07-28-2009, 05:29 PM | #1 |
Drives: 2010 Camaro/2009 Nissan Rogue Join Date: May 2009
Low oil pressure
My oil pressure reads well below the 30 PSI mark when at idle. I hope its just an inaccurate gauge. All the small block Chevys I have owned always had over 30 PSI at idle. Should I be concerned?
07-28-2009, 05:49 PM | #2 |
Drives: abm2ssrs Join Date: Apr 2009
L99 or ls3
[SIGPIC]
07-28-2009, 05:50 PM | #3 |
L99 or ls3 i will look at mine for you i have L99
[SIGPIC]
07-28-2009, 05:52 PM | #4 |
ZUL8TR
Drives: 94 Z28 Join Date: Feb 2009
No I would not be concerned. I have a 2SS also and my pressure is @ 30psi at Ilde. This is when the oil temp is around 180-200 degrees.
07-28-2009, 05:52 PM | #5 |
Drives: Aggressive Join Date: Jul 2008
Mine is the same way. I figured it was normal. Is it not?
Black 2SS RS LS3 Inferno Int. '17 1LE replica 20's {MODS} KOOKS LT: Borla S-Type: Roto-Fab CAI: Hurst ST.: PFADT Stage 2, Trailing arms, Tie Rods: ECS BigBlower Cam: Fast 102mm intake: Brian Tooley racing dual spring kit: TFS pushrod set: Katech C5R timing chain: Mellings high volume oil pump: ATI Balancer: Ideal performance upgraded clutch master cylinder:Tick performance upgraded slave cylinder/throwout bearing: Mantic 9000 twin disk clutch & light weight flywheel: Tuned by Doug Ring at ECS. 475RWHP/445RWTQ.Dynapack Dyno.
07-28-2009, 06:12 PM | #6 | ||
Truth Enforcer
Drives: anything I can get my hands on Join Date: Sep 2006
how many small block chevys have you had?
my LT1 idles at around 6psi for oil. lol
A group as a whole tends to be smarter than the smartest person in that group until one jackass convinces everyone otherwise. Quote:
07-28-2009, 06:22 PM | #7 | |
1995 LT1 in Z28 1999 5.3 New Silverado 2001 LS1 Trans Am 2002 LS1 Collector Edition T/A 2007 5.3 Avalanche LTZ 4x4 and now the 2010 SS All, except the SS have had good oil pressure....according to the gauges. |
07-28-2009, 06:24 PM | #8 |
BTW it is the LS3 with 715 miles.
07-28-2009, 06:36 PM | #9 |
Drives: 2010 Camaro 2SS RS M6 CGM A9125214 Join Date: Jun 2009
Normal, the oil pressure minimums when hot for the LS3 and L99 are as follows:
6 psig at 1,000 engine RPM 18 psig at 2,000 engine RPM 24 psig at 4,000 engine RPM |
07-28-2009, 07:35 PM | #10 |
Similar Threads | ||||
L99 Delete Whats involved? | jsharp | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 59 | 05-26-2009 10:54 PM |
How about a barrel of oil for around $16? | Blownhotrodder | General Automotive + Other Cars Discussion | 19 | 03-06-2009 07:25 PM |
The 3,000 Mile Oil Change Myth | KILLER74Z28 | General Automotive + Other Cars Discussion | 35 | 07-20-2008 09:02 PM |
Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 09:47 AM |
