Old 07-21-2011, 10:48 PM   #29
Camarowguy
Camarowguy's Avatar
Drives: 2011 imperial blue SS, black 92 RS
Well ima try it.
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :(
2017 Silverado 5.3 all stock
2004 5.7 GTO 78mm turbo
Camarowguy is offline   Reply With Quote
Old 07-21-2011, 10:50 PM   #30
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Originally Posted by CyberDan View Post
If you're trying to sell it, I'd refrain from using words like "tossed".. These things are pretty delicate.
LOL... it's actually in the bubble wrap bag that the new one came in... I don't really care if I sell it or not... someone around here will need it and I'll give it away...
Old 07-22-2011, 05:45 AM   #31
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
PMs sent to those that requested them. The "strong" MAF sensors are getting fewer and further between now that people are seeking them out but we can track them down on a case by case basis. Just hit me up.
Old 07-22-2011, 07:32 AM   #32
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
All you did was get a maf that reads DIFFERENTLY (note: not better) then your old maf. Apparently, this fit more or less better into the pre-defined tune tables in the stock tune. A dyno or street tune from any tuner would fix this, as there isn't anything wrong with the original maf.
DietCoke is offline   Reply With Quote
Old 07-22-2011, 07:35 AM   #33
Camarowguy
Camarowguy's Avatar
Are you sure? Vararam advertises with their intake and a weak maf sensor they have problems. Problems like I'm experiencing. So I'm just wondering.....did you yourself have a weak maf on a Vararam and try the strong one only to feel no difference? Btw, if the reaction time (which is what is different from what I gather) is slower on a weak one, no tune is gonna fix that. Just sayin......
Old 07-22-2011, 07:38 AM   #34
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Vararam's problem is due to the nature of the box. I have the exact issue Vararam has (shitty part throttle and cruise driving) when I have my ram air duct open. Basically all that air is being forced into the intake pipe, but since your throttle body is closed at part throttle or cruise, it has nowhere to go. While this is great at WOT because the engine is sucking air in, at part throttle it just causes the rammed air to get extremely turbulent inside the intake. This will throw MAF readings all to hell, and is why I have a threaded cap on my 4" ram air pipe that is sealed into my airbox. When I'm ready to race, just remove the cap, and it's good to go. No more turbulent air readings, no more erratic cruising and weird stuff happening. It's literally night and day with the cap as far as drivability goes.
Has nothing to do with a maf being 'weak' or 'strong', they just read air differently. Case in point: no one has MAF issues at WOT with the Vararam.
Old 07-22-2011, 08:11 AM   #35
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
Can't speak for the vararam as I have a cai. Inc I can say my car dogged it at all driving conditions including at wot. It no longer does after swapping out the maf. After swapping back and forth as in my original post nothing was helping. I have no tune or any other mods. The new maf made all the difference for my particular situation.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 07-22-2011, 08:13 AM   #36
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
mlee could toss Me all night long!
LMFAO!!
Old 07-22-2011, 08:14 AM   #37
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
Well if your just going to chuck it...SUPRBAD will take it!
Old 07-22-2011, 08:18 AM   #38
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Precisely what I'm getting at. The new maf is feeding your pcm different air numbers, which makes your car run better, because they fit what your pcm whats to see.
Not stronger, or better. Just different
A tune would negate the MAF change completely, as you'd tune the car to the air/MAF.
Old 07-22-2011, 08:23 AM   #39
shevyman
Drives: 2010 Camaro SS IOM
ok i have a question. does this only affect the l99's this is something new to me i am reading. i am asking cause i see alot of you have the aa and also i know the l99 has that fuel saver thing so i am wondering if that is why there is a weak maf. correct me if i am wrong or said something wrong. thank you
shevyman is offline   Reply With Quote
Old 07-22-2011, 08:26 AM   #40
csjcsj
csjcsj's Avatar
Drives: 2010 Camaro SS/RS 6spd
So if my car has been tuned, you are saying it would do me no good to. Change the maf????????!! Check my sig for mods!!
csjcsj is offline   Reply With Quote
Old 07-22-2011, 08:40 AM   #41
Wild Bill
Wild Bill's Avatar
Drives: Camaro 2015 RS CRM
I also have a "Stong" lightly used MAF. I bought a new one without checking the number. $45.00 shipped anywhere in the USA.
I also have 4 brand new, in box, GM center wheel caps for the midnight silver SS wheels. I went in a different direction and never installed them. All 4 shipped anywhere in the USA, $40.00.
PM me if interested.
IOM 2SS/RS manual
1100 - 4/7/09
3000 - 5/27/09
6000 - 7/17/09
See my Thread in New York Metro Area.
http://www.camaro5.com/forums/showthread.php?t=33878
Wild Bill is offline   Reply With Quote
Old 07-22-2011, 08:43 AM   #42
Camarowguy
Camarowguy's Avatar
Can you post some pics of your setup? I'm interested to see what your talking about. My car actually drives fine, no bucking at all. The only issue I have is the lack of response when the throttle is cracked open suddenly. The only thing I can relate it to is back in my carburetor days, if the throttle pump wasn't adjusted right...or didn't have a big enough shot, it would hiccup, pop back, or hesitate. This is my experience.
I just ordered one from the local dealer. He went pulled it out the package and it had k11 on it....so I should be good to go. The list price was about $75, but being I work in the parts dept and order parts from them all the time I got it cheaper. Let's just say it was below $60. I'll have it by lunch time and I'll give you guys an unbiased opinion. At least this will put it to rest for me.
Dealership Screw Up - Clearcoat Issue FDNY-L107 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 12 04-26-2011 10:52 AM
window indexing issue TripleB 5th Gen Camaro SS LS LT General Discussions 9 03-20-2011 11:19 AM
Sequential Tail Light Issue 40again Cosmetics and Lighting Modification Discussions 5 03-17-2011 01:33 AM
Please Think before you post 35th02ss Off-topic Discussions 35 08-02-2009 09:38 AM
Bumleb's Camaro battery cable issue is almost Fixed, Issue Solved Bumleb 5th Gen Camaro SS LS LT General Discussions 118 05-14-2009 11:04 PM
