nylon Braided Race hose Quantity: 2 FT ![]() The blocks are from http://www.krcpower.com/catalog_i112...l?catId=366482 ![]() ************************************************** ************************************************** *** Radiator hose replacement: Aluminum tube: Coupler: Clamps: ![]() Flex-a-lite radiator: http://www.flex-a-lite.com/auto/html..._radiator.html ![]() Meziere electric water pump: http://www.meziere.com/ps-1507-1520-wp329n.aspx Innovators West Front Drive: http://www.innovatorswest.com/8-Rib-...sion-Kits.html ![]() Billet strut tower, over flow and radiator caps: http://www.lsrperformance.com/dress-...vy-camaro.html ![]() Windshield washer relocation kit: http://www.apex-speed.com/apex-motor...t-1234567.html ![]() Motor Mounts: http://prothane.com/ ![]() Improved Racing Oil Pan Baffle: http://www.improvedracing.com/ ![]() NOTE: I will update parts list as we go......... ************************************************** ************************************************** *********************** Okay, so I thought it would be fun to create a team list of everybody who has help make this thread what it is. So in no certain order....here we go BiggFoot ![]() kjkjr27 SS4PK ![]() Calbert1999 ![]() OVRKILL ![]() greenmachinedriver ![]() Synner ![]() 67motorcat ![]() 572HP ![]() aquablueL99 ![]() BIGDADDYGENE ![]() BLACK10 ![]() bmbbl be ![]() brooks35 ![]() cpoboats ![]() CUPRA ![]() donalddb ![]() EZSPEED ![]() Farthestnorth ![]() GlennP ![]() INDY ![]() Kilo-9 ![]() LS2SLOW ![]() MRGOODWRENCH3 ![]() NC-V aka Kyle ![]() Another great project from NC-V aka Kyle ![]() PAULSS ![]() platinumss ![]() Rcfiddy1 ![]() robsls3 ![]() Roctrux ![]() rtcat600man ![]() Switchback700 ![]() Pharmaro ![]() Farthestnorth ![]() My 5th: ![]() Copper98 ![]() ss/rs-matt ![]() TXM62SS ![]() tys2010camaro ![]() Nathan ![]() Pyroboy ![]() ChitownSS ![]() Gene ![]() Dekan513 ![]() New recruits on waiting list: SS4PK Zman12 Steiger Anybody that wants to get added to the list, let us know. Thanks guys for all the help and inspiration! Now lets get more names on the list. Also, if anybody has an better pic they like me to replace with the ones I have, PM me it. And anybody who has pics of their engine bay they like me to post, please post them and I will keep updating the list.
The Backbone!
Drives: '11 VR 2SS/RS M6, 01 Jeep TJ modded Join Date: Jun 2011
![]() Drives: '10 Camaro 2SS Join Date: Nov 2011
Subscribed , great idea !
Here are a few things I have done to clean up the engine compartment. First was to get rid of the engine cover and top intake manifold cover. I installed the TechAFX heater hose kit. It also includes a new fuel line. I polished the fuel rail and rotated it 180degrees.
![]() ![]() ![]() The Roto-Fab Radiator cover cleans up the top of the radiator. ![]() A Katech Billet Belt Tensioner looks better than the factory one. ![]() I made a new PCV hose and routed it under the Throttle Body instead of over the top. ![]() The cold air intake is by ADM Performance. I think it is the best looking piece on the market. The washer bottle is by Roto-Fab.
![]() Drives: 2010 2SS RS M6 Blk Join Date: Jul 2010
I like what you've done there....but truth be told is doesn't "clear up" the plumbers clutter the OP pointed out regarding our egine bays. Removing the engine cover just exposes the mess beneath lol.
G6X3 cam,Vararam, Kooks stepped LT's, Kooks Hi-Flo cats and 2.5" street sleeper cat back, ported TB, 18% UDP, 12.63 @ 117 (pre-cam).
#6 |
Most hated in NM....
Drives: Supercharged SS Join Date: Sep 2011
looking real good. Looks like you actually have a muscle car engine rather than a piece of plastic
#7 |
The only thing else that mr good wrench could do is a coil relocation kit and get some new valve covers. you really can't do much else unless you are going to do some major surgury. ADM did a build where they moved the fuse box out of sight and that really cleaned to motor bay up some, but that is pricey.
#8 | |
I did some research on the Gates hose clamps. A few guys express concerns with using them on this thread. http://www.camaro5.com/forums/showthread.php?t=187235
This video might shed some light. Worth watching, very informative and educational. Thoughts please. The section circled in red show how much the radiator hose binds you move it forward to install a Vararam. I measures that section and the hose goes down from 1.75 inches to 1. I'm in the process of remedying this with new hoses and clamps. I will keep you guys posted.
