10-16-2009, 06:47 PM | #225 |
Drives: 2010 2SSRS RJT Join Date: Sep 2009
Thanks for the great advice. Fortunately I found this when the car was under 100 miles. I am now around 600. I have been careful to accelerate hard only from rolling starts and after the car is sufficiently warmed up, although I couldn't resist accelerating from a dead stop this morning. This ahole in a Mercedes cut me off on the freeway offramp. I pulled next to him at the light at the entrance to the freeway with the car well warmed up. Green light - punched it - chirp (1st gear) - chirp (2nd gear) and off I went. L99 in case you are wondering.
Man did it feel good. First time I've heard the tires break loose. Sounds like the motor is coming along well. |
10-19-2009, 05:32 PM | #226 |
Drives: 2010 Camaro 2SS/RS ABM Join Date: Jun 2009
Darin i am in NY and expect my car 1st week of Nov, does the cold weather affect break in or just warm it up good before you pound on it?
2SS/RS/M6 | ABM | White Stripes | Black Int
Mods: American Racing Headers & Exhaust, Airaid Intake, Pfadt Front/Rear Sway Bars, Stealth Bulbs, AAC LED bowtie, AAC Concept LED Side-markers ABM/Tinted, 20% Tints, Chuck COW Tune, MGW shifter (blue with white racing stripes). Coming Soon: 4:10 Gears? |
10-20-2009, 10:22 PM | #227 |
Drives: BADDEST SS IN ATL!!!! Join Date: Oct 2009
Darin, thanks for all the great input. I have a couple quick questions for you. You have said the break in period is within the first 300 miles correct? I will be receiving my car early November and was wondering how long does this break-in need to take place over? i was also wondering if i could take a weekend off and break it in over 2 days or 300 miles? i ordered the ls3 and just wanted to clarify that once you hit your desired speed with the 6spd you drop it into neutral and coast to stop or use the brakes if need be? Also do you think there is a certain number of loaded runs you should take or is it just a mileage thing? thanks for the input on these questions.
10-21-2009, 09:33 AM | #228 |
Drives: 2010 Black 2SS Join Date: Jul 2009
Darin,
I followed your prodcedure the best i could, i know you had mentioned that you should not down shift during the break in procedure. (Changed the oil at 1500) The car now has about 2100 miles is it ok to down shift for use when slowing the car down? Thanks, |
10-21-2009, 12:42 PM | #229 |
10-22-2009, 01:43 AM | #230 |
Drives: 2010 Camaro Auto 2SS/RS Join Date: Oct 2008
People, it's not rocket science!! Load the engine with quick acceleration runs to whatever speed you're comfortable a bunch of times. Let it cool and repeat. Seriously it's that easy. At about 500 or so miles, change the oil and you're good to go. Do what you please with your broken in car
10-22-2009, 08:31 AM | #231 | |
Reher Morrison Racing
Drives: Inferno Orange SS/RS Join Date: Jul 2009
After break in you can do anything you want. Downshifting into corners is not only fun, its the proper way to approach the apex and have power coming out. I dont shift the living hell out of mine. Your done, go have fun!
2010 Camaro SS/RS IOM, 475rwhp 415ft/lbs Cam-232°/245° .612 .612 113LSA. Precision 3500 stall, New Era CAI. Reher Morrison Heads, Manifold and TB. Ferrea H-stems, dual springs, Ti-retainers. American Racing long tubes-Xpipe, High flow CATs, "S"type Borla's. 160F Thermo.
VVT ACTIVE! Thanks to New Era Performance! -Induction R&D-EFI calibration Reher-Morrison Racing Engines http://www.rehermorrison.com/rmSale3.htm Phone 817-467-7171 cell 682-559-0321 |
10-22-2009, 08:33 AM | #232 |
No, it does not.
10-22-2009, 08:34 AM | #233 | |
10-22-2009, 11:34 PM | #234 |
Drives: 2010 2SS, IBM / BLK (10/09/09) Join Date: Aug 2009
Vector is making the claim that you can just go back to the original factory tune before you go in for service. That makes sense as long as they can't see that it was ever changed to begin with, correct? This is a question that I think we will be seeing an answer to soon......many people are using those tunes right now.
10-23-2009, 07:03 AM | #235 | |
If you tune your car and things happen you should accept the risk. Not GM. I am not saying that everything is off limits to Warranty. If the front head lamp goes out or your trunk hinge fails that has nothing to do with the drive train and GM techs won’t care if you flashed it. I think the choices are clear. Flash it and except that something may go wrong and that you will pay for it or don’t flash it and keep your warranty in tact.
VVT ACTIVE! Thanks to New Era Performance! -Induction R&D-EFI calibration Reher-Morrison Racing Engines http://www.rehermorrison.com/rmSale3.htm Phone 817-467-7171 cell 682-559-0321 Last edited by Darin Morgan; 10-23-2009 at 07:05 AM. Reason: mispell |
10-23-2009, 10:10 AM | #236 |
Drives: 2SS RS CGM Join Date: Sep 2009
Darin,
I read earlier in this thread that you did not chage the oil that came in your car to a "break- in" type oil. I will be getting my camaro in a few weeks and was thinking about changing the oil as soon as I drive off the lot to a " Break in" oil, and wanted your opinion. If, you think I should, what type would you recommend? |
10-23-2009, 10:12 AM | #237 | |
10-25-2009, 06:41 PM | #238 |
Drives: 1998 Z28 Join Date: Oct 2009
I am so glad to see that someone touched on this. Getting the rings to seal up with proper break in is worth a lot. I have seen so many tuner shops on new built engine just start it up and let it idle for 30 min.
Similar Threads | ||||
What's considered a Muscle Car? | SyN | General Automotive + Other Cars Discussion | 125 | 09-25-2010 12:04 AM |
4-Sale 2001 Z/28 Show Car A4, t-tops | 01pewterz28 | Autos For Sale / Wanted | 10 | 08-12-2010 08:26 AM |
Getting Antsy | Doc | 5th Gen Camaro SS LS LT General Discussions | 26 | 08-19-2009 11:49 AM |
Car show creetons!!!! | attymf | 5th Gen Camaro SS LS LT General Discussions | 51 | 08-09-2009 09:19 PM |
