06-22-2017, 06:15 PM | #701 |
Congrats George, as long as they foot the bill for the original parts to be replaced you can start all over again. I know its a lot of work but I am sure you wouldn't be happy if someone else tried to replicate your work for you. I remember we mentioned back when we were talking about your dents in the fenders about what would happen if you should have an accident.Sure enough Murphys Law lol. This time when you're finished we'll keep our mouths shut, LOL
06-22-2017, 06:45 PM | #702 | |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
All my so called "friends" are ass holes. They're already taking bets on how soon it will get hit again once done. On a side note a friend of mine bought a '17 ZL1. He had a clunking noise in the front end. He took it in and they found a nut backed off, he thinks they said it was the sway bar. All was fine for about a week and now something else is clunking, he came by today and had me take it for a ride to see what I thought it might be. I can feel it banging under the drivers seat and I'm thinking it might be the exhaust. Any ways, it's a manual, so after driving it for about 4 miles I remember why I got an auto, my ankle would be junk if I drove it any more, doesn't bend well after all the surgeries I had years ago in a bike accident. Even so it is quite a car, plenty of power, transmission shifts like butter, steering and braking is excellent, all the electronics and technology is much more advanced than on my 2010 but in all honesty, I like mine much better. I know I'm biased but mine feels much more like the muscle cars I grew up with and I'm glad. |
06-23-2017, 06:56 AM | #703 |
Started on the lower grille /plate frame before I tend to customer work, so looking at the original one I was trying to figure out how to make the new one look like the old one. The first one to say "why don't you smash it into a wall" is on my shit list.
The original one started out with an aluminum frame then went to the plate frame welded in so it's not as clean as I would like so I decided to go about it like this. I trimmed down the plate frame to the right size. Then I drilled a small hole in the center which was simple as it's got a dimple in the center from the molding process. Then I clamped it to a straight edge and using a heat gun bent it to the appropriate angle. Now using the center hole and the screw holes for the plate I could get a visual of the grille under it to position it exactly centered. Then I marked the outline of the plate frame. From here I will remove the areas inside the outline to the correct depth to keep the plate mount flush with the grille then I will weld it in. The first time I did it I considered it fun, this time it's just work but I have to do it as the final look is much better than the factory mounted plate frame. |
06-24-2017, 07:55 AM | #704 |
Trying to finish up the lower grill today. I'm finding it a bit challenging this time. Where as I don't have the car or the facia here to fit and measure things and also without the facia mounted to the car it's difficult to make sure everything is straight and the angles correct because the plastics are flimsy when cut up.
I cut a strip of steel to lay in between the grill slots to use as a guide for grinding the recess the plate mount will fit into. This makes it much straighter and cleaner than doing it by eye as I did the first time. I just need to trim the edges slightly to fit the mount and it's ready to be prepped and welded. I'm hoping that when it's finished it will fit right because all I have to go by is the original one but it's pretty mangled up. |
06-24-2017, 09:49 AM | #705 |
everything has been fit and positioned for welding. As soon as I run a few errands I will get it welded up. I sure wish the car was here with the facia on so I could double check fitment but not much I can do about it.
06-24-2017, 01:03 PM | #706 |
Well I'm glad that's done, as I've said before, hope I don't have to do that again.
This one came out good with a small change. I recessed the plate mount a little more than previously. On the last one I had to notch the facia slightly to fit the plate cover, I'm hoping this time it wont be necessary but wont know until I try it on the facia. It sits flush with the grill but not sure if the grill sits flush to the facia. Never paid much attention to it and can't tell from pictures, regardless, it's done. |
06-25-2017, 05:18 PM | #707 |
Looking good so far, I guess it's kinda nice to have a second shot at everything. Sometimes you get better ideas after you finish a project.I suppose you could think of it as Version 2.0
06-25-2017, 05:28 PM | #708 |
I guess but I'd rather be doing other things I have been thinking about instead of doing things over. I was satisfied the way it was but it is what it is.
06-26-2017, 03:54 PM | #709 |
Here's another example of why insurance companies suck.
I posted the dash cam and security camera videos of the accident. It seems to me that everyone who has seen the videos can clearly see what happened yet the other insurance company sent me this today. If my company didn't finally approve my claim I would be up against his company on my own and would have to argue fault against them. |
06-26-2017, 04:50 PM | #710 |
That's incredible, maybe they had to have followed you right up your drive and get hitched to your bumper before there is any owning up to the blame.
06-26-2017, 05:12 PM | #711 |
It is incredible. Insurance companies have so much money and power it's almost impossible to fight them. Even a lawyer wouldn't touch this case because without bodily injury there is nothing in it for them. To hire a lawyer and go to court would cost more than the repairs to the car, with bodily injury the other person insurance would be required to pay for attorney fees if the ruling is in your favor but not for property damage. The insurance companies are well aware of this so use it to their advantage.
06-27-2017, 06:23 PM | #712 |
Finally everything is sorted out, I think/hope. The body shop has most if not all of the replacement parts in house and are starting in on the repairs, estimated shop time is 2-3 weeks then from there I'll get the suspension work and alignment done. Meanwhile I made a couple of templates for the DRL covers and ordered the smoked Lucite for them. I'm hoping to see it by the weekend so I can cut them out and decide on the best way to attach them. I didn't take any pictures but will soon.
06-28-2017, 06:59 AM | #713 |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
Do you have a part number or fitting size that you used by the throttle body? Getting it drilled and tapped so that I can have a decent catch can setup.
06-28-2017, 07:12 AM | #714 |
Similar Threads | ||||
OK...I'm starting a better V6 exhaust examples thread!! | KMPrenger | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 611 | 07-01-2020 08:49 AM |
Pyr0b0y's SS Build Thread [COTW 5/23/11] | pyr0b0y | Member Car Journals | 825 | 09-25-2014 12:20 AM |
Well, I guess I should start my own build thread. | Powhusku | Member Car Journals | 140 | 09-23-2013 12:13 PM |
Ph4r's Car - Boobies - Build Thread | Ph4r | Member Car Journals | 42 | 03-20-2013 06:09 PM |
Neogenix's 2011 SS/RS BLK/BLK Build Thread | neogenix | Member Car Journals | 7 | 02-27-2011 10:15 PM |