#9 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
I cleaned mine up by using 2012 Camaro heater hoses, flipped the fuel rail 180 degrees, removed the intake manifold cover and powder coating the coil brackets. In the next month I will make a few more changes.
Heritage Grill, Cold Air Inductions Intake, Elite Engineering Catch Can, BMR 1" Lowering Springs, Sway Bars and End Links, Clear Image Jet Hot Ceramic Coated headers and High Flow Cats, Hurst Billet 2 Shifter, LSR Billet Strut Washers, DynoMax Axle Back Exhaust, JANNETTY MAGIC! Last edited by PAUL SS; 01-04-2012 at 09:11 AM. Reason: sp |
#10 |
Lackonblacksls sent me these pictures. This things is Bad Ass. Not one original factory hose on it. 427 13.7 to 1 compression!
#11 |
Drives: 2010 SS, 06 SRT10 Ram Join Date: Nov 2011
People actually clean under the hood?
#12 |
![]() Drives: 2011 2ss/rs Join Date: Aug 2010
Yep my car with the black fast with blue letters
#13 |
Clean, no. Don't allow it to get dirty, yes.
Heritage Grill, Cold Air Inductions Intake, Elite Engineering Catch Can, BMR 1" Lowering Springs, Sway Bars and End Links, Clear Image Jet Hot Ceramic Coated headers and High Flow Cats, Hurst Billet 2 Shifter, LSR Billet Strut Washers, DynoMax Axle Back Exhaust, JANNETTY MAGIC! |
#14 |
I used to be Stieger....
#15 |
Looking for thoughts on powder coating the stock intake in a "wrinkle Black' finish. It will be subtle but slightly different than factory. Perhaps a more cast aluminum look. I'm going for a industrial high tech look. Not to showing or Bling.
Some thing like this: http://www.camaro5.com/forums/showthread.php?t=110331 Let's hear it.
#16 | |
Heritage Grill, Cold Air Inductions Intake, Elite Engineering Catch Can, BMR 1" Lowering Springs, Sway Bars and End Links, Clear Image Jet Hot Ceramic Coated headers and High Flow Cats, Hurst Billet 2 Shifter, LSR Billet Strut Washers, DynoMax Axle Back Exhaust, JANNETTY MAGIC! Last edited by PAUL SS; 01-30-2012 at 08:27 AM. |
#17 | |
POWER TECH
![]() Drives: 2010 CAMARO. 10.04@133mph, 1.4 60' Join Date: Jul 2009
heres a pic and vid of my engine bay
#18 | |
I was thinking the same thing....... that you couldn't powder coat the intake because it isn't metal and wouldn't withstand the 400 degree of baking neccessary. But apparently this company has it figure out. They do alot of work in the corvette community. http://www.peakspeedshop.com/PowderCoat.php
#19 |
![]() ![]() Drives: camaro ss-05chopper-13-street glide Join Date: Apr 2010
i chromed a fiberglass intake cover on mine
#20 |
![]() Drives: Black 2011 2SSRS owner Join Date: Oct 2010
Subscribed.
Colossians 3:17 RK Sport Rear Spoiler/Black Chrome Powder Coated SS Wheels/Air Lift Suspension/MagnaFlow Competition Axleback 5" Tips/Hurst Short Throw Shifter/Trinity 1000 Programmer/Black GM Heritage Grille/Street Scene Lower Grille w/Ducts/20% Tint/Smoked Exterior Lens Kit/Driver's Side Grand Sport Hash Marks Flat Black |
#21 |
OFF THE HOOK
Just put one of these in there and call it good!
#22 |
gfx installed
Drives: abm2ssrs Join Date: Apr 2009
i just keep the hood closed.
#23 |
Blown Cool Breeze
Drives: 2011 Black on Black 2SS M6 Join Date: Jul 2010
I did what alot of other guys here have done.
But I routed the wires where it splits around the oil fill cap to what I believe is a better position. Also mounted the evap solenoid to the ECM tower which I haven't seen anyone else do yet.
Had a 2010 IBM 2SS M6 Enjoy life.Think of all the women on the Titanic who passed up dessert. |
#24 |
haha... The hood seems to do a great job of that. I was installing my maggie last weekend and was amazed at how clean the engine was considering that I had never actually cleaned it before
#25 | |
| Thread Tools | |
| Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ | AutoAgenda | Exterior Parts & Accessories | 14 | 02-06-2013 08:43 PM |
| New Texas Speed & Performance Engine Machining Center! | Trevor @ Texas Speed | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 18 | 01-16-2013 03:46 PM |
| Hawk Performance Brake Pads part HB247Z.575 $85.00 | Rogan | USA - Florida | 2 | 10-07-2011 12:10 PM |
| Acronyms? | KEEP RT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 03-11-2011 08:57 PM |
| Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
