Old 03-25-2011, 10:42 PM   #1
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
DRL and halos on all the time for only $2.99!
This has been my easiest and most favorite mod so far!
I searched and searched to try to find if anyone had done this before but couldn't find a good thread showing what wires to use. So i grabbed my trusty test light and did it myself.
I installed some LED DRL today and also wired them with my halos. So now my halos are always on with my DRL and when it gets dark and my headlights come on automatically the DRL stay on! It was super easy and the parts only cost me $2.99.
All you need is about 2 feet of wire and 4 quick splices, I bought a 10 pack for $2.99.
Unplug the harness going to each headlight and DRL. splice the power wires together on the left halo/DRL and the right halo/DRL. Plug the harnesses back in. DONE!!!!!
Not sure if the wire colors and position are the same for the 2010 but on my car i tapped the brown with white stripe wire on my passenger halo to the blue wire on my passenger DRL. On the driver side i connected the purple wire from the halo to the light blue wire on the DRL.
SUX2BU is offline   Reply With Quote
Old 03-25-2011, 11:20 PM   #2
RedJewel2011
Drives: RS Rims, Spoiler & Retrofitted HIDs
Great Info! But mine isn't RS.
Good to know, Thanks and looking good.
RedJewel2011 is offline   Reply With Quote
Old 03-26-2011, 06:08 AM   #3
JohnForeman
Drives: 2010 2SSRS
Can you give us the info on the LED DRL's that you used?
Thanks
2010 2SSRSA6 - GFX
35% Window Tint
93 Octane Diablo Predator Tune
JohnForeman is offline   Reply With Quote
Old 03-26-2011, 10:25 AM   #4
hvychvy970
hvychvy970's Avatar
Drives: Black 2011 2SSRS owner
Is it possible to unplug those DRL's at the bulb and the Halos still come on like that? That is what I really want to do. Is it too much of a pain for you to test that?
Colossians 3:17
RK Sport Rear Spoiler/Black Chrome Powder Coated SS Wheels/Air Lift Suspension/MagnaFlow Competition Axleback 5" Tips/Hurst Short Throw Shifter/Trinity 1000 Programmer/Black GM Heritage Grille/Street Scene Lower Grille w/Ducts/20% Tint/Smoked Exterior Lens Kit/Driver's Side Grand Sport Hash Marks Flat Black
hvychvy970 is offline   Reply With Quote
Old 03-26-2011, 11:50 AM   #5
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
hello, if i understand correctly, you are talking about removing the power wire from the drl's and leaving the jumper wire from the drl (power wire) to the halo's? if this is what you are asking, the halo's would be on all the time and the drl's would never come on. is this what you are asking?
the next problem is that you when you connect the 2 power wires together and there are no diodes added, you will get back feed up the wire back to the source. this is not good. someone might correct me if they know more. this has been discussed with many of the harnesses that have been made here on the forum.
lupe
overhaulengines is offline   Reply With Quote
Old 03-26-2011, 01:00 PM   #6
IBM/2SS/RS/LS3
NorCal Camaro➎ Member
IBM/2SS/RS/LS3's Avatar
Drives: Bowties ONLY!!
Hope you used a diode in there.
IBM/2SS/RS/LS3 is offline   Reply With Quote
Old 03-26-2011, 09:18 PM   #7
Ph4r
Top Down Fun
Drives: 11 2SS/RS IOM Vert
If I am following the way he did the mod right, the right thing would have been to add two diodes per side, but that would be a bit more complicated install. You would then need to cut the power wire in each harness just before the jumper and splice in the diode, that way neither power source can short out the output, and everything works the way he wants.
That being said, are both of them coming straight from a BCM Module Output, or do they go through a relay? If either goes through a relay, there will be no harm in leaving out the diode on that leg.
I am also wondering what LED DRL's he installed, and where they came from. We seem to have very similar tastes.
2011 Chevrolet Camaro Convertible 2SS RS M6 IOM Vert! IO Interior, Factory Hurst, Painted GFX, Black Rally Stripes, Front/Rear/Bowtie Blackouts, QTP Cutouts, Extra Cupholders!
LED Tails, LED DRL's (always on!), Ghosted "Concept" LED Side Markers, LED Tag Lights, Tinted LED Reverse Lights, Chrome Front Turn Signal Bulbs!
My Build Thread
Daily Driver: 2016 Ford Fusion Titanium with 2 car seats in the back!
Ph4r is offline   Reply With Quote
Old 03-27-2011, 09:23 AM   #8
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
No need, like Ph4r said the power comes from a relay so the computer is not affected by this mod. A diode would only be needed if you wired this BEFORE the relay. I know a thing our two about wiring, I basically rewired my entire 98 SS daily driven race car.
I checked again and this does indeed per the parking lights.
Old 03-27-2011, 09:32 AM   #9
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
I got the same P13W DRL Bulbs that AAC sells they were $50 for the set. I don't think the place I got them from is a sponsor so PM me to find out the website.
Old 03-27-2011, 10:14 AM   #10
ToddB
Drives: 2011 2SS Convertible Supercharged
Nice job.
ToddB is offline   Reply With Quote
Old 03-27-2011, 10:59 PM   #11
IBM/2SS/RS/LS3
With 15+ years of 12 volt in my background, I too know just a little about wiring.
So the halos are powered by a relay??? I doubt it. I'm just asking since a LED doesn't need a relay and you're allowing 12+ to possibly flow back into the BCM.
And are you also aware of PWM (the output of the DRL's)?
And please don't use a test light and Scotch Locks on a 40k+ car..
Old 03-28-2011, 12:50 AM   #12
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
I searched for a while and I think you might be right about no parking light relay. Might throw 4 diodes on there just to be safe, and keep the exact same function I have now. But so far it has been working great.
Old 03-28-2011, 01:01 AM   #13
IBM/2SS/RS/LS3
Just trying to help ya
FYI: The DRL uses a pulse width modulation circuit and I bet your halos pulse a little huh? And the way you've wired it you'll be sending the PWM "pulse" back into the BCM; NO BUENO. A simple 50v 5A diode will work for ya' ($2.50 or so at Radio Shack)
Another thing you could do is add a relay. DRL+ to 85, ground 86, 12+ to 30 and 87 to the halo.
Old 03-28-2011, 01:10 AM   #14
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Haven't noticed any pulsing. Does it do it the whole time?
Halo's as DRL on NON-RS (working prototype) MagnumForceGB Cosmetics and Lighting Modification Discussions 7 10-14-2010 02:52 PM
How do I get my Halo's to turn on all the time like DRL? Topdown Cosmetics and Lighting Modification Discussions 23 07-29-2010 03:59 PM
